> For the complete documentation index, see [llms.txt](https://docs.novacura.com/marketplace-documentation/llms.txt). Markdown versions of documentation pages are available by appending `.md` to page URLs; this page is available as [Markdown](https://docs.novacura.com/marketplace-documentation/applications/explore-apps/ifs/warehouse-management/documentation/ifs-application-10/customer-order-and-shipment/unpack-from-handling-unit-on-shipment.md).
# Unpack from Handling Unit on Shipment
This flow(app) can be used to unattach parts from shipment-connected handling units.
<div align="left"><img src="https://3218748546-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F-MiW42YxFsGXIDjQJKNR%2Fuploads%2F3CbeIQgax5bAMJAVVNeK%2FUnpack%20from%20Handling%20Unit%20on%20Shipment_wf.png?alt=media&amp;token=ea56f3b4-5ddd-4d8e-bd3c-d130fba40274" alt=""></div>
{% file src="/files/7GbO0Uzghyo3AfukdDC7" %}
### **Enter Shipment ID**
* Shipment ID is mandatory and shoul&#x64;**:**
  * Belong to the user default site
  * Have at least one “Attached Shipment Reservation” line with Attached Qty > 0 under the Shipment
* Click on the **List** button to see a list of Shipment ID’s that satisfy the above conditions
Display the user default Site ID and its description.
| <img src="https://3218748546-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F-MiW42YxFsGXIDjQJKNR%2Fuploads%2FaLpVbzBr5pMabaiY2FdV%2Fimage.png?alt=media&amp;token=da5bc4eb-94c2-47e5-aa88-9abeb779f43d" alt="" data-size="original"> | <img src="https://3218748546-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F-MiW42YxFsGXIDjQJKNR%2Fuploads%2FQN5PlLkOeXUDoq41fQNW%2Fimage.png?alt=media&amp;token=be481a3e-05f9-4ae3-b0cc-a5d4f20ede92" alt="" data-size="original"> |
### **Enter Handling Unit ID**
* Handling Unit ID is mandatory and should be connected to the Shipment ID entered in the previous step
* Click on the **List** button to see a list of Handling Unit ID’s that satisfy the above condition
| <img src="https://3218748546-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F-MiW42YxFsGXIDjQJKNR%2Fuploads%2Fd5ydWyOYzG06AJiUXsyx%2Fimage.png?alt=media&amp;token=a0939315-7770-434c-ac22-7991663abcf5" alt="" data-size="original"> | <img src="https://3218748546-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F-MiW42YxFsGXIDjQJKNR%2Fuploads%2FuG4mkbD8HBXCR5h0dp2t%2Fimage.png?alt=media&amp;token=c9e8f305-d0e2-4080-a78e-f75ed8b7b34b" alt="" data-size="original"> |
### **Enter Part No**
* Part No is mandatory and should be attached to the Handling Unit ID entered in the previous step
* Attached Qty > 0
* Click on the **List** button to see a list of Part No’s that satisfy the above condition
| <img src="https://3218748546-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F-MiW42YxFsGXIDjQJKNR%2Fuploads%2FB6Vbr4hh3S8Q2p1ZPLe0%2Fimage.png?alt=media&amp;token=848b3f35-0451-44a7-b37d-7b8ad1734a32" alt="" data-size="original"> | <img src="https://3218748546-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F-MiW42YxFsGXIDjQJKNR%2Fuploads%2Fsxopc3gek2lCFgRHeUsR%2Fimage.png?alt=media&amp;token=dc126c30-5c66-4d17-beae-c3f7c73172fe" alt="" data-size="original"> |
### **Enter Order No**
* Order No is required and validated against the Shipment ID, Handling Unit ID and Part No entered in the previous steps
* Click on the **List** button to see a list of Order No’s which that the above condition
| <img src="https://3218748546-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F-MiW42YxFsGXIDjQJKNR%2Fuploads%2FAfMQUSO0kpxxIbjzk1V1%2Fimage.png?alt=media&amp;token=e432d3d4-36ca-44c6-a61e-f9c696a6745f" alt="" data-size="original"> | <img src="https://3218748546-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F-MiW42YxFsGXIDjQJKNR%2Fuploads%2FGn6yI6bHaVnjEMSvGBFa%2Fimage.png?alt=media&amp;token=83c91263-4537-4ce8-a432-ca61fa0d00a3" alt="" data-size="original"> |
### **Enter Release No**
This step is shown only if the selected Order No in the previous step has more than one order line revision connected as shipment line for the selected Shipment ID, Handling Unit ID & Part No combination.
* Click on the **List** button to see a list of Release No’s that satisfy the above condition
| <img src="https://3218748546-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F-MiW42YxFsGXIDjQJKNR%2Fuploads%2Fob3NyqhllREYXfFQvGts%2Fimage.png?alt=media&amp;token=da307f7e-87f4-44d7-9dc4-1cab6d39136f" alt="" data-size="original"> | <img src="https://3218748546-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F-MiW42YxFsGXIDjQJKNR%2Fuploads%2FRWw2qd3XdpvYM4DAsTHP%2Fimage.png?alt=media&amp;token=0e41bd8d-f4d1-4680-b1aa-943e205738f0" alt="" data-size="original"> |
*Based on the selected Part user might be prompted with additional user steps to filter out* **Inventory Part In Stock** *records until a unique stock record is selected. For more info about these additional steps please refer* [*Inventory Part In Stock Selection*](/marketplace-documentation/applications/explore-apps/ifs/warehouse-management/documentation/ifs-application-10/inventory-part-in-stock-selection.md)*.*
### **Enter Qty**
* Qty to Unattach is required and should not exceed the Qty Attached
This step won’t be visible if the part is a serial part. Qty to Unattach will be set to 1 in that case.
Display information about the selected “Attached Shipment Reservations” record under the Shipment.
| <img src="https://3218748546-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F-MiW42YxFsGXIDjQJKNR%2Fuploads%2FqR8JEzGiHv5SNzk7aLST%2Fimage.png?alt=media&amp;token=e8ccb605-84d7-4f69-975d-088741f8bb5e" alt="" data-size="original"> | <img src="https://3218748546-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F-MiW42YxFsGXIDjQJKNR%2Fuploads%2FYA2NyrpiJHrrfdGvA2PB%2Fimage.png?alt=media&amp;token=e08637d9-e756-4618-b69f-9d3981b617aa" alt="" data-size="original"> |
### **Summary**
* Click on the **Save** button to complete the process
|     | <img src="https://3218748546-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F-MiW42YxFsGXIDjQJKNR%2Fuploads%2FbXaV6l7hO3qHSjeVYDVX%2Fimage.png?alt=media&amp;token=3f6ab06f-7d8f-439b-8227-3b04f046500f" alt="" data-size="original"> |
|     |        Flow Classic        |
GET https://docs.novacura.com/marketplace-documentation/applications/explore-apps/ifs/warehouse-management/documentation/ifs-application-10/customer-order-and-shipment/unpack-from-handling-unit-on-shipment.md?ask=<question>&goal=<endgoal>
