Connector agents
Connector Agents enable secure, reliable communication between your on-premises systems and Novacura Cloud. They act as lightweight, self-managed services that allow you to seamlessly access data and services hosted behind firewalls—without exposing your internal infrastructure to the public internet.
Once installed within customer premise, a Connector Agent establishes outbound-only connections over secure channels to Novacura Cloud. This approach simplifies deployment—there’s no need to open inbound firewall ports or configure VPNs.
Communication Requirements
The agent supports two outbound communication protocols: AMQP over TCP and AMQP over WebSockets (HTTPS). If no protocol is explicitly configured, the agent defaults to AMQP over WebSockets.
Required Ports
HTTPS
443
Default option
AMQP over TCP
AMQP
5671
To enable AMQP over TCP, add the following entry to the appSettings.json file located in the agent’s installation directory after completing the installation.
"TransportSettings": { "TransportType": "AmqpTcp"}
Connectors
Depending on the configured connectors in the Hub, additional outbound access may be required.
Email connector
SMTP
587
TLS
SMTP
465
SSL
Database connectors
SQL Server
1433
Default SQL server port
Oracle
1521
Default Oracle listener port
Make sure your firewall allows outbound access to the services and ports used by the configured connectors.
Next steps: Installing a Connector Agent
To get started with Connector Agents,
