> For the complete documentation index, see [llms.txt](https://docs.novacura.com/marketplace-documentation/llms.txt). Markdown versions of documentation pages are available by appending `.md` to page URLs; this page is available as [Markdown](https://docs.novacura.com/marketplace-documentation/applications/explore-apps/ifs/warehouse-management/documentation/ifs-application-10/warehouse-handling/count-handling-unit-per-count-report.md).
# Count Handling Unit Per Count Report
This flow is used to update the count for a Handling Unit using a count report.
![](https://3218748546-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F-MiW42YxFsGXIDjQJKNR%2Fuploads%2FqoWGleFEnKYx0O7rXYnF%2FCount%20HU%20per%20Count%20Report.png?alt=media\&token=8fd886b8-fc6b-4784-8907-c9e2c19021dd)
{% file src="/files/fgf5Qwyr4Hb7XvcbvXmF" %}
### Enter Count Report
* Count Report No is required.
* Click on the **List** button to see a list of count reports.
| <img src="https://3218748546-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F-MiW42YxFsGXIDjQJKNR%2Fuploads%2F0hl1yL5qx2OjU7LVV89c%2Fimage.png?alt=media&amp;token=7a63d69a-da4d-477f-a07f-6fa1780258ee" alt="" data-size="original"> | <p><img src="https://3218748546-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F-MiW42YxFsGXIDjQJKNR%2Fuploads%2Fk7jdUNHBVP06oAMS7Da0%2Fimage.png?alt=media&amp;token=7406de4a-5fb2-4803-b1f0-a1e95752b9cb" alt=""><br></p> |
### Enter Handling Unit&#x20;
* Handling Unit ID is required and should be included in the count report entered in the previous step.
* Click on the **List** button to see a list of handling units.
| <img src="https://3218748546-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F-MiW42YxFsGXIDjQJKNR%2Fuploads%2FxCr9xECHAfgN3YnuYTXw%2Fimage.png?alt=media&amp;token=93c8335f-5859-4b1b-a15e-bec2ebee676e" alt="" data-size="original"> | <p><img src="https://3218748546-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F-MiW42YxFsGXIDjQJKNR%2Fuploads%2FBJwMQ03QOoWUPytDispZ%2Fimage.png?alt=media&amp;token=34daefa6-1101-4b69-a0f0-814324a719ce" alt=""><br></p> |
### Select Action
* Choose an action for handling unit count report and options are,
  * **Exists** - Confirm the on-hand quantity of all the stock records attached to the handling unit.
  * **Does not Exist** - Count stock records attached to the handling unit to zero.
  * **Count Sublevel** - Continue the count with the next handling unit in the structure.
  * **Count Part** - Continue the count at the part level allowing the user to update the individual Part count by executing the [Count Inventory Part Per Count Report](/marketplace-documentation/applications/explore-apps/ifs/warehouse-management/documentation/ifs-application-10/warehouse-handling/count-inventory-part-per-count-report.md) Workflow.
* Displays instructions for each item in Action to Perform dropdown
| <img src="https://3218748546-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F-MiW42YxFsGXIDjQJKNR%2Fuploads%2F8KKkNPuAi9mGuTqF8Sp7%2Fimage.png?alt=media&amp;token=6cd685f6-a946-413a-99b9-0a115fc450b8" alt="" data-size="original"> | <p><img src="https://3218748546-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F-MiW42YxFsGXIDjQJKNR%2Fuploads%2FagBAHBd5blEKRVAvoXqd%2Fimage.png?alt=media&amp;token=9b8c6fad-7a55-4322-b85c-df5b2eb26d2b" alt=""><br></p> |
### Confirm for Count Exists/Does Not Exist
* This step is only visible when you select either **Exists** or **Does Not Exist** options in the previous step.
* Select **Yes** to confirm the count.
| <img src="https://3218748546-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F-MiW42YxFsGXIDjQJKNR%2Fuploads%2F1yZQ1WRz9f1uCLMwu40c%2Fimage.png?alt=media&amp;token=d7a9582f-7993-4d9e-bd34-2f64fbb4efff" alt="" data-size="original"> | <p><img src="https://3218748546-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F-MiW42YxFsGXIDjQJKNR%2Fuploads%2FsRtX7HBENn7NZtyfTkqK%2Fimage.png?alt=media&amp;token=5c8d75c8-fa60-4f30-9cde-4ac8909b02cb" alt=""><br></p> |
GET https://docs.novacura.com/marketplace-documentation/applications/explore-apps/ifs/warehouse-management/documentation/ifs-application-10/warehouse-handling/count-handling-unit-per-count-report.md?ask=<question>&goal=<endgoal>
