> For the complete documentation index, see [llms.txt](https://docs.novacura.com/flow-connect/llms.txt). Markdown versions of documentation pages are available by appending `.md` to page URLs; this page is available as [Markdown](https://docs.novacura.com/flow-connect/working-with-connect/create-and-design.md).
# Create and design
- [Application packages](https://docs.novacura.com/flow-connect/working-with-connect/create-and-design/application-packages.md): All applications are groped into application packages, similar to folders in the file system.  Packages contains applications, components, permissions and more.
- [Package content view](https://docs.novacura.com/flow-connect/working-with-connect/create-and-design/application-packages/package-content-view.md)
- [Applications](https://docs.novacura.com/flow-connect/working-with-connect/create-and-design/applications.md)
- [Create](https://docs.novacura.com/flow-connect/working-with-connect/create-and-design/applications/create.md): You create, delete and edit metadata for applications in the Hub. The application logic is developed in Flow Designer.
- [Design](https://docs.novacura.com/flow-connect/working-with-connect/create-and-design/applications/design.md)
- [Test](https://docs.novacura.com/flow-connect/working-with-connect/create-and-design/applications/test.md)
- [Commit](https://docs.novacura.com/flow-connect/working-with-connect/create-and-design/applications/commit.md)
- [Portal Pages](https://docs.novacura.com/flow-connect/working-with-connect/create-and-design/portal-pages.md)
- [Create Portal Page](https://docs.novacura.com/flow-connect/working-with-connect/create-and-design/portal-pages/create-portal-page.md)
- [Design Portal Page](https://docs.novacura.com/flow-connect/working-with-connect/create-and-design/portal-pages/design-portal-page.md)
- [Commit Portal Page](https://docs.novacura.com/flow-connect/working-with-connect/create-and-design/portal-pages/commit-portal-page.md)
- [Components](https://docs.novacura.com/flow-connect/working-with-connect/create-and-design/components.md)
- [Create component](https://docs.novacura.com/flow-connect/working-with-connect/create-and-design/components/create-component.md)
- [Manage component](https://docs.novacura.com/flow-connect/working-with-connect/create-and-design/components/manage-component.md)
- [Modules](https://docs.novacura.com/flow-connect/working-with-connect/create-and-design/modules.md)
- [Create module](https://docs.novacura.com/flow-connect/working-with-connect/create-and-design/modules/create-module.md)
- [Manage module](https://docs.novacura.com/flow-connect/working-with-connect/create-and-design/modules/manage-module.md)
- [Phrasebooks](https://docs.novacura.com/flow-connect/working-with-connect/create-and-design/phrasebooks.md)
- [Automations](https://docs.novacura.com/flow-connect/working-with-connect/create-and-design/automations.md)
- [Functionality](https://docs.novacura.com/flow-connect/working-with-connect/create-and-design/automations/functionality.md)
- [Create Automation](https://docs.novacura.com/flow-connect/working-with-connect/create-and-design/automations/create-automation.md)
- [Manage Automation](https://docs.novacura.com/flow-connect/working-with-connect/create-and-design/automations/manage-automation.md)
- [Creating Access Key](https://docs.novacura.com/flow-connect/working-with-connect/create-and-design/automations/creating-access-key.md)
- [Executing Automations Externally](https://docs.novacura.com/flow-connect/working-with-connect/create-and-design/automations/executing-automations-externally.md)
- [IFS Cloud](https://docs.novacura.com/flow-connect/working-with-connect/create-and-design/automations/executing-automations-externally/ifs-cloud.md)
- [Salesforce Apex Trigger Example](https://docs.novacura.com/flow-connect/working-with-connect/create-and-design/automations/executing-automations-externally/salesforce-apex-trigger-example.md)
- [CloudEvents JSON Support](https://docs.novacura.com/flow-connect/working-with-connect/create-and-design/automations/executing-automations-externally/cloudevents-json-support.md)
GET https://docs.novacura.com/flow-connect/working-with-connect/create-and-design.md?ask=<question>&goal=<user_goal>
