> For the complete documentation index, see [llms.txt](https://docs.novacura.com/marketplace-documentation/llms.txt). Markdown versions of documentation pages are available by appending `.md` to page URLs; this page is available as [Markdown](https://docs.novacura.com/marketplace-documentation/applications/explore-apps/ifs/warehouse-management/documentation/ifs-application-10/handling-unit-management/modify-handling-unit.md).
# Modify Handling Unit
This flow (app) can be used to modify a handling unit configuration which either connected or not connected to a shipment.
![](https://3218748546-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F-MiW42YxFsGXIDjQJKNR%2Fuploads%2F4mU1tlA60s7LQxXtuJ0S%2FModify%20Handling%20Unit_wf.png?alt=media\&token=d6b70423-11d8-46d5-9f5a-859b75dc1e3e)
{% file src="/files/sLLyJKHRprpbuin1Y8i7" %}
### Enter Shipment ID
* Shipment ID is not mandatory. Any shipment belonging to the user default site can be entered
* Click on the **List** button to see a list of shipments connected to the user default site
| <img src="https://3218748546-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F-MiW42YxFsGXIDjQJKNR%2Fuploads%2Favx9xDXLxQhgK4Jo6hd1%2Fimage.png?alt=media&amp;token=520c9147-2ae2-44b5-bf28-fdadf96058a8" alt="" data-size="original"> | <img src="https://3218748546-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F-MiW42YxFsGXIDjQJKNR%2Fuploads%2FuOZ3Lw6sCAuCyKqhBPE8%2Fspaces_-MiW42YxFsGXIDjQJKNR_uploads_9nEf1xNgRIjW4OLFYHI0_Picture2.webp?alt=media&amp;token=7a382119-465a-4fe4-bb7a-846a4710cffb" alt="" data-size="original"> |
### Enter Handling Unit ID
* Enter the Handling Unit ID to be modified. The site of the handling unit should be either empty or the same as the user default site
* If the Shipment ID is entered in the previous step, handling unit Shipment ID should match the same
* Click on the **List** button to see a list of Handling Units that satisfy the above conditions
| <img src="https://3218748546-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F-MiW42YxFsGXIDjQJKNR%2Fuploads%2FeAoqskxv9mMQTz96Cc0o%2Fimage.png?alt=media&amp;token=bdeed0f4-af31-45a5-a506-21eaed57bc43" alt="" data-size="original"> | <img src="https://3218748546-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F-MiW42YxFsGXIDjQJKNR%2Fuploads%2FqVPMdB8AFiVTZnjdjhbe%2Fspaces_-MiW42YxFsGXIDjQJKNR_uploads_c3MW0xzL8UckWEzWbehb_Picture3.webp?alt=media&amp;token=f2ada99c-d4ca-49be-9a55-1b7d10a6f453" alt="" data-size="original"> |
### Enter Width/Height/Depth
These steps are optional.
| <img src="https://3218748546-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F-MiW42YxFsGXIDjQJKNR%2Fuploads%2FOI6HHql6U9TgvgWi3D5X%2Fimage.png?alt=media&amp;token=a139e39a-9f33-44de-81cb-ae08c65fe70c" alt="" data-size="original"> | <img src="https://3218748546-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F-MiW42YxFsGXIDjQJKNR%2Fuploads%2FQi4KqaSUbQZAZj6pIm8l%2Fspaces_-MiW42YxFsGXIDjQJKNR_uploads_j3TEpfjadKA28AT4xKR6_Picture4.webp?alt=media&amp;token=351ed6ff-56bb-4958-9829-d194f0610db0" alt="" data-size="original"> |
| <img src="https://3218748546-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F-MiW42YxFsGXIDjQJKNR%2Fuploads%2F605PeqJwrETdE0HafTp9%2Fimage.png?alt=media&amp;token=53a50ae3-8b25-40dd-82f9-956800a44416" alt="" data-size="original"> | <img src="https://3218748546-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F-MiW42YxFsGXIDjQJKNR%2Fuploads%2FV5o7yCpLj7FYBWq5Z3Pp%2Fspaces_-MiW42YxFsGXIDjQJKNR_uploads_FWNMqfdiwA4LrnibTfEZ_Picture5.webp?alt=media&amp;token=175810d7-17d5-4a14-829f-e4905bb83f69" alt="" data-size="original"> |
