> For the complete documentation index, see [llms.txt](https://docs.novacura.com/marketplace-documentation/llms.txt). Markdown versions of documentation pages are available by appending `.md` to page URLs; this page is available as [Markdown](https://docs.novacura.com/marketplace-documentation/applications/explore-apps/ifs/worksite-field-reporting/documentation/ifs-cloud/crew-management.md).
# Crew Management
This flow can be used to manage crews and crew members. The flow starts with a Project check for the logged-in user. If the user does not have a selected project then he/she needs to select one.
Owners of the crews can:
* Create New Crew
* Delete Existing Crew
* Reassign Supervisor
* Add and Delete Crew Members
![](https://3218748546-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F-MiW42YxFsGXIDjQJKNR%2Fuploads%2FIBDrqrWez3BfkceWb8SV%2FCrew%20Management%20Cloud_wf.png?alt=media\&token=9716e6c7-e688-45fa-b832-31ea68192b60)
{% file src="/files/Q03wmes0wit8hs3Kxozz" %}
## Functions
### Select Crew
On the first screen, users can see those crews in the drop-down list which belong to the user as owner or supervisor. In addition, users can also create new crews.
* To create a new crew select 'New\...' from the list
* Display the Project Company, current Project, IFS User ID, and IFS Person
| <img src="https://3218748546-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F-MiW42YxFsGXIDjQJKNR%2Fuploads%2FOW2oXBr88gnRupfuEV0s%2Fimage.png?alt=media&amp;token=d5d16b74-3d6a-447d-a142-e7d16ddbec7b" alt="" data-size="original"> | <img src="https://3218748546-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F-MiW42YxFsGXIDjQJKNR%2Fuploads%2FzYR3RPcMFpFJCPSwtsYw%2Fimage.png?alt=media&amp;token=11700b33-6c4b-499f-9e68-4f954641eeb7" alt="" data-size="original"> |
### Crew Details
On this screen, users can add/modify the employees of the crew.
It is also possible to change the supervisor.
When creating a new crew:
* Crew ID field is empty
* Give the name of the new crew
* Select a supervisor person from the single-selection list
* Select the crew members from the multi-selection list
* Click on the Save button
When editing an existing crew:
* Crew ID field shows the ID of the crew
* If the Crew name is not empty, user can modify it
* The supervisor list shows the current supervisor
* Crew members list show the members
* If anything has been changed, click on the Save button to save the modifications
The green highlighted crew member in the list is the supervisor
| <img src="https://3218748546-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F-MiW42YxFsGXIDjQJKNR%2Fuploads%2FrrKuacXPwadysBMrhk4a%2Fimage.png?alt=media&amp;token=08bb890c-679d-4d7f-9170-1b318a8daa65" alt="" data-size="original"> | <img src="https://3218748546-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F-MiW42YxFsGXIDjQJKNR%2Fuploads%2FYeKouItYhfH5l7bV9bNc%2Fimage.png?alt=media&amp;token=53c80720-b7af-4fa5-b976-147c576047d8" alt="" data-size="original"> |
| <img src="https://3218748546-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F-MiW42YxFsGXIDjQJKNR%2Fuploads%2Fzcxyk3IhU2GHhydCqLYs%2Fimage.png?alt=media&amp;token=0fbee8fb-0724-4a4c-9cb1-a14b90cbbe60" alt="" data-size="original"> | <img src="https://3218748546-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F-MiW42YxFsGXIDjQJKNR%2Fuploads%2FPFhNj9DN7ncoImtuKufm%2Fimage.png?alt=media&amp;token=dd06a108-dcf0-459f-85eb-d819f4517337" alt="" data-size="original"> |
| <img src="https://3218748546-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F-MiW42YxFsGXIDjQJKNR%2Fuploads%2FykUy3r48ic5ZhtWHMZWK%2Fimage.png?alt=media&amp;token=016228e5-b39d-47aa-a3ed-0a9c1fc4a2de" alt="" data-size="original"> | <img src="https://3218748546-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F-MiW42YxFsGXIDjQJKNR%2Fuploads%2FARYrbEr6i6QTsHRrrdpp%2Fimage.png?alt=media&amp;token=73d5b335-5405-4c1a-aab4-443f67c4914a" alt="" data-size="original"> |
### Delete Crew
It is possible to delete the crew and all the members of the crew when the supervisor or the owner of the crew clicks on Delete. If the user confirms the deletion by clicking on Delete button again, the application will delete the whole crew permanently.&#x20;
| <img src="https://3218748546-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F-MiW42YxFsGXIDjQJKNR%2Fuploads%2FJhg30kbdEnirljdn4BaT%2Fimage.png?alt=media&amp;token=928c86f3-c75a-4552-96fd-e59f883a91ec" alt="" data-size="original"> | <img src="https://3218748546-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F-MiW42YxFsGXIDjQJKNR%2Fuploads%2FLVVHybkA8ToYpcMYHmET%2Fimage.png?alt=media&amp;token=1e233d24-c211-48e4-9cf3-2273a4ce2f0b" alt="" data-size="original"> |
GET https://docs.novacura.com/marketplace-documentation/applications/explore-apps/ifs/worksite-field-reporting/documentation/ifs-cloud/crew-management.md?ask=<question>&goal=<endgoal>
