> For the complete documentation index, see [llms.txt](https://docs.novacura.com/marketplace-documentation/llms.txt). Markdown versions of documentation pages are available by appending `.md` to page URLs; this page is available as [Markdown](https://docs.novacura.com/marketplace-documentation/applications/explore-apps/ifs/warehouse-management/documentation/ifs-cloud/handling-unit-management/modify-handling-unit.md).
# Modify Handling Unit
This flow (app) can be used to modify a handling unit configuration which either connected or not connected to a shipment.
<div align="left"><figure><img src="https://3218748546-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F-MiW42YxFsGXIDjQJKNR%2Fuploads%2FZvKrKjk2UbwNmWeJ3i11%2FModify%20Handling%20Unit.png?alt=media&amp;token=fa1b507c-f29d-466b-9eca-7d2ddfa889c1" alt=""><figcaption></figcaption></figure></div>
{% file src="/files/f09Ht1a3w3sojX9XEU97" %}
### Enter Shipment ID
* Shipment ID is not mandatory. Any shipment belonging to the user default site can be entered
* Click on the **List** button to see a list of shipments connected to the user default site
| <img src="https://3218748546-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F-MiW42YxFsGXIDjQJKNR%2Fuploads%2FviSAWhQv2KIpD0EYZNj2%2Fimage.png?alt=media&amp;token=d76ecc9d-00aa-4de3-bf6e-0124cb1d1b3b" alt="" data-size="original"> | <img src="https://3218748546-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F-MiW42YxFsGXIDjQJKNR%2Fuploads%2FeYnbnnflcOpvamhhfx8h%2Fspaces_-MiW42YxFsGXIDjQJKNR_uploads_9nEf1xNgRIjW4OLFYHI0_Picture2.webp?alt=media&amp;token=3a8d4428-1a18-4a06-a419-9d5434ce5fe2" alt="" data-size="original"> |
### Enter Handling Unit ID
* Enter the Handling Unit ID to be modified. The site of the handling unit should be either empty or the same as the user default site
* If the Shipment ID is entered in the previous step, handling unit Shipment ID should match the same
* Click on the **List** button to see a list of Handling Units that satisfy the above conditions
| <img src="https://3218748546-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F-MiW42YxFsGXIDjQJKNR%2Fuploads%2FXOG6ZZRGisCVAg87sSoZ%2Fimage.png?alt=media&amp;token=47fea525-c36e-4ba1-a1a3-b17c877fa270" alt="" data-size="original"> | <img src="https://3218748546-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F-MiW42YxFsGXIDjQJKNR%2Fuploads%2F3jwUyerEqmriSxbTFfut%2Fspaces_-MiW42YxFsGXIDjQJKNR_uploads_c3MW0xzL8UckWEzWbehb_Picture3.webp?alt=media&amp;token=ccb997a3-5503-47f1-ac16-754d8da120f4" alt="" data-size="original"> |
### Enter Width/Height/Depth
These steps are optional.
| <img src="https://3218748546-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F-MiW42YxFsGXIDjQJKNR%2Fuploads%2FurcmiiFiSOXhk4WJyslt%2Fimage.png?alt=media&amp;token=4fb208b0-8725-4ed2-9eb3-3d0d03b61550" alt="" data-size="original"> | <img src="https://3218748546-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F-MiW42YxFsGXIDjQJKNR%2Fuploads%2FsrHXqsQvY9sno7UTH9eD%2Fspaces_-MiW42YxFsGXIDjQJKNR_uploads_j3TEpfjadKA28AT4xKR6_Picture4.webp?alt=media&amp;token=c7c09f7c-a41e-4937-8edc-6ce43857a05a" alt="" data-size="original"> |
| <img src="https://3218748546-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F-MiW42YxFsGXIDjQJKNR%2Fuploads%2FpbMR4x6xJw5SBRJMTU2S%2Fimage.png?alt=media&amp;token=19f11293-687a-4a9f-b3e9-4a6d8894bdb6" alt="" data-size="original"> | <img src="https://3218748546-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F-MiW42YxFsGXIDjQJKNR%2Fuploads%2FBwdasb4yrAvaoTuHcVgG%2Fspaces_-MiW42YxFsGXIDjQJKNR_uploads_FWNMqfdiwA4LrnibTfEZ_Picture5.webp?alt=media&amp;token=738acff2-6322-43b1-8714-6de41791ef2c" alt="" data-size="original"> |
