> For the complete documentation index, see [llms.txt](https://docs.novacura.com/flow-connect/llms.txt). Markdown versions of documentation pages are available by appending `.md` to page URLs; this page is available as [Markdown](https://docs.novacura.com/flow-connect/this-is-flow-connect/whats-new/change-log.md).
# Change log
## 2026-11-11
Agent version : 1.0.0.1617\
Agent manager version: 1.0.0.621
Change: Agent  and Agent manager have been updated to the .NET 10.0.15 security servicing release (remediates CVE-2026-114149 and related CVEs).&#x20;
## 2026-11-10
#### CloudEvents JSON support for Automation webhooks
Automation webhooks now accept authenticated CloudEvents 1.0 structured JSON requests. The complete event, including nested `data`, is available as typed component input. Existing JSON and XML requests and the `x-api-key` requirement are unchanged. CloudEvents binary mode is not supported.
[Learn more about CloudEvents JSON support](https://docs.novacura.com/flow-connect/working-with-connect/create-and-design/automations/executing-automations-externally/cloudevents-json-support).
## 2026-11-06
### Connector Agent v1.0.0.1610
This release improves concurrent command processing and includes security and maintenance updates for the Connector Agent and its bundled connectors.
#### **Improved concurrent execution handling**
Fixed an issue where concurrent executions of the same machine step could use input parameters from another execution. This could result in incorrect data being returned or updated, or an operation being performed using the wrong user context.
Each execution now uses the correct input parameters and user context.
#### **Security and maintenance updates**
The Connector Agent and its bundled connectors have been rebuilt with updated .NET runtime components to address the Brotli compression vulnerability and include the latest security servicing.
Updated connectors include:
* Database connectors
* REST Connector
* Mail Connector
* File system and file transfer connectors
* NiceLabel Connector
* Infor M3 Socket Connector
* OPC UA Connector
* PowerShell Connector
No connector functionality or API changes were introduced as part of these maintenance updates.
#### Mail Connector - OAuth2 authentication for SMTP and Reply-To configuration
The Mail connector now supports OAuth2 authentication for SMTP, including Microsoft 365 and Exchange Online. It uses the client credentials flow, so it runs without user interaction. Access tokens are cached and renewed automatically before they expire. Authentication and token failures are reported with the cause.&#x20;
The configuration also allows a default Reply-To address, which can be overridden in the Designer machine step. Existing basic-auth configurations continue to work.
### Connector Agent Manager v1.0.0.618
Connector Agent Manager has been rebuilt using updated .NET components to include the latest security servicing, including the fix for the Brotli compression vulnerability.
No functionality or user-interface changes were introduced in this release.
## 2026-11-04
### Fixes in Clients&#x20;
* Resolve a race condition when utilizing wedge keyboard scanners.
* Resolve an issue with the menu selection selected state when utilized with dependency.
* **Behavior change:** Changed behavior for text and numeric fields at the end of a user step when other controls depend on their value. Scanning or quickly pressing Enter now waits for dependent controls to update, preventing newly revealed required fields from being skipped. In these cases, users must advance to the next step manually.
## 2026-11-02
### Fixes in Web and Windows clients
* Fixed an issue where a workflow could advance before the full barcode value was captured when using a scanner that enters data as keyboard input (a wedge scanner).
* Fixed a visual issue where grid rows could flicker while editing values.
## 2026-10-29
#### Fixes in Clients
All Clients
* General performance and stability improvements
Web and Windows Clients
* Fixed an issue regarding scanner settings not applying directly
* Fixed an issue where a hidden Inbox search filter stayed active after completing a task, making the inbox appear empty
## 2026-10-28
#### New in Portal
**Access overlapping map markers**
Markers at the same location can now spread out in a flower-shaped arrangement, making it possible to select individual markers and view their details even when several work tasks share the same position.
**Simpler Custom Content editing**
Create Custom Content using one HTML document and one CSS stylesheet instead of separate sections. Repeat parts of the content for each data row, and expand both editors into a larger workspace. Existing section-based configurations are converted automatically to the new format.
Existing portlets are converted automatically to the new format, preserving their appearance and behaviour. Previous sections are combined into one HTML document in their original order, with dynamic sections converted to repeat blocks. The converted configuration is only stored when you explicitly save; the original section-based configuration is retained for recovery.
**Page settings in one place**
Manage a page’s name, translations and visibility in navigation from the **Page Settings** dialog. The option to delete the page is now also available in this dialog.
General improvements to the navigator and New portlet.
#### Fixes in Portal
* General performance improvements.
* Fixed an issue where checkboxes could not be edited when adding a new row in the Table portlet.
### Connector Agent v1.0.0.1587 & Connector Agent Manager v1.0.0.607
#### HTTP and HTTPS proxy support
Connector Agent Manager now supports communication with Novacura cloud services through your organization’s configured HTTP or HTTPS proxy.
* Supports agent registration, authentication, cloud messaging, file transfers, and agent updates through the proxy.
* New Connector Agents automatically inherit the proxy settings during installation.
* Proxy settings are configured using the new `CloudProxy` section in `appsettings.json`.
**Important:** Existing Connector Agents must be configured individually, even after upgrading. Proxy settings for connections to business systems remain unchanged.
### REST Connector
#### Automatic decompression of REST responses
The REST Connector now automatically decompresses responses that use:\
`Content-Encoding: deflate`.
Previously, compressed responses could return a successful HTTP status (200 OK), but the response body would contain unreadable data.
With this improvement, **the REST Connector automatically decompresses the response**, making the data readable and ready to use without additional manual transformations.
## 2026-10-19
#### New in Portal
Create Custom Content using one HTML document and one CSS stylesheet instead of separate sections. Repeat parts of the content for each data row, and expand both editors into a larger workspace. FlowScript continues to work as before. Existing section-based configurations are converted automatically to the new format, preserving their appearance and behaviour.
