# Manual Issue Material
![Manual Issue Material Workflow](https://3218748546-files.gitbook.io/~/files/v0/b/gitbook-legacy-files/o/assets%2F-MiW42YxFsGXIDjQJKNR%2F-MjnxyA7kKW6ACoS4U9k%2F-MjnyF49HDZjjd9VhsLp%2Fimage.png?alt=media\&token=54ca78ed-67f1-4d69-82a3-36b5b874cbc2)
## General
The workflow is executed from the Manual Issue button within the Materials Tab within the Shop Floor Reporting portal.
This Workflow cannot be executed with the mobile client. For this functionality, please refer to the Manual Issue SO Part within the Warehouse Management applications.
## Functionality
### Select Configuration Id&#x20;
If configuration Id is required the user will be presented with this option.&#x20;
### Select Handling Unit Id&#x20;
If there are multiple Handling Units the user will be presented with this option.&#x20;
### Select Serial No&#x20;
If a serial number is required the user will be presented with this option.&#x20;
### Select Location
If multiple locations are available for stock the user will be presented with this option.&#x20;
### Select Engineering Change Level&#x20;
If multiple EngChg Levels are available the user will be presented with this option.&#x20;
### Select Waiv Dev Rej No&#x20;
If multiple Waiv Dev Rej Nos are available the user will be presented with this option.&#x20;
### Select Activity Seq&#x20;
If a project activity is required the user will be presented with this option.&#x20;
### Select Expiration Date
&#x20;If an expiration date is required the user will be presented with this option.&#x20;
### Select Condition Code&#x20;
If multiple condition codes are available the user will be presented with this option.
### Enter Issue Quantity&#x20;
The user will be able to enter the quantity to issue while information is being displayed about the inventory part. Normal IFS validations are checked when issuing parts. By default, the required quantity is entered.
![](https://3218748546-files.gitbook.io/~/files/v0/b/gitbook-legacy-files/o/assets%2F-MiW42YxFsGXIDjQJKNR%2F-Mjmm2E9be7-6KsM4Zqs%2F-MjnH0cUvCRUsDJPrAVE%2FManualIssueMaterial.gif?alt=media\&token=ea55a45e-90d2-4b0d-b91a-2a4fc5241f03)