| <img src="https://3218748546-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F-MiW42YxFsGXIDjQJKNR%2Fuploads%2FnCTbMP2JIdxgk9g5huD0%2Fimage.png?alt=media&amp;token=534e83f6-dcc8-4c22-8829-987d18178c59" alt="" data-size="original"> | <img src="https://3218748546-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F-MiW42YxFsGXIDjQJKNR%2Fuploads%2FxWxk2Z9r7q2ftoCLvbOR%2Fspaces_-MiW42YxFsGXIDjQJKNR_uploads_O4fsmeY9PTugIz6Zj4MQ_Picture6.webp?alt=media&amp;token=c1ba4d1b-b47b-44e1-910e-3cc6258790bd" alt="" data-size="original"> |
### Enter Gross Weight/Volume
|     | ![](https://3218748546-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F-MiW42YxFsGXIDjQJKNR%2Fuploads%2F2NqAuQIncXzbx5VMBg8u%2FPicture7.png?alt=media\&token=6eb59de0-f4dd-4a6e-abfb-25c8e415b0fc)![](https://3218748546-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F-MiW42YxFsGXIDjQJKNR%2Fuploads%2FCkqD4xLPrVPqbhrf3sQA%2FPicture8.png?alt=media\&token=a6327c6f-b1a1-4444-a508-0252a6cced2f) |
|     | Flow Classic        |
### Check Generate SSCC
* This step is shown only if the selected Handling Unit’s Type is SSCC generation enabled
Check box selection is optional.
|     | ![](https://3218748546-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F-MiW42YxFsGXIDjQJKNR%2Fuploads%2FVm7QNKc6ZROUdkZ9tagz%2FPicture9.png?alt=media\&token=7712fc57-dd27-4b05-9de6-315fed62aedf) |
|     | Flow Classic        |
### Enter SSCC
* This step is optional and will be shown only if Generate SSCC option is **Not** used
|     | ![](https://3218748546-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F-MiW42YxFsGXIDjQJKNR%2Fuploads%2FxbBsqQkM3LT01W84LE5B%2FPicture10.png?alt=media\&token=7a316439-0d2e-47a1-8980-b2da112ae27b) |
|     | Flow Classic        |
### Enter Alt Handling Unit Label
This step is optional.
|   | ![](https://3218748546-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F-MiW42YxFsGXIDjQJKNR%2Fuploads%2FSsxIvt0dpXsQwmt4NvNU%2FPicture11.png?alt=media\&token=24d90a59-97fb-49f1-aa89-db9bde37ecfb) |
|   |        Flow Classic        |
### Print Handling Unit Label
|     | ![](https://3218748546-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F-MiW42YxFsGXIDjQJKNR%2Fuploads%2FfqxeajFJjRZkDtBv3g6I%2FPicture12.png?alt=media\&token=76056c42-963c-4228-9d1b-f831dbbf2f70) |
|     | Flow Classic        |
### Print Content Label
|     | ![](https://3218748546-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F-MiW42YxFsGXIDjQJKNR%2Fuploads%2FnIp7Vr1BYesjyhXdXwgj%2FPicture13.png?alt=media\&token=7952333f-9892-4468-82e3-1f9c0d446ba8) |
|     | Flow Classic        |
### Print Shipment Label
* This step is optional and is shown only if a Shipment ID is entered in the first step
|     | ![](https://3218748546-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F-MiW42YxFsGXIDjQJKNR%2Fuploads%2FyQpXtq1HqGWbCcuKyuRh%2FPicture14.png?alt=media\&token=3308d7bd-3219-4961-8908-c2506557890a) |
|     | Flow Classic        |
### Summary
* Summary step. Click on the **Save** button to save the updated Handling Unit
| ![](https://3218748546-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F-MiW42YxFsGXIDjQJKNR%2Fuploads%2FtYsGkICSOIUJwcqSlqYF%2FPicture19_wf.png?alt=media\&token=fcb10b38-8146-48d7-8a9d-9fb6c7b4945b) |
GET https://docs.novacura.com/marketplace-documentation/applications/explore-apps/ifs/warehouse-management/documentation/ifs-cloud/handling-unit-management/modify-handling-unit.md?ask=<question>&goal=<endgoal>