Navigator and Add new portlet UI have been improved.&#x20;
## 2026-10-19
### Connector Agent v1.0.0.1564
Fixed an issue in the M3 connector where an empty response from M3 incorrectly resulted in a single empty record being returned
## 2026-10-15
### Connector Agent v1.0.0.1561
This release introduces the new PowerShell Connector, performance improvements for IFS 10, and enhanced diagnostics and fixes for the Infor M3 Socket Connector.
#### New: PowerShell Connector
The new **PowerShell Connector** enables you to execute pre-registered and pre-approved PowerShell scripts directly from workflows.
Pass Flow variables as script parameters and return structured results to your workflow, enabling automation of system operations, file handling, integration tasks and performing custom operations that are not covered by existing connectors.
[Read more about the PowerShell Connector](https://docs.novacura.com/flow-connect/working-with-connect/connect-to-systems/connectors/powershell)
#### Other Connector Improvements
**IFS 10 Connector**
* **Improved performance** — IFS 10 steps now execute faster by reusing secure connections through a dedicated local proxy, reducing the overhead of establishing a new connection for each execution.
**Infor M3 Socket Connector**
* **Improved diagnostics** — Added more detailed execution diagnostics for M3 API calls, making it easier to identify and troubleshoot failed queries.
* **Dynamic output fields** — Fixed an issue where output fields were not returned when the `outputFields` attribute was assigned using a variable instead of a hardcoded value.
### Connector Agent Manager v1.0.0.598
* **Password-protected encryption key exports:** Exporting encryption keys now requires setting a password to protect the exported keys, preventing them from being exposed in clear text.
## 2026-10-14
#### Fix in Android
* Improved stability on Datalogic handheld scanners, including scanner recovery when returning to the app and handling temporary scanner errors without repeated attempts that could make the app unresponsive.
## 2026-10-12
The new built-in [DeviceSessionInfo ](/flow-connect/reference/reference/flowscript/walkthrough/devicesessioninfo-module.md)FlowScript module lets apps read live network status, environment and user details, client settings and versions, and work item sync status. Use this information to adapt app behaviour to the current connection and session, or show users work items waiting to sync.&#x20;
## 2026-10-09
#### All Clients
* Improved file upload reliability with automatic retries for temporary network and server errors.
* Fixed an issue that could delay exiting an app by up to 30 seconds without a network connection.
* General performance and stability improvements.
#### Android
* Fixed Bluetooth connection and reconnection issues with Zebra scanners.
* Added scan trigger support for Zebra RS-series wearable scanners.
## 2026-10-08
#### New in Portal
**Improved page navigation**
Organize related pages with overview pages that show links to subpages or open the first subpage directly. The new Subpages portlet lets you add links to a page’s subpages within your page layout. Pages can also be hidden from the navigator for drill-down scenarios, with a Back button to return to the previous page.
**Configurable header styling**
Customize portlet and container headers with size, bold text, background colour and title text colour. Stacked container tabs support a shared size and bold setting, making it easier to create a consistent page design.
**Inboxes in My Apps and Link portlets**
Access inbox tasks directly in the Portal through My Apps and Link portlets, with badges showing task counts. Configure My Apps to show apps, inboxes or both. Search, filter by date and sort tasks in the inbox dialog, then return to the list after completing a task.
## 2026-10-06
### Connector Agent v1.0.0.1535
Fixed an issue where REST connector requests using API Key authentication could return a 404 error when the API key was configured as a query parameter. The connector now correctly includes the API key in such requests.
## 2026-10-05
### **Fixes in Clients**
* Improved error messages for clearer information when something goes wrong.
* General stability and performance improvements.
### New Automation Overview in Flow Hub
We've introduced a dedicated **Automations** page in Flow Hub, making it easier than ever to get a complete overview of your organization's automations.
Previously, automations were managed within individual application packages, making it difficult to see which automations existed across the organization and where they were deployed. With the new Automations page, you can now **view and monitor all your automations in one centralized location**, without having to navigate through individual packages.
<figure><img src="https://1716064794-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FIIgl6sNaTky0iALxYWHH%2Fuploads%2Fu3FeEUpFHlevr8ocAgKh%2Fimage.png?alt=media&amp;token=879a4934-7bb4-40f3-bb46-bd56c6424636" alt=""><figcaption></figcaption></figure>
#### What's New?
**Centralized Automation Overview**
The new overview provides a clear view of all automations across your organization, including:
* **Component:** See which component each automation belongs to.
* **Deployment:** Identify where each automation is deployed.
* **Next Run:** See when each automation is scheduled to execute next.
* **Run Statistics:** Monitor total runs and failed runs.
You can also **filter by environment, package, and time interval**, making it easy to find specific automations and focus on relevant activity. From the overview, you can also navigate directly to failed runs, making it easier to identify and investigate issues.
**Run History**
Automation run history has moved from the Analytics section to the new Automations page. The functionality remains unchanged, but is now conveniently located alongside the automation overview.
**Access Key Management**
You can view and manage your automation access keys directly from the Automations page.
#### Why This Matters
You now have a much clearer picture of your organization's automation landscape. By bringing the automation overview, run history, and access key management together, Flow Hub makes it easier to **find, monitor, and manage automations across packages and environments** — all from one place.
## 2026-09-30
### Connector Agent v1.0.0.1513
This release includes runtime performance improvements and enhancements to OAuth2 authentication in the REST Connector.
#### Runtime performance improvements
Improved Connector Agent runtime performance through code-level optimizations.
#### OAuth2 authentication improvements
Alongside this Agent release, REST Connector version 1.0.108 introduces several OAuth2 authentication improvements :
* Added support for configuring additional token request parameters without exposing secrets in workflow steps.
* Added support for configuring a custom HTTP header for OAuth2 access tokens, for APIs that do not use the standard `Authorization` header.
* Made the client secret optional for ROPC token requests. When left empty, it is omitted from the request.
* Added the ability to configure the token request body format.
