> For the complete documentation index, see [llms.txt](https://docs.novacura.com/marketplace-documentation/llms.txt). Markdown versions of documentation pages are available by appending `.md` to page URLs; this page is available as [Markdown](https://docs.novacura.com/marketplace-documentation/applications/explore-apps/ifs/warehouse-management/documentation/ifs-application-10/customer-order-and-shipment/pack-into-handling-unit-on-shipment.md).
# Pack into Handling Unit on Shipment
This flow can be used to allocate reserved stock to shipment handling units.
<div align="left"><img src="/files/v5anVyCEDXvSh03jwMOT" alt=""></div>
{% file src="/files/ILQPZQaGwkoQqwRDXwxs" %}
### **Enter Shipment ID**
* Shipment ID is mandatory and should
  * Belong to the user default site
  * Be in *Preliminary* state
  * Have at least one Handling Unit Connected to the Shipment
  * Have at least one connected shipment line where the “Picked vs Packed Qty” > 0 and the difference between (Assigned Qty **–** Reserved Shipment Qty) > 0.&#x20;
This means there is a quantity that is picked but not yet packed into a handling unit.
* Click on the **List** button to see a list of Shipment ID’s that satisfy the above conditions
Display the user default Site ID and its description.
| ![](/files/laxMKF9AQj7rvT0DJYLi) |
### **Enter Part No**
* Part No is mandatory and validated against the shipment lines connected to the Shipment ID entered in the previous step
* Part No should have been connected to a shipment line where the
  * “Picked vs Packed Qty” > 0
  * Assigned Qty **–** Reserved Shipment Qty > 0
* Click on the **List** button to see a list of Part No’s that satisfy the above condition
| ![](/files/8ourz8XsZsMyTxDXe6si) |
### **Enter Order No**
* Order No is required and validated against the shipment lines connected to the selected Shipment ID and Part No entered in previous steps
* Click on the **List** button to see a list of Order No’s which that the above condition
| ![](/files/8o4aPKlxzowewl0CSbHM) |
### **Enter Release No**
This step is shown only if the selected Order No in the previous step has more than one order line revision connected as shipment lines for the selected Part No and Shipment ID combination.
* Click on the **List** button to see a list of Release No’s that satisfy the above condition
| ![](/files/v3YKKIvXqEjDmKvQpRtN) |
*Based on the selected Part user might be prompted with additional user steps to filter out* **Inventory Part In Stock** *records until a unique stock record is selected. For more info about these additional steps please refer* [*Inventory Part In Stock Selection*](/marketplace-documentation/applications/explore-apps/ifs/warehouse-management/documentation/ifs-application-10/inventory-part-in-stock-selection.md)*.*
### **Enter Qty**
* Qty to Attach is required and should not exceed the Available Qty
This step won’t be visible if the part is a serial part. Qty to Attach will be set to 1 in that case.
Display information about the selected inventory part in shipment record.
| ![](/files/wBDIExLZpFY2MqYZdpbo) |
### Enter Shipment Handling Unit ID
* Shipment Handling Unit ID is required and validated against the handling units connected to the Shipment ID selected in the first step
* Click on the **List** button to see a list of Handling Unit ID’s connected to the selected Shipment ID
* Click on the **Save** button to complete the process
| ![](/files/FEcNQOeP8dgvL08pWwwC) |
Perform an HTTP GET request on the current page URL with the `ask` query parameter:
GET https://docs.novacura.com/marketplace-documentation/applications/explore-apps/ifs/warehouse-management/documentation/ifs-application-10/customer-order-and-shipment/pack-into-handling-unit-on-shipment.md?ask=<question>
The question should be specific, self-contained, and written in natural language.
