> For the complete documentation index, see [llms.txt](https://docs.novacura.com/flow-connect/llms.txt). Markdown versions of documentation pages are available by appending `.md` to page URLs; this page is available as [Markdown](https://docs.novacura.com/flow-connect/reference/how-to-guides/create-user-step-controls/numeric-input.md). Agents can also search and read this documentation through its [MCP server](https://docs.novacura.com/flow-connect/~gitbook/mcp).
# Numeric input
This guide will take you through how to set up a numeric input.
## Add a numeric input
   2. Add a Numeric input.&#x20;
   3. In the Target Variable, write "price".
   4. Under Appearance, in Prompt, write "Enter a price".
   5. In Default Text, write "100".
   6. Click the **Play** button in the top right-hand corner to run the application in diagnostic mode.
   <figure><img src="https://1716064794-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FIIgl6sNaTky0iALxYWHH%2Fuploads%2F5vbdFZ39RJ6F5RVIPTE6%2FNumeric%20input.png?alt=media&amp;token=03660b69-ff1b-4995-a8af-9eb3391dfb6a" alt=""><figcaption><p>The way the app is set up, it won't allow the user to leave the value empty. We therefore have a default value. If you want the user to not be able to move forward without writing a value of their own, remove the default value.</p></figcaption></figure>
2. Go back to the Designer.
   <figure><img src="https://1716064794-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FIIgl6sNaTky0iALxYWHH%2Fuploads%2FoHGixRKhz7mCgFwRtmor%2FWith%20border.png?alt=media&amp;token=fabf8a31-f25e-4599-9864-41bbd0010540" alt=""><figcaption><p>The image is now hidden since the condition is fulfilled.</p></figcaption></figure>
GET https://docs.novacura.com/flow-connect/reference/how-to-guides/create-user-step-controls/numeric-input.md?ask=<question>&goal=<user_goal>