These improvements broaden OAuth2 compatibility with provider-specific requirements and simplify secure configuration by keeping credentials out of workflow steps.
## 2026-09-28
### New in Hub
#### **Manage environments**
You can now manage environments directly in the Hub under **Admin > Environments**:
* **Add environments** — create additional Test or Production environments, for example a separate QA environment.
* **Rename environments** — give environments names and descriptions that match your release process.
* **Reorder environments** — set the order in which environments are shown in the Hub, on the deployment screen and in the clients.
* **Delete environments** — remove Test or Production environments you no longer need.
Managing environments requires the new **Manage Environments** system permission. The permission has been added to the built-in **Organization Owners** group. For other admin groups, it is turned off by default and can be turned on in the group's system permissions.
See [Manage environments](/flow-connect/working-with-connect/deploy/environments/manage-environments.md) for details.
## 2026-09-24
#### Fixes on Android and iOS
* Improved network stability when switching between the Flow app and other applications.
## 2026-09-15
#### Connector Agent v1.0.0.1479
#### Fixes
* Fixed an issue in the IFS 10 Database Connector where database steps could stop working after an IFS-side execution error or after a long idle period. The connector could fail with `Error in FndApCommand.ExecuteNonQuery` and require the Flow Connect agent to be restarted.\
  The connector now handles invalid pooled IFS connections correctly and no longer attempts to open an interactive login dialog in headless agent environments. This improves reliability for IFS 10 configurations that use initialization or cleanup commands such as `Fnd_Session_Util_API`.
* M3 Socket connector responseLimit now supports more than 100 records.&#x20;
#### Portal
* General stability, performance, and maintenance improvements.
## 2026-09-14
**Fixes in Android**
* Fixed an issue where certain characters in a user's initials could cause the client to crash.
* Fixed issues that could prevent Zebra Bluetooth scanners from successfully connecting to the client.
## 2026-09-03
### Fixes in Client&#x20;
#### All Clients
* Improved FlowScript performance when using `concat`.
* Fixed an issue that could cause a crash when concatenating sequences in FlowScript.
* Added execution token reuse for machine step requests, reducing repeated authentication and improving response times.
* Added automatic retries for temporary network failures, waiting for connectivity to return before retrying.
* Fixed an issue where scanner or keyboard input could be processed during screen transitions.
* Fixed a runtime issue related to hyphen-minus Unicode characters.
#### Web and Windows Clients
* Fixed an issue where checkpoints triggered before the view started listening could be lost.
* Fixed an issue where signature input could continue after leaving the signature area.
#### iOS
* Fixed an issue where the Inbox title could be displayed too large.
## 2026-08-31
### Agent Manager v1.0.0.568
Added support for **distributed agents for Fow Connect Edge**, allowing Edge services and Edge agents to run on separate servers.&#x20;
When installing a new Edge agent, Agent Manager now saves the correct **Garnet connection string**.
This ensures newly installed Edge agents can connect successfully to the required **Edge services**.
## 2026-08-26
#### Fix in Portal
* Increased the maximum page navigator depth from 3 to 5 levels.
## 2026-08-24
### Connector Agent v1.0.0.1466
Connector Agent now includes **FlowScript 1.3.1**.
This update improves **module parsing performance**, making FlowScript processing more efficient.
## 2026-08-19
### New in Portal
<figure><img src="https://1716064794-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FIIgl6sNaTky0iALxYWHH%2Fuploads%2FzgqB0YuJ9xfUpYEROtB8%2Fimage.png?alt=media&amp;token=f9317f80-6af5-442b-9167-09407ca30a3d" alt=""><figcaption></figcaption></figure>
[Diagnostics ](/flow-connect/reference/reference/portal/diagnostic-panel-in-portal.md)is now available in the Portal, giving you greater visibility into how components run and making troubleshooting faster and easier. Explore detailed traces, execution times, errors, and input data to pinpoint performance bottlenecks and understand unexpected behavior quickly. &#x20;
### Fixes in Portal
* Improved performance by loading the Web Client in the background when a user first navigates to a page containing links to apps.
* Fixed an issue with expanding and collapsing windows.
* Fixed an issue where Flow Connect Portal could sometimes require users to clear their browsing data to work properly.
* Fixed an issue where queued executions could break when saved in newer versions of the Designer.
* Fixed an issue where data nodes were not executed in parallel.
#### iOS
* Improved application icon rendering.
* Scanner events now correctly route scanned values to the targeted text and numeric fields.
* Fixed an issue that could cause a crash when uploading a JPEG image to the file gallery.
## 2026-08-07
### IFS OData
Fixes in the IFS OData module generation service:
* Fixed a naming conflict for enumeration types that have a member called "Value". These must now be referred to by the disambiguated name ending in an underscore, e.g. `RoutingHandling.ActionConditionType.Value_`.
* Fixed a bug where nested OData actions and functions (like MoveInventoryPart) generated broken request URLs because the operation path was collapsed incorrectly. These now generate the correct path, and code generation is more reliable when the OpenAPI definition is incomplete.
If you have encountered any of these issues, you need to generate a new version of the module using the existing IFS Flowscript Module Generator application.
### Import Classic Workflows
Importing workflows from Classic has been updated with the following improvements and fixes:
* The deprecated function `FirstOrEmpty()` is now automatically migrated to `FirstOrNull()`.
* Substitution variables used for schema in database connectors are now automatically migrated to AppOwner, e.g. {myAppOwner} -> {AppOwner}.
* Fixed an issue where machine steps migrated to script steps failed for some connectors, e.g. FileSystem.
## 2026-08-04
### Connector Agent Manager v1.0.0.551
* **Preparations for Flow Connect Edge:** Installed agents now save their run mode (**Cloud**, **Dual**, or **Edge**) to the cloud, to be visible in Flow Hub.
### Connector Agent v1.0.0.1433
* Updated a dependency library. No functional changes.
