# Receive By-Products
## General
This workflow enables the user to receive by-products of a shop order into inventory. It is possible to receive single-handled or lot-handled parts defined in IFS Applications. User can also receive multiple by-products repetitively in a single user flow, changing different warehouse/stock attributes as required.
This user workflow is available within the Shop Order Operations portlet and is also available to be executed from the web and mobile clients.
## Functionality
### Prerequisite
* The selected Operation should be connected to at least one By-Product.
* &#x20;The shop order must at least have the Released status.
### Receive By-Products
* Populate By-Products in the By-Product sub-tab in the Portal connected to a Shop Order Operation.
* Select one of the By-Product and start the user flow - Receive By-Product.
* Enter/Edit Quantity to Receive (defaulted to suggested value) and Location to be received                (If the part is lot tracked, the user is enabled with Lot/Batch column to enter a lot No).
* Enter Additional Miscellaneous stock information in the next step.
* Thereafter, the user is allowed to either complete the receipt or continue receiving the remaining by-products.
![](https://3218748546-files.gitbook.io/~/files/v0/b/gitbook-legacy-files/o/assets%2F-MiW42YxFsGXIDjQJKNR%2F-MkaIXJZ7pDw4I3S5ICr%2F-MkaIa3WfX0LMvoAL6kE%2FReceive-ByProduct.gif?alt=media\&token=b400002e-3849-43b8-a1c7-df48af063ff6)
