> For the complete documentation index, see [llms.txt](https://docs.novacura.com/marketplace-documentation/llms.txt). Markdown versions of documentation pages are available by appending `.md` to page URLs; this page is available as [Markdown](https://docs.novacura.com/marketplace-documentation/applications/explore-apps/ifs/warehouse-management/documentation/ifs-cloud/warehouse-handling/issue-material-requisition-line.md).
# Issue Material Requisition Line
This flow(app) can be used to issue a part for the material requisition line whether it had been reserved or not.
![](https://3218748546-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F-MiW42YxFsGXIDjQJKNR%2Fuploads%2FPBbJIpzUk83jqI47OVMg%2FIssue%20Material%20Requisition%20Line.png?alt=media\&token=bf3cbe13-1270-4e95-b951-41d6805fe860)
{% file src="/files/YBrDBxH5C4TxiueoQxyl" %}
### **Enter Order No**
* Material Requisition Order Number is required and should be in status **Released**, **Partially Delivered** or **Reserved**.
* Click on the **List** button to see a list of material requisitions that satisfy the above condition.
| <img src="https://3218748546-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F-MiW42YxFsGXIDjQJKNR%2Fuploads%2FngHxZTcglUdYzVIPWZwh%2Fimage.png?alt=media&amp;token=b4cac819-c7e9-4690-8c4b-c61564e8536c" alt="" data-size="original"> | <img src="https://3218748546-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F-MiW42YxFsGXIDjQJKNR%2Fuploads%2FKbZdKyA0YjyRckHJQEew%2Fimage.png?alt=media&amp;token=b61791b3-4997-4d4d-a610-2bcc82901248" alt="" data-size="original"> |
### **Enter Part No**
* Part No is required and should belong to the requisition entered in the previous step.
* Click on the **List** button to see a list of parts that satisfy the above condition.
| <img src="https://3218748546-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F-MiW42YxFsGXIDjQJKNR%2Fuploads%2FgzAzJJy2osO2639oSaGe%2Fimage.png?alt=media&amp;token=57c7180e-4399-4a28-9b5d-829374245a20" alt="" data-size="original"> | <img src="https://3218748546-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F-MiW42YxFsGXIDjQJKNR%2Fuploads%2F5oYg832pqvDgnmjiIz5X%2Fimage.png?alt=media&amp;token=30b898fc-9f3d-4112-93fa-7807eb113cd1" alt="" data-size="original"> |
### **Enter Release No**
* This step is shown only if the selected Order No in the previous step has more than one order line revision for selected Part No.
* Release No is required
* Click on the **List** button to see a list of Release No’s for the selected part.
|   | <img src="https://3218748546-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F-MiW42YxFsGXIDjQJKNR%2Fuploads%2F1kVGk3qbiZsVgNLQOdfc%2Fimage.png?alt=media&amp;token=2f2871a8-40e0-4726-8638-913065dbe388" alt="" data-size="original"> |
|   |        Flow Classic        |
*Based on the selected Part user might be prompted with additional user steps to filter out **Inventory Part In Stock** records until a unique stock record is selected. For more info about these additional steps please refer* [*Inventory Part In Stock Selection*](/marketplace-documentation/applications/explore-apps/ifs/warehouse-management/documentation/ifs-application-10/inventory-part-in-stock-selection.md)&#x20;
### **Enter Qty**
* Qty to Issue is required cannot be a negative number or higher than the required quantity.&#x20;
Display information about the selected ***Inventory Part In Stock*** record
|   | <img src="https://3218748546-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F-MiW42YxFsGXIDjQJKNR%2Fuploads%2FwVlEd4OnlNOcdEwW2sMv%2Fimage.png?alt=media&amp;token=d91a1a38-79ee-4b71-8042-75b8e2c89bbd" alt="" data-size="original"> |
|   |        Flow Classic        |
### **Choose the next step**
* Only shown if the order is partially issued.
* On this screen, you can choose from 3 options.
  * Menu - Exit the workflow(app).
  * Issue Another Part - Restart the whole process from the beginning.
  * Issue Same Part - Issue the same part but from a different source.
|   | ![](https://3218748546-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F-MiW42YxFsGXIDjQJKNR%2Fuploads%2FVdw2YCQA8YvLX54XyxOw%2FPicture119.png?alt=media\&token=6bc93b2f-b936-471b-aefb-212a94b83219) |
|   |        Flow Classic        |
GET https://docs.novacura.com/marketplace-documentation/applications/explore-apps/ifs/warehouse-management/documentation/ifs-cloud/warehouse-handling/issue-material-requisition-line.md?ask=<question>&goal=<endgoal>