## 2026-07-29
### Fixes
#### All Clients
* Prevent storage errors when finishing Sync Work retries
## 2026-07-28
### Fixes
#### All Clients
* Auto-forwarding no longer occurs when the setting is disabled.
#### iOS
* Resolved an issue where the calendar in the Inbox appeared compressed.
* Checkpoints now play a sound before reaching the end step.
* Annotations now display in full-screen mode.
#### Android
* Fixed an issue in the binary control that sometimes prevented either option from being selected.&#x20;
#### Web
* Introduced a redesigned contextual menu.
* Corrected application title priority handling.
* Fixed shortcut keys for navigating between items.
* Added the ability to select a year and month in the Date control.
* Fixed an issue where Inboxes were not focusable.
* Resolved an issue where pinned steps overlapped the Back button in mobile view.
* Added a new Start Diagnostic button (enabled by default in development environments; available in test and production environments when the "Enable Diagnostic Panel" setting is active).
<figure><img src="https://1716064794-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FIIgl6sNaTky0iALxYWHH%2Fuploads%2FPpjvGkOYyYWq1m3oxN2X%2FRun%20Diagnostic.png?alt=media&amp;token=7e7f4e8f-b2f2-4235-8fb6-d8d8841e2a34" alt=""><figcaption></figcaption></figure>
## 2026-07-20
### New in Portal
Events have been added to the Filter portlet. This makes it possible to create cascading filters between portlets, for example, selecting a customer in one filter and automatically limiting the second filter to orders for that customer.
A context menu is now available everywhere in the configuration panel where an app or component can be added. Refresh and Copy input definition have been moved to this menu. New is Open in Designer, which opens the selected app or component directly in the Designer.
<div align="left"><figure><img src="https://1716064794-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FIIgl6sNaTky0iALxYWHH%2Fuploads%2FIujPW35k7phUeP2CvWuy%2Fimage.png?alt=media&amp;token=ab7d613a-3e0d-48f7-88e1-da6810ea92db" alt=""><figcaption></figcaption></figure></div>
Filter portlet – The List of Values option now supports multi-select. Enable it by toggling the Allow multiple values setting.
When a filter is applied to a portlet, a filter icon is shown in the portlet header. It is now possible to see the active filter values. This is an End-User setting and can be enabled under Profile → User Settings → Filter Preview.
<figure><img src="https://1716064794-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FIIgl6sNaTky0iALxYWHH%2Fuploads%2FVsBpjtIGROezzllbBB6Z%2Fimage.png?alt=media&amp;token=72a39de4-cae9-4eaa-ad9d-9d6a152a056e" alt=""><figcaption></figcaption></figure>
### Fixes in Portal
* Fixed a CSS issue in the Filter portlet.
* Fixed an issue where filters could stop working after being cleared.
* Gantt – Fixed Resource Mapping and dependency interaction functionality.
* Gantt – Fixed an issue where Clear User Settings did not work.
* Kanban – Fixed a drag-and-drop issue.
* Fixed an issue where the Portlet Filter pop-up could be hidden.
* Scheduler – Added `viewStart` and `endDate` to the Resource input.
* Visual Planning portlets – Added a slight delay before tooltips are shown on hover.
## 2026-07-15
#### Fix in iOS
* Fixed an issue where menu selection text was not visible if a line break was used.
## 2026-07-08
#### Fixes in Android
* Fixed an issue where users could get stuck on the splash screen on scanners running older operating systems.
## 2026-07-02
### Fixes
#### All Clients
* Fixed an issue where binary downloads could fail for queued executions.
* Improved Home view reload performance.
#### iOS
* Fixed an issue where the Inbox calendar could stop working after returning from an execution.
* Fixed an issue where the Next button on the keyboard was disabled when a text or numeric field allowed empty values.
## 2026-07-01
### Connector Agent v1.0.0.1382
**Release of a brand-new OPC UA connector.**
The OPC UA connector enables direct interaction with OPC UA servers from workflows. It allows browsing the server's address space, reading real-time data from nodes, and writing values to data points, enabling seamless integration with industrial automation systems.
Unlike the UI-based approach in Flow Classic, Flow Connect leverages Flow Script to programmatically browse, read, and write OPC UA server nodes. [Read more](https://docs.novacura.com/flow-connect/working-with-connect/connect-to-systems/connectors/opc-ua)
## 2026-06-25
#### New in Portal
<figure><img src="https://1716064794-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FIIgl6sNaTky0iALxYWHH%2Fuploads%2FJAlYWyvQmoR8wFnmrEsx%2Fimage.png?alt=media&amp;token=22ce666a-d88c-4bae-9baa-bf16d1c80d19" alt=""><figcaption></figcaption></figure>
* General - Added support for Custom buttons and CRUD (table portlet). CRUD and custom buttons can now be customised with configurable styles, colours, sizes, and alignment, making it easier to match your application's branding and layout.
* Custom content - Added support for Phrasebook translations in custom content configuration.
* Filter - Added a new List of Values UI option to display values as chips or buttons. Filter values can now be displayed as clickable chips for faster selection when there are 8 or fewer options. Lists with more than 8 options are automatically displayed as a dropdown.
* Table - Added extended colour styling configuration. Conditional styling can now be applied to entire columns, and cell colours can be based on the value of a different column, providing greater flexibility when highlighting data.
* Table - Added listener information to CRUD buttons. CRUD buttons can now access the same event data used to filter a portlet, making it easier to create related records based on the current selection.
#### Fixes
* General - Fixed an issue where navigation could lose focus when many nested elements were present.
* General - Fixed an invalid save portlet message displayed during validation errors.
* Table - Improved header sizing and highlighting.
## 2026-06-17
#### All clients
* Added support for automatically moving focus to Menu Selection, Binary, and Checkbox controls.
* Fixed an issue where the Signature control could not be hidden.
* Fixed an issue that could cause an error message to appear when client data became out of sync.