| <img src="https://3218748546-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F-MiW42YxFsGXIDjQJKNR%2Fuploads%2F58dPAknd6hJ1KPRHuFpk%2Fimage.png?alt=media&amp;token=b49bdadc-c036-4577-977a-b2ece1c4b92b" alt="" data-size="original"> | <img src="https://3218748546-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F-MiW42YxFsGXIDjQJKNR%2Fuploads%2FIQvPTNoD26L4bRRQui0m%2Fspaces_-MiW42YxFsGXIDjQJKNR_uploads_O4fsmeY9PTugIz6Zj4MQ_Picture6.webp?alt=media&amp;token=d3fd5824-4bf7-448b-a835-83c9436dfeea" alt="" data-size="original"> |
### Enter Gross Weight/Volume
|     | <img src="https://3218748546-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F-MiW42YxFsGXIDjQJKNR%2Fuploads%2FBnyOzRjsEAf43DukvPbc%2Fimage.png?alt=media&amp;token=fdb574d4-c84b-4181-b416-9a1df96532e8" alt="" data-size="original">![](https://3218748546-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F-MiW42YxFsGXIDjQJKNR%2Fuploads%2FKFvEMV36EQS6fc5OIVaJ%2Fimage.png?alt=media\&token=d7e004a6-6ccb-49a7-aaac-68f7f8258d57) |
|     |        Flow Classic        |
### Check Generate SSCC
* This step is shown only if the selected Handling Unit’s Type is SSCC generation enabled
Check box selection is optional.
|     | <img src="https://3218748546-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F-MiW42YxFsGXIDjQJKNR%2Fuploads%2FtnkiSxs76E2I0qmMqQbX%2Fimage.png?alt=media&amp;token=02f61d69-e044-4e6e-a504-9fc79c7ecca9" alt="" data-size="original"> |
|     |        Flow Classic        |
### Enter SSCC
* This step is optional and will be shown only if Generate SSCC option is **Not** used
|     | <img src="https://3218748546-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F-MiW42YxFsGXIDjQJKNR%2Fuploads%2FrDBkQK16F8e6GSwAA0Ov%2Fimage.png?alt=media&amp;token=dd8fb3cc-6eea-4214-bf99-485bc3bc1257" alt="" data-size="original"> |
|     |        Flow Classic        |
### Enter Alt Handling Unit Label
This step is optional.
|     | <img src="https://3218748546-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F-MiW42YxFsGXIDjQJKNR%2Fuploads%2FcFQyJNc0iv6ddJrl04lg%2Fimage.png?alt=media&amp;token=81c0e5d7-374f-4283-b5b7-ae88d9a40146" alt="" data-size="original"> |
|     |        Flow Classic        |
### Print Handling Unit Label
|     | <img src="https://3218748546-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F-MiW42YxFsGXIDjQJKNR%2Fuploads%2FM8pmX4o6BJbotsG0FUlH%2Fimage.png?alt=media&amp;token=5e3e4c96-389a-4ffa-82d9-8021fae0ab5e" alt="" data-size="original"> |
|     |        Flow Classic        |
### Print Content Label
|     | <img src="https://3218748546-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F-MiW42YxFsGXIDjQJKNR%2Fuploads%2FB0VDQXJhsPjv180jfzY3%2Fimage.png?alt=media&amp;token=17a0902f-08b2-4653-99c5-f53a541fa91b" alt="" data-size="original"> |
|     |        Flow Classic        |
### Print Shipment Label
* This step is optional and is shown only if a Shipment ID is entered in the first step
|     | <img src="https://3218748546-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F-MiW42YxFsGXIDjQJKNR%2Fuploads%2FX8Xyg9AXUGs6UJAL1wDD%2Fimage.png?alt=media&amp;token=7858671d-baa5-45ad-b022-853081200942" alt="" data-size="original"> |
|     |        Flow Classic        |
### Summary
* Summary step. Click on the **Save** button to save the updated Handling Unit
|     | <img src="https://3218748546-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F-MiW42YxFsGXIDjQJKNR%2Fuploads%2FAYBZhOF5Cq3iRGMt4XfU%2Fimage.png?alt=media&amp;token=6ae44e10-2d0f-43aa-94de-d0fa4800e1b5" alt="" data-size="original"> |
|     |        Flow Classic        |
GET https://docs.novacura.com/marketplace-documentation/applications/explore-apps/ifs/warehouse-management/documentation/ifs-application-10/handling-unit-management/modify-handling-unit.md?ask=<question>&goal=<endgoal>
