> For the complete documentation index, see [llms.txt](https://docs.novacura.com/flow-connect/llms.txt). Markdown versions of documentation pages are available by appending `.md` to page URLs; this page is available as [Markdown](https://docs.novacura.com/flow-connect/reference/how-to-guides/create-user-step-controls/image-selection-input.md). Agents can also search and read this documentation through its [MCP server](https://docs.novacura.com/flow-connect/~gitbook/mcp).
# Image selection input
This guide will take you through how to set up an Image selection input.
## Prerequisite data
No connectors will be used in this example, but data from table steps will be utilized. Please download the file below; it will be used to import into the required table steps
{% file src="/files/RcjC9R9lDz406R3n2PLg" %}
## Add a data grid
   2. Add a Table step.
   3. Open the Table step and select **Import File**.
   4. Choose the semicolon separator and click **OK**.
   5. Select the "Image selection.csv" file downloaded in the prerequisite section above.
   6. Set the table variable name to "Articles" and click **OK**.
   7. Change the step name to "Articles". It's good practice to name steps after their content.
   8. Right-click on the "Articles" step, select **Add data arrow**, and connect it to the User step created in step 1.
<figure><img src="https://1716064794-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FIIgl6sNaTky0iALxYWHH%2Fuploads%2F8vrpDnAHW4S4qnrzTqx7%2Flist%20seletion.png?alt=media&amp;token=b3ac8b0e-af8f-4d59-9c3d-9b7b2b015216" alt=""><figcaption></figcaption></figure>
2. Open the User step.
   1. Add an Image Selection Input.&#x20;
   2. In the Target Variable, write "Article".
   3. In the Data Source, in the Table Variable, choose the table "Articles".
   4. In the Prompt, write "Choose an article".&#x20;
   5. In the Item Text, write "{Name}".
   6. In the Image Source, write "{Picture}".
   7. Check the "Allow Multiple Selections" checkbox.&#x20;
3. Click the **Play** button in the top right-hand corner to run the application in diagnostic mode.
<figure><img src="https://1716064794-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FIIgl6sNaTky0iALxYWHH%2Fuploads%2FZ803YZuiaxyEYJR3RkgO%2FPicture1.png?alt=media&amp;token=500fbe0d-79bd-442c-9eee-654cdeb8cb66" alt=""><figcaption><p>The grid shows all articles, with picture and name. </p></figcaption></figure>
2. Condition to hide&#x20;
<figure><img src="https://1716064794-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FIIgl6sNaTky0iALxYWHH%2Fuploads%2F30JbA6gLpdXaMHuSOvLR%2FWith%20border.png?alt=media&amp;token=589bec14-8458-499f-ac8b-73b3da8387ab" alt=""><figcaption><p>The articles are now hidden since the condition is fulfilled.</p></figcaption></figure>
GET https://docs.novacura.com/flow-connect/reference/how-to-guides/create-user-step-controls/image-selection-input.md?ask=<question>&goal=<user_goal>