#### Android
* Fixed an issue where pressing Enter after entering text skipped Dropdown and Radio Button controls and moved directly to the next text field.
* Fixed an issue where the Done button did not automatically close the on-screen keyboard when there was no next control to receive focus.
#### iOS
* Improved the offline data error message.
* Fixed a crash that could occur when opening a Data Grid with no columns.
* Fixed an issue where text in the List Selection search bar was displayed in white.
### Connector Agent v1.0.0.1371
With this Agent release, version **1.0.52** of the **File System Connector** has been released.&#x20;
This version introduces improvements to the handling of protected paths, ensuring that access restrictions are enforced consistently and that protected directories remain inaccessible regardless of the configured root path. The update strengthens the overall security and reliability of file system operations.
## 2026-06-15
### List view for the Application Library and package content
A new **list view** is now available alongside the existing card view, both in the Application Library and inside an application package. Use the toggle in the top-right corner to switch between them.
In the **Application Library**, list view displays your packages in a sortable table with **Created** and **Last Modified** columns, and you can sort by **Name**.
Inside an **application package**, list view is more detailed:
* It shows Applications, Portal Pages, and Automations in a single sortable table with additional columns: Deployed version, Last Modified, Latest Commit, Visible (shown in Client), and Tags.
* **Density modes** – list view can be shown in **Regular** or **Dense** spacing.
* **Filtering** – a new filter bar lets you narrow content by **Name**, **Type** (Application, Page, Automation), **Deployed** status, and **Tags**, with a **Reset filters** option.
* **Tagging** – Applications, Portal Pages, and Automations can now be assigned **tags** from their settings panel, which can then be used in the list view column and the Tags filter.
Read more: [Package content view](https://docs.novacura.com/flow-connect/working-with-connect/create-and-design/application-packages/package-content-view) and [Application packages](https://docs.novacura.com/flow-connect/working-with-connect/create-and-design/application-packages).
## 2026-06-02
### Connector Agent v1.0.0.1327
* This version introduces support for signed values in the HTTP REST connector for script-based flows. The Flow Designer allows variables to be marked as requiring a signature, while script steps can sign primitive values and verify signed values at runtime.
  With this enhancement, the application can make secure authorization decisions based on trusted values provided by the client.
### Portal
#### New in Portal
* Interactive basic authentication support has been added to the Portal
#### Fixes
* Export – Fixed issue where exporting to XLS was not working
* Charts – Fixed several issues affecting chart portlets in Flow Connect Portal
* Document Viewer – Fixed issue where page organisation changes could not be saved
* List of Values – Added support for configuring sort order
* Portal – Added validation to prevent page names consisting only of whitespace
* Portal – Fixed a crash that could occur when navigating to a URL in a different environment
* Portal – Fixed issue where pasting a portlet into a stacked container could place it outside the last tab
* Portal – Fixed issues affecting custom content app click actions
* Portal – Fixed whitespace issues introduced in Portal 2026.1
* Table – Advanced column settings are now preserved when the data source changes
* Table – Column lists now display translated column names instead of internal variable names
* Table – Fixed issue where copying from a portlet did not work when frozen columns were enabled
* Table – Fixed issue where grouping and refreshing could cause the portlet to become unresponsive
* Table – Fixed issue where the Column LOV spinner remained visible after an error
* Table LOVs – Fixed issue where list-of-values definitions could not be edited
* Table/Custom Content – Fixed issue where disabling Auto Refresh could result in an endless loading spinner
## 2026-06-01
### Client fixes
#### Web, Android, and iOS&#x20;
* Added a "No Search Results" view for list selection controls
* Added a "Clear Image" option for the camera control
#### Web and Android
* Added a Delete Signature button
#### Android
* Added a Done Signature button
* Increased the maximum number of lines for checkpoints
* Fixed an issue where files could not be opened from the file gallery
#### iOS
* Fixed an issue with the Delete Signature button
* Fixed an issue where blank signatures could be saved
#### Connector Agent Manager v1.0.0.511
* Improved reliability of the Agent uninstall process.
* Fixed an issue that could prevent Agent uninstallation.
* Added clearer guidance when files remain after uninstall due to being locked by another process.
## 2026-05-25
### Connector Agent v1.0.0.1323
* Fixed an issue where executing SQL Server queries could fail when datetime columns contained null values.
## 2026-05-19
### Client fixes
* Fixed an issue where “Add row” did not work for grids in User Step
* Fixed an issue where erroneous dates and numbers were not blocking execution
* Updated whitespace handling for the initial control in execution steps
### Connector Agent v1.0.0.1304
**Release of a brand-new Infor M3 connector.**
The Infor M3 connector enables direct interaction with the M3 ERP system from workflows. It allows querying M3 programs and transactions, passing input parameters, and retrieving business data, enabling seamless integration with M3.
Unlike the UI-based approach in Flow Classic, Flow Connect leverages Flow Script to programmatically query Infor M3 programs, transactions, and fields. [Read more](https://docs.novacura.com/flow-connect/working-with-connect/connect-to-systems/connectors/inform3-api-socket)
#### Other Connector Releases
* Together with this agent version IFS10 Connector 1.0.74, Microsoft SQL server 1.0.69, Oracle 1.0.53, ODBC 1.0.7 have also been released due to improvements made to the codebase.
## 2026-05-18
### Connector Agent v1.0.0.1302
Fix for Azure Service Bus transport configuration regression. This release resolves the issue that caused Connector Agent v1.0.0.1283 to be withdrawn.
Includes all improvements from v1.0.0.1283:
* More resilient agent upgrades with automatic retries for transient file locks.
* Updated scripting runtime with the latest fixes and improvements.
* Database steps that rely on user identity values no longer fail when no user identity is available at runtime.
## 2026-05-14
### Connector Agent v1.0.0.1283 (*withdrawn*)
> This release has been withdrawn due to a regression affecting Azure Service Bus transport configuration. A corrected release will be published in an upcoming version.
