> For the complete documentation index, see [llms.txt](https://docs.novacura.com/marketplace-documentation/llms.txt). Markdown versions of documentation pages are available by appending `.md` to page URLs; this page is available as [Markdown](https://docs.novacura.com/marketplace-documentation/applications/explore-apps/ifs/warehouse-management/documentation/ifs-application-10/handling-unit-management/create-handling-unit.md).
# Create Handling Unit
This flow (app) can be used to create one or more handling units connected or not connected to a shipment.
![](https://3218748546-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F-MiW42YxFsGXIDjQJKNR%2Fuploads%2Fkoko9VwDDhJAG4sDz2w4%2FPicture205_wf.png?alt=media\&token=63678428-bc77-41a6-b4d5-6de392a727e5)
{% file src="/files/MaIYhQZDKiRgXSJ0EoL0" %}
### Enter Shipment ID
* Shipment ID is not mandatory. Any shipment in Status ‘Preliminary’ belonging to user default site can be entered
* Click on the **List** button to see a list of available shipments which satisfy the above condition
| <img src="https://3218748546-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F-MiW42YxFsGXIDjQJKNR%2Fuploads%2F5BZ2LdXyPReM4Symyt5v%2Fimage.png?alt=media&amp;token=6de94336-8dbf-4450-aba8-2d7329445b97" alt="" data-size="original"> | <img src="https://3218748546-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F-MiW42YxFsGXIDjQJKNR%2Fuploads%2FKxO3nYcPGCYJDJvenTgs%2Fspaces_-MiW42YxFsGXIDjQJKNR_uploads_a0bxIQgPLcNJjVwDwIeL_Picture207s.webp?alt=media&amp;token=dcb80f86-523b-4447-86bf-eeb297e7793f" alt="" data-size="original"> |
### Enter Handling Unit Type
* Handling Unit Type is mandatory, and any Handling Unit Type can be entered
* Click on the **List** button to see a list of available Handling Unit Types
| <img src="https://3218748546-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F-MiW42YxFsGXIDjQJKNR%2Fuploads%2FYfl5vA2OWkW7dQ0yUnhX%2Fimage.png?alt=media&amp;token=0da35f97-b92f-46b8-b2fd-1d07e68360a5" alt="" data-size="original"> | <img src="https://3218748546-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F-MiW42YxFsGXIDjQJKNR%2Fuploads%2FTN5Yx5ii431nYXIYY7oF%2Fspaces_-MiW42YxFsGXIDjQJKNR_uploads_x1n8LD4IeIFbjQ57UaTO_Picture208s.webp?alt=media&amp;token=4379c473-ecbe-4085-a62b-e02fba83573f" alt="" data-size="original"> |
### Enter Parent Handling Unit
* Parent Handling Unit is not mandatory. The handling units allowed to be connected as a Parent should satisfy two conditions
  * The site of the handling unit should be either empty or the same as the user default site
  * If the Shipment ID is entered in the previous step, handling unit Shipment ID should match the same
* Click on the **List** button to see the list of Handling Units that satisfy the above conditions
| <img src="https://3218748546-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F-MiW42YxFsGXIDjQJKNR%2Fuploads%2F8VbvWuWMRm74vwxwG9co%2Fimage.png?alt=media&amp;token=714854c7-af4c-4ed9-a929-81781a12bd20" alt="" data-size="original"> | <img src="https://3218748546-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F-MiW42YxFsGXIDjQJKNR%2Fuploads%2FmaS8qIb1x4m5ZJgF8uvy%2Fspaces_-MiW42YxFsGXIDjQJKNR_uploads_WGvv9oeZJ2CrQZkxYmZH_Picture209_2s.webp?alt=media&amp;token=8775f2d0-945a-4479-9480-13c906611e93" alt="" data-size="original"> |
### Enter No of Units
* This will create several handling units with the given configuration
Default is set to 1.
|     | <img src="https://3218748546-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F-MiW42YxFsGXIDjQJKNR%2Fuploads%2FqKVRqexDIZCGnJ6fAo01%2Fimage.png?alt=media&amp;token=80b78e59-9bf0-4d89-8388-aee8e452de26" alt="" data-size="original"> |
|     |        Flow Classic        |
### Check Generate SSCC
* This step is shown only if the selected Handling Unit Type is SSCC generation enabled
Check box selection is optional.
|     | <img src="https://3218748546-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F-MiW42YxFsGXIDjQJKNR%2Fuploads%2FzDxMWsWNjpemHYjyD43p%2Fimage.png?alt=media&amp;token=59286c64-1914-4da6-9f89-e35c2459cfa5" alt="" data-size="original"> |
|     |        Flow Classic        |
### Enter Alt Handling Unit Label ID
This step is optional.
|     | <img src="https://3218748546-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F-MiW42YxFsGXIDjQJKNR%2Fuploads%2FYvrHK1IozuL2wjRnkdon%2Fimage.png?alt=media&amp;token=22c5cd3c-bf99-41a7-8320-61fa01b315d0" alt="" data-size="original"> |
|     |        Flow Classic        |
### Print Handling Unit Label
|     | <img src="https://3218748546-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F-MiW42YxFsGXIDjQJKNR%2Fuploads%2FwdmEtL5UKDj2YmMeEiiJ%2Fimage.png?alt=media&amp;token=10f4ba21-753d-4e47-9968-4482692a5095" alt="" data-size="original"> |
|     |        Flow Classic        |
### Print Shipment Label
This step is optional and only shown if a Shipment ID is entered in the first step.
|     | <img src="https://3218748546-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F-MiW42YxFsGXIDjQJKNR%2Fuploads%2FNvFOoQB50ofK0LdTL8my%2Fimage.png?alt=media&amp;token=6bbf9770-d582-4777-b2e9-884e410157aa" alt="" data-size="original"> |
|     |        Flow Classic        |
### Summary
* Summary of all the steps performed. Click on the **Save** button to create the Handling Unit
|     | <img src="https://3218748546-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F-MiW42YxFsGXIDjQJKNR%2Fuploads%2FweeUlL4f0UknDpW6f4Pb%2Fimage.png?alt=media&amp;token=e2feb170-000a-4860-982c-c0e044aae9ae" alt="" data-size="original"> |
|     |        Flow Classic        |
GET https://docs.novacura.com/marketplace-documentation/applications/explore-apps/ifs/warehouse-management/documentation/ifs-application-10/handling-unit-management/create-handling-unit.md?ask=<question>&goal=<endgoal>
