> For the complete documentation index, see [llms.txt](https://docs.novacura.com/marketplace-documentation/llms.txt). Markdown versions of documentation pages are available by appending `.md` to page URLs; this page is available as [Markdown](https://docs.novacura.com/marketplace-documentation/applications/explore-apps/ifs/warehouse-management/documentation/ifs-application-10/customer-order-and-shipment/reassign-handling-unit-on-shipment.md).
# Reassign Handling Unit on Shipment
This flow(app) can be used to reassign a handling unit from one shipment to another new or an existing shipment on the user’s default site.
<div align="left"><img src="https://3218748546-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F-MiW42YxFsGXIDjQJKNR%2Fuploads%2FBJoSRvOEYcwJ0hWIXi9S%2FReassign%20Handling%20Unit%20on%20Shipment_wf.png?alt=media&amp;token=50ab4cf0-eb64-4ccb-b86c-854fd960b8c6" alt=""></div>
{% file src="/files/AV2XFcOf0G6yeeXEqA5u" %}
### **Enter Handling Unit ID**
* Handling Unit ID is mandatory and should be assigned to a shipment
* The handling unit assigned shipment should satisfy the following conditions:
  * Belong to the user’s default site
  * Should be in “*Preliminary”* or *“Completed”* state
  * Not delivered yet
* Click on the **List** button to see a list of handling units that satisfy the above conditions
Display the user default Site ID and its description.
| <img src="https://3218748546-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F-MiW42YxFsGXIDjQJKNR%2Fuploads%2FSeZwtFcYaRVAkdl5ohAg%2Fimage.png?alt=media&amp;token=0293dfeb-046b-4aa8-ad29-5b81b18471d6" alt="" data-size="original"> | ![](https://3218748546-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F-MiW42YxFsGXIDjQJKNR%2Fuploads%2FISNcVunlrCTWPv2sRvdX%2FPicture339.png?alt=media\&token=4994733b-1457-44e2-8d13-966fcd9a46b7) |
### **New Shipment**
* Select if you want to assign the handling unit to an existing shipment or create a new shipment
* If you choose the latter the flow will create a new shipment and assign the handling unit to it
The new shipment will get the following values from the current shipment:&#x20;
* receiver ID&#x20;
* receiver address
* ship-via
* delivery terms
* shipment type
* planned ship date
* planned delivery date
* forwarder
* rout
| <img src="https://3218748546-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F-MiW42YxFsGXIDjQJKNR%2Fuploads%2F54ypsLckHpI7LuXmooAk%2Fimage.png?alt=media&amp;token=e6565a5c-3857-4ad8-9fc1-1933892d3e7b" alt="" data-size="original"> | ![](https://3218748546-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F-MiW42YxFsGXIDjQJKNR%2Fuploads%2Fbh5coBhVQlFh7ndulq3T%2FPicture340.png?alt=media\&token=7051b673-b15f-48a7-b927-63725856e435) |
### **Enter To Shipment ID**
* To Shipment ID is mandatory and only shown if you select “Reassign to Existing Shipment” in the previous step
* To Shipment ID should have the same receiver ID, receiver address, ship-via, delivery terms, and shipment type as the From Shipment ID
* Click on the **List** button to see a list of shipments that satisfy the above condition
| <img src="https://3218748546-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F-MiW42YxFsGXIDjQJKNR%2Fuploads%2FfbQ3rdZAorj0Gk8neArb%2Fimage.png?alt=media&amp;token=d2f3a414-caa4-4591-b2d7-68673117d56e" alt="" data-size="original"> | ![](https://3218748546-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F-MiW42YxFsGXIDjQJKNR%2Fuploads%2FkLpVcLnsGlKYZ0cOcr80%2FPicture341.png?alt=media\&token=d5476910-d0b3-4843-9dac-ca27b3e659dc) |
### **Summary**
* With the Release Reservation check-box, you can choose to release the reservations attached to the handling unit or to reassign them to the destination shipment
* If the parts are picked and placed in the shipment inventory they will always be reassigned to the destination shipment
* Click on the **Save** button to complete the process
| <img src="https://3218748546-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F-MiW42YxFsGXIDjQJKNR%2Fuploads%2FY8GQL1aWZI54d9ZtmnvD%2Fimage.png?alt=media&amp;token=4629d8b6-cefc-46dd-8d47-5fdafb61db2a" alt="" data-size="original"> | ![](https://3218748546-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F-MiW42YxFsGXIDjQJKNR%2Fuploads%2F3RXpcUt9JThjLowcZVUJ%2FPicture342.png?alt=media\&token=df7b2feb-5aca-45ab-92ae-62978517a0f8) |
GET https://docs.novacura.com/marketplace-documentation/applications/explore-apps/ifs/warehouse-management/documentation/ifs-application-10/customer-order-and-shipment/reassign-handling-unit-on-shipment.md?ask=<question>&goal=<endgoal>