* More resilient agent upgrades. The upgrade process now moves files individually with automatic retries and marks each upgrade folder as complete only after the move fully succeeds. Upgrades survive transient file locks (antivirus, backup tools, Windows Search) instead of failing as a whole, and a partially written upgrade folder is never reused.
* Updated scripting runtime. The embedded scripting engine has been refreshed, bringing the latest fixes and improvements to flow scripts that run on the agent.
* Database steps that rely on user identity values (`FlowUser__email`/`username`) no longer fail when no user identity is available at runtime.
* Together with this agent version FileSystem 1.0.49, SFTP 1.0.25, FTP 1.0.11, and NiceLabel 1.0.5 have also been released due to upgrades made to the flow script.
### Connector Agent Manager v1.0.0.488
* Reliable agent uninstall. Uninstall no longer fails when an agent has already been partially removed from the cloud, when files are still in use as the service is stopping, or when the underlying Windows service has already been marked for removal.
* More resilient agent installation and upgrades. Copying agent files into place no longer relies on a single all-or-nothing directory rename. Files are moved individually with automatic retries, so installations and upgrades succeed even when antivirus, backup tools, or other processes briefly hold a file open.
## 2026-05-07
#### All clients
* Added support for Basic Authentication for connector authentication
## 2026-05-04
### Reusable Phrasebooks
Phrasebooks can now be created as shared, reusable **assets**. Until now, every translation lived in the local Phrasebook of a single Application or Component. With Phrasebook assets, the same translations can be maintained once and used across many Applications, Components, and Portal Pages.
Highlights:
* Create a Phrasebook asset in the **Application Library** to share it organization-wide, or inside an **Application Package** to keep it scoped to that Package.
* Phrasebook assets are **committed and versioned** — the same lifecycle as Components and Modules. References automatically pick up the latest committed version when an Application is edited and saved.
* Enable a Phrasebook asset for an Application, Component, or Portal Page from the new **Add Phrasebook** dropdown in the Phrasebook window.
* Asset phrases are referenced through the **asset's name**, for example `{CommonLabels.greeting}` — keeping local and shared phrases in separate namespaces, the same way Modules work.
* Insert any existing phrase without typing using the new **Browse phrases** option in any Template-enabled field's Editor menu.
Learn more about [Translations](/flow-connect/working-with-connect/create-and-design/phrasebooks.md).
### New Crypto module in Flowscript
The Crypto module provides cryptographic operations for hashing, encryption, decryption, key generation, and digital signatures. [Learn more.](/flow-connect/reference/reference/flowscript/walkthrough/crypto-module.md)
## 2026-04-30
### New in Portal
* Support added for Phrasebook assets
* Support added for Local storage
### Fix in Clients
* Resolved a race condition issue for binaries.
## 2026-04-29
### Connector Agent v1.0.0.1228
This release improves upgrade reliability and adds dedicated support for on-prem automation executions.
* Added dedicated handling for on-prem automation execution requests, so these jobs are processed separately and more predictably.
* Improved automation compatibility by supporting version-specific execution packages, helping ensure the right runtime is used for each request.
* Strengthened the Agent upgrade flow with better retry handling for temporary file and folder access issues, reducing upgrade failures caused by transient system locks.
* Improved resilience for Hub-triggered upgrades by making interrupted or partial downloads recover safely and avoiding inconsistent upgrade state.
* Together with this agent version, SFTP 1.0.24, FTP 1.0.10, and NiceLabel 1.0.4 have also been released due to upgrades made to the flow script.
## 2026-04-27
#### New FlowScript module
Added Text module with functions for text manipulation (e.g. concat, contains, pattern matching, character codes, and new lines)
* Major inbox reworked across all clients *(Note: paused inbox tasks are not preserved after update)*
* Added support for all Phrasebook languages
* Fixed the issue where assertion step titles appeared in error pop-ups
* Fixed calendar control issues (underlying/starring actions)
#### Android
* Fixed issues with assertion step titles in error messages
* Fixed issue with External App Launcher record variables
#### iOS
* Fixed the issue where the app could become unresponsive when using an empty picklist dropdown
* Fixed the issue where the Evaluator was unavailable
### Connector Agent v1.0.0.1198
Fixed: Improved security handling in the Agent to address a potential issue (Microsoft Security Advisory CVE-2026-40372). This update strengthens internal protections to ensure safer execution of integrations.
## 2026-04-16
### New in Portal
**Improvements in the Table portlet**
* Added table header configuration, making it possible to control font size and background colour separately from the rows. The font and padding picker has also been moved and is now available to end users via the context menu.
* Added an option to remove the paginator. When the paginator is removed, a maximum of 500 rows will be displayed for performance reasons.
* Updated default CRUD button titles (Add, Delete, Update, Cancel). These can now be customised and translated using the Phrasebook.
**Link portlet**
* Added support for external URLs with query parameters for IFS and Search types.
**Automations**
* Added a max retry option for scheduled automations (up to 5 retries in TEST; PROD remains unchanged).
* Increased automation timeout. Scheduler timeout has been extended from 10 minutes to 30 minutes.
### Fixes in Portal
* General  – Prevent selection of assets without committed versions as a data source
* General - Scroll now positions on the selected item when the data source list opens
* General – ESC now cancels drag-and-drop when adding a portlet
* Custom content – Added missing clear user settings option
* Document viewer – Aligned icons to the left
* Filter – Added English translation for data input
* KPI card – Fixed the incorrect default colour
## 2026-04-09
#### Release of a brand new connector: NiceLabel
* The NiceLabel Connector enables barcode label printing through the NiceLabel labeling system. [Read more](https://docs.novacura.com/flow-connect/working-with-connect/connect-to-systems/connectors/nicelabel)
## 2026-04-01
### AI Flow Builder
AI Flow Builder v1 lets you create workflows simply by describing what you need in plain language. The system interprets your description, asks for missing details, and generates a set of workflow steps that you can review and adjust. This first version focuses on easy, common business scenarios and gives you a fast way to turn an idea into a structured workflow. Editing remains fully under your control : you can adjust steps manually or ask the AI to refine them with short follow-up commands.
