> For the complete documentation index, see [llms.txt](https://docs.novacura.com/marketplace-documentation/llms.txt). Markdown versions of documentation pages are available by appending `.md` to page URLs; this page is available as [Markdown](https://docs.novacura.com/marketplace-documentation/applications/explore-apps/ifs/warehouse-management/documentation/ifs-cloud/warehouse-handling/start-transport-task.md).
# Start Transport Task
This flow (app) can be used to start a transport task for a given Transport Task ID.
<figure><img src="https://3218748546-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F-MiW42YxFsGXIDjQJKNR%2Fuploads%2F5kuNR4T28afDPGK2CviP%2FStart%20Transport%20Task%20Cloud.png?alt=media&amp;token=6d5cbe89-1358-43b2-b531-1280c2192459" alt=""><figcaption></figcaption></figure>
{% file src="/files/Xp5jbTdr0Qh8gNWsLFGJ" %}
### Enter Transport Task ID
* Transport Task ID is required.
* Entered Transport Task ID is validated against transport task lines. Hence the Transport Task should have at least one task line,
  * &#x20;In *’Created’* or *’Picked’* state.
  * From Site is set to user’s default site.
  * If the line has HU connected then the Outermost Handling Unit ID is not null.
* Click on the **List** button to see a list of Transport Tasks that satisfy the above conditions.
| <img src="https://3218748546-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F-MiW42YxFsGXIDjQJKNR%2Fuploads%2F26VJkbQxK8iLGr84V2Hr%2Fimage.png?alt=media&amp;token=6d9c6380-984b-4b96-9b79-acaa147e7ec7" alt="" data-size="original"> | <img src="https://3218748546-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F-MiW42YxFsGXIDjQJKNR%2Fuploads%2FJntluiFkQG45NLAuDjsY%2FPicture91.jpg?alt=media&amp;token=f0218e42-d4de-4c88-9eb7-15d000ed6b08" alt="" data-size="original"> |
### Enter Task Line No
* Select a Task Line to start processing.
* After a Task Line is processed the flow will loop back to this step to start with another line. This will continue until no lines are left to process for the given Transport Task. However, you can choose to exit the process at any time.
Based on the selected Task Line user will be prompted with additional user steps. If the line is handling unit connected then it will start [Process Handling Unit on Transport Task](/marketplace-documentation/applications/explore-apps/ifs/warehouse-management/documentation/ifs-cloud/warehouse-handling/process-handling-unit-on-transport-task.md) flow, otherwise it will start the [Process Part on Transport Task](/marketplace-documentation/applications/explore-apps/ifs/warehouse-management/documentation/ifs-cloud/warehouse-handling/process-part-on-transport-task.md) flow.
| <img src="https://3218748546-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F-MiW42YxFsGXIDjQJKNR%2Fuploads%2F8DmWEIGrm9RFxbe5zaXI%2Fimage.png?alt=media&amp;token=1a76cded-92f1-467c-b3ab-cb3ebbcc90da" alt="" data-size="original"> | <img src="https://3218748546-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F-MiW42YxFsGXIDjQJKNR%2Fuploads%2FEguP8WaewogFmBblX9Np%2FPicture92.jpg?alt=media&amp;token=93d65441-6c2e-4260-93d5-63f8d8b9c334" alt="" data-size="original"> |
GET https://docs.novacura.com/marketplace-documentation/applications/explore-apps/ifs/warehouse-management/documentation/ifs-cloud/warehouse-handling/start-transport-task.md?ask=<question>&goal=<endgoal>
