> For the complete documentation index, see [llms.txt](https://docs.novacura.com/marketplace-documentation/llms.txt). Markdown versions of documentation pages are available by appending `.md` to page URLs; this page is available as [Markdown](https://docs.novacura.com/marketplace-documentation/applications/explore-apps/ifs/warehouse-management/documentation/ifs-cloud/handling-unit-management/create-handling-unit.md).
# Create Handling Unit
This flow (app) can be used to create one or more handling units connected or not connected to a shipment.
<div align="left"><figure><img src="https://3218748546-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F-MiW42YxFsGXIDjQJKNR%2Fuploads%2Fxa4Mdxurb1LnSSFwrxIx%2FCreate%20Handling%20Unit.png?alt=media&amp;token=04be3efc-8629-4fd1-8e25-a7783b5d166b" alt=""><figcaption></figcaption></figure></div>
{% file src="/files/1jTSjtTbHgu0rQQOSJag" %}
### Enter Shipment ID
* Shipment ID is not mandatory. Any shipment in Status ‘Preliminary’ belonging to user default site can be entered
* Click on the **List** button to see a list of available shipments which satisfy the above condition
| <img src="https://3218748546-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F-MiW42YxFsGXIDjQJKNR%2Fuploads%2FaHWUFrLtI6GO9J5wbGfH%2Fimage.png?alt=media&amp;token=dc06d12a-6006-4334-8e84-0bf8d8b4ac28" alt="" data-size="original"> | <img src="https://3218748546-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F-MiW42YxFsGXIDjQJKNR%2Fuploads%2FirEtEbpBlz6a8GH5Io1e%2Fspaces_-MiW42YxFsGXIDjQJKNR_uploads_a0bxIQgPLcNJjVwDwIeL_Picture207s.webp?alt=media&amp;token=98f83212-507d-4d23-9d13-92e13d525e6c" alt="" data-size="original"> |
### Enter Handling Unit Type
* Handling Unit Type is mandatory, and any Handling Unit Type can be entered
* Click on the **List** button to see a list of available Handling Unit Types
| <img src="https://3218748546-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F-MiW42YxFsGXIDjQJKNR%2Fuploads%2F7s7hhMBf2b51LBSKUYv4%2Fimage.png?alt=media&amp;token=bcc319e6-08dd-4538-bd2a-08ee68ab5047" alt="" data-size="original"> | <img src="https://3218748546-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F-MiW42YxFsGXIDjQJKNR%2Fuploads%2Fr0DUzu5fpNGcgUMt03se%2Fspaces_-MiW42YxFsGXIDjQJKNR_uploads_x1n8LD4IeIFbjQ57UaTO_Picture208s.webp?alt=media&amp;token=e7760802-20b0-4b33-b876-60d663019728" alt="" data-size="original"> |
### Enter Parent Handling Unit
* Parent Handling Unit is not mandatory. The handling units allowed to be connected as a Parent should satisfy two conditions
  * The site of the handling unit should be either empty or the same as the user default site
  * If the Shipment ID is entered in the previous step, handling unit Shipment ID should match the same
* Click on the **List** button to see the list of Handling Units that satisfy the above conditions
| <img src="https://3218748546-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F-MiW42YxFsGXIDjQJKNR%2Fuploads%2FtVwnONNEnVSvsO7cOd5O%2Fimage.png?alt=media&amp;token=1f2fe4d5-9a0b-4222-9b04-fe1da3320361" alt="" data-size="original"> | <img src="https://3218748546-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F-MiW42YxFsGXIDjQJKNR%2Fuploads%2FzGbUVqifTx8MM62wUcWF%2Fspaces_-MiW42YxFsGXIDjQJKNR_uploads_WGvv9oeZJ2CrQZkxYmZH_Picture209_2s.webp?alt=media&amp;token=5afa05d2-b920-4f73-8f0a-b6cfcf56ba57" alt="" data-size="original"> |
### Enter No of Units
* This will create several handling units with the given configuration
Default is set to 1.
|   | ![](https://3218748546-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F-MiW42YxFsGXIDjQJKNR%2Fuploads%2FaewM91IuvPbhz2o0zcjY%2FPicture210s.png?alt=media\&token=7404334f-4f16-43df-ad30-50ca8ba36758) |
|   |        Flow Classic        |
### Check Generate SSCC
* This step is shown only if the selected Handling Unit Type is SSCC generation enabled
Check box selection is optional.
|   | ![](https://3218748546-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F-MiW42YxFsGXIDjQJKNR%2Fuploads%2FtxVAOiIhZv6dxx9XFGTA%2FPicture211s.png?alt=media\&token=7ddbe026-0271-42ee-ab9d-be0be7691921) |
|   |        Flow Classic        |
### Enter Alt Handling Unit Label ID
This step is optional.
|   | ![](https://3218748546-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F-MiW42YxFsGXIDjQJKNR%2Fuploads%2FXcInN5ASsYDUi8IO3ZBH%2FPicture212_2s.png?alt=media\&token=c54862bd-396e-4f3b-87db-ab774161982c) |
|   |        Flow Classic        |
### Print Handling Unit Label
|   | ![](https://3218748546-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F-MiW42YxFsGXIDjQJKNR%2Fuploads%2Fp5rUSjCD4nmS0gbbMADO%2FPicture213_2s.png?alt=media\&token=2eebbac0-3184-4eee-982a-306b92ae8b13) |
|   |        Flow Classic        |
### Print Shipment Label
This step is optional and only shown if a Shipment ID is entered in the first step.
|   | ![](https://3218748546-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F-MiW42YxFsGXIDjQJKNR%2Fuploads%2F6zuntN59faWqRjjATVBA%2FPicture214_2s.png?alt=media\&token=1bce5235-14a6-4cf3-b8f3-330f4b68f1c8) |
|   |        Flow Classic        |
### Summary
* Summary of all the steps performed. Click on the **Save** button to create the Handling Unit
|     | ![](https://3218748546-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F-MiW42YxFsGXIDjQJKNR%2Fuploads%2Fk9rcfgIYpXtN20hlXkWK%2FPicture215_2s.png?alt=media\&token=a0336cba-7bb6-4b93-8ba1-253db050a922) |
|     | Flow Classic        |
GET https://docs.novacura.com/marketplace-documentation/applications/explore-apps/ifs/warehouse-management/documentation/ifs-cloud/handling-unit-management/create-handling-unit.md?ask=<question>&goal=<user_goal>