This release creates only the workflow steps. Step configurations such as fields, validations, conditions, and data mapping are not included yet and continue to be added manually.
What’s supported in v1
Supported
* Create workflows from natural language
* Add, remove, rename, or reorder steps
* Generate decision branches
* Simple multi-level approvals
* AI-assisted edits in iterations
* Autosave of all manual and AI-generated changes
* The system produces executable FlowScript for cases related to integration with IFS Cloud via OData APIs
Not Supported in v1
* Step configuration (fields, validations, conditions)
* FlowScript or scripting (excluding IFS Flowscript generation)
* Swimlanes
* Asset or component generation
* Connectors or data model suggestions
* Image-to-workflow conversion<br>
For more details, follow the [link](/flow-connect/reference/reference/ai-flow-builder.md) below.
### Web Designer Replaces Windows Designer
* Web Designer is now the default for all organizations starting April 1st.
* Applications and Assets now automatically open in Web Designer.&#x20;
* The Windows Designer is now referred to as the Legacy Designer.
* Applications created in Windows Designer can still be opened in Legacy Designer from the context menu.
Changes in Web Designer aren't visible in Windows Designer, and committed applications cannot be reopened in Windows Designer.
The Legacy Designer will be discontinued on June 30, 2026.
**New FlowScript module**
The [FlowScript local storage module](/flow-connect/reference/reference/flowscript/walkthrough/flowscript-local-storage-module.md) enables local storage, retrieval, and management of data using partitions and keys, making it easy to cache data and share temporary information between apps.
* Each value is stored within a partition (logical grouping) and identified by a key
* Data is stored locally on the device or in the browser
* Storage is user-specific and session-specific
* Data is not shared across devices or browsers and is cleared when the session ends
Fixes in Clients
* Fixed an issue where text formatting for static and header text controls would reset when resuming or restarting an app
## 2026-03-25
### Portal
#### Navigation & Deployment Updates
* You can now define the page order and tree structure (up to three levels) directly in the Portal and Hub.
* Users can now switch the navigator between side and top positions or enable breadcrumbs under Profile > User Settings.
* The navigation structure is now inherited from DEV to TEST/PROD upon page deployment.
* To ensure consistency across environments, child pages will automatically move up one level if their parent page is not deployed.
#### Fixes
* Removed the notification for resizing or dragging portlets.
* Table - Fixed an issue where resizing a column would overwrite the column name.
* Table - Resolved a performance issue where portal configuration was slow when tables contained a large number of columns.
## 2026-03-12
* Users are now informed when attempting to upload unsupported file types.
* Components now update correctly after debugging, ensuring the client always loads the latest version.
## 2026-03-09
#### Fixes
**Automation**
* Fixes issues where it was not possible to stop a schedule and where overlapping scheduled executions could cause a pile-up.
**Portal**
* Phrasebook - Fixes issues with the phrasebook dialogue appearing behind the table column management modal, the context menu remaining after closing the dialogue, and errors when adding a language.
* Document Viewer - Fixes issues with displaying files, opening the viewer without a file selected, printing, and annotations.
* Gantt - Parent milestone tasks display the native tooltip instead of the custom tooltip.
* Kanban - Pre-fetch filters are cleared when performing column actions in a table.
* Kanban - The selected task is not highlighted.
* Table - Custom buttons row disappears after using the “Clear User Settings” option.
* Table - Error occurs when selecting “Show tooltip”.
* Table - If one column is configured as a link, it is not possible to edit the remaining columns.
* Table - Issue with autocomplete in configuration.
* Table - Issue with custom buttons and toolbar.
* Table - Portlet configuration save returns a 500 error when listeners are configured.
## 2026-03-03
### Connector Agent v1.0.0.1075
* **Fixed:** REST calls to HubSpot could fail when a text/string variable containing a datetime in the format `"2024-01-01T20:23:03.333Z"` is used in the JSON body. When using the REST call via the Agent, if the date string is stored in a variable, the Agent converts it to a different format `"1/1/2024 8:23:03 PM"`, causing a **400 – Bad Request** error. Hardcoding the datetime in the JSON body works as expected (**200 – OK**). Running the workflow in Client mode instead of the Agent also works correctly with the variable, without any conversion.
## 2026-03-02
**All**
* Fixed an issue where long control prompts were cropped or wrapped incorrectly
* Added SSL pinning for native clients
**Android**
* Fixed an issue where screen rotation cleared the search field in the Execution view
**iOS**
* Fixed an issue where search was split into two columns in landscape mode
* Fixed an issue where inbox view icons displayed colored backgrounds
* Fixed an issue where checkpoints prevented users from exiting the application
**Web and Windows clients**
* Fixed an issue where fields in the grid control did not display values for certain browser language settings
* Fixed an issue where the image viewer close button was barely visible
* Fixed Diagnostic Panel flickering
## 2026-02-26
### IFS OData Modules
* Optimized OData modules: large data sets are processed much more efficiently.
* The required If-Match headers are now added as a separate parameter.
* Enum-typed keys are now formatted as proper OData enum literals instead of raw values.
* Improved handling of IFS enums that use friendly names containing spaces.
* Queryable navigation properties are now generated from the OpenAPI specification.
Newly generated modules require Agent version 1.0.0.1042 or later. For organizations using the Windows Designer, version 1.0.0.203 or later is required.
### M3 Migration Improvements
Migration of Classic workflows using the M3 REST Connector.
* Added an option to specify a user variable for migrated script steps during import.
* Error handling in machine steps is now properly migrated.
### Hub
* Fixed several issues related to importing Classic workflows.
* View analytics from the automation settings screen.
### Windows Designer v1.0.0.203
Updated version of the Windows Designer with support for the latest FlowScript optimizations.
