Approve Expenses
Overview
This workflow can be used to approve or reject expense sheets.
Approve Expenses Inbox
  • All expenses in status Confirmed that the user has access to according to the HR position structure will be visible
  • Code to only show direct subordinates can be enabled in the inbox query
Flow Connect
Flow Classic
Review Expense Details
  • Review expense details
  • Approve or Reject expenses
  • Review attached document with receipts in pinned user step
Flow Connect
Flow Classic
Approve Expense
  • Approve will change the expense sheet status to Approved
Reject Expense
  • If an expense is rejected the status will be changed to Preliminary
  • The document connected to the Expense Sheet header with receipts will be deleted
  • The user have the option to send an rejection email to the employee attached to the expense sheet
    • The email address is fetched from "Person/Communication Method" in IFS Cloud or you can manually set the email
    • Add a message to the employee with reason for the rejection
Flow Connect
Flow Classic