## 2026-02-16
### Connector Agent v1.0.0.1035
* **Fixed:** Machine steps using the **Oracle connector** could **crash** when a query returned **high-precision decimal/NUMBER(p,s)** columns (precision **> 28**), even if the actual value had fewer digits. The Agent now handles these cases more robustly to prevent runtime numeric conversion failures.\
  **Tip:** If you have specific columns that may contain very large or high-precision numbers, return them as text in the SQL query using `CAST(<column> AS VARCHAR2(<size>))` or `TO_CHAR(<column>)`. Alternatively, you can enable **`Convert decimals to string = true`** in the connector configuration to treat all decimal values as text.
## 2026-02-11
### Connector Agent Manager v1.0.0.420
The application has been upgraded from **.NET 8** to **.NET 10**.
On first start after updating, some users may see a prompt saying **“.NET Desktop Runtime must be installed”**. If this happens, follow the link in the dialog to download and install the **.NET 10 Desktop Runtime**, then restart Connector Agent Manager.
## 2026-02-05
### New in Portal - Gantt portlet
The Gantt portlet is now available in the Portal. It is a timeline-based tool for planning and managing tasks, projects, and resources. Commonly used in project management, Gantt charts visualise tasks, durations, and dependencies in a structured format. The portlet supports dependency tracking, schedule adjustments, and progress visualisation.
Flowscript and translations are now supported in HTML-based tooltips.
Organisation and environment IDs are now supported in Portal links.
### Fixes in Client
* Added the ability to switch camera devices inside the camera control
## 2026-02-02
### New Designer available
The new web-based Designer is now enabled for all organizations as a beta. You can open your existing applications in the new Designer by using the context menu on the application card and selecting **Open in Web Designer**.
#### Important notes on transitioning from Windows Designer
* All existing applications created in Windows Designer can be opened in Web Designer.
* Changes saved in Web Designer will not be visible if the same application is opened in Windows Designer.
* Once an application is committed in Web Designer, it can no longer be opened in Windows Designer.
* Applications developed in Web Designer can use components and modules developed in Windows Designer.
#### New default designer
Starting April 1, the Web Designer will be the default for all organizations in Connect. If you would like to make this change before April 1, please reach out to your Account Manager.
* The Web Designer will become the default when opening an application or asset by clicking the card or selecting **Open in Designer** from the Hub.
* You can still open an application in Windows Designer for a limited time by using the context menu and selecting **Open in Legacy Designer**.
## 2026-01-30
### Update Connector Agent from Hub
The Hub now shows an indicator (a blue dot) in the Agents section when a newer version of the Connector Agent is available. You can also request an update directly from the Hub, provided the agent is running version 1.0.0.923 or later.
The update request is handled on the agent machine and does not provide real-time status updates in the Hub. Once the update is complete, the new version will be displayed in the Hub.
## 2026-01-27
**Android:**
* Removed the possibility of application screenshots appearing in recent views, for privacy reasons.
**iOS:**
* Updated to iOS 26.&#x20;
* Added a privacy overlay when the application is paused.
**Web:**
* Fixed an issue where refreshing the page could result in a 404 error.
**Web & Forms:**
* Fixed an issue where items did not receive automatic focus in certain situations.
## 2026-01-21
### Connector Agent v1.0.0.930
* New: Added opt-in, detailed IFS10 command logging to support troubleshooting. You can enable Debug logging in appsettings.json to capture failing commands only, or Verbose logging to capture all executed commands.
## 2026-01-20
**iOS**
* Fixed a bug where rotating the screen while having a contextual menu open would cause the layout to break.
* Fixed an issue where the progress spinner overlay could be scrolled out of in the home view.
* Fixed spacing in the add row dialogue for the data grid control.
## 2026-01-19
### Connector Agent v1.0.0.923
* New: Prepared support for upgrading the Agent directly from the Hub. Once the Hub upgrade feature is released, Agents running v1.0.0.923 or later can be upgraded from the Hub; older Agent versions must be upgraded using Connector Agent Manager.
## 2026-01-07
### Connector Agent v1.0.0.893
* **Fix:** Resolved an issue where *Connector Agent* could fail to start on computers where it was installed for the first time. The Agent Windows service now launches correctly after a fresh installation.
## 2026-01-05
### Connector Agent Manager v1.0.0.410
* **Fix:** Resolved an issue where *Connector Agent Manager* could fail to start on computers where it was installed for the first time. The application now launches correctly after a fresh installation.
## 2025-12-17
### New in Hub
**UX Improvements**
* Duplicate a connector, including environment configurations.
* Dialogs now support Enter to confirm the default action, enabling faster keyboard-based workflows.
* Table views now include vertical grid lines, improving structure and overall readability.
**Migration from Classic**
* Steps using the M3 REST connector are now automatically migrated to FlowScript modules in Connect.
* SQL Server steps using the Connector Service are now automatically migrated to native SQL Server connectors in Connect, preserving existing behavior.
## 2025-12-16
### New in Portal
The Scheduler portlet is now available in the Portal. Use the Scheduler to get a visual overview of your tasks, with or without resources, and see how they are allocated over time. Interact using simple drag-and-drop, or double-click to start executing an app. Easily plan, adjust, and optimise your work.
Find more info [here](/flow-connect/reference/reference/portal/design-items/portlets/scheduler.md).&#x20;
**Event changes**
* Task deselection now fires an empty event (previously, no event was fired).
* Both task selection and deselection now trigger post-fetch events.
**Start Ring input changes**
* Added: `PortletType` property (Scheduler, Gantt, and Kanban).
* Removed: `TimezoneOffset` property (Scheduler and Kanban).
* `targetResourceIds` is now included in drop interactions from other portlets.
**Known limitations in agenda views**
* Creating tasks via interaction is not supported.
* `targetResourceIds` is not included in drop interactions.
## 2025-12-05
### New
The diagnostic panel can now be accessed in the TEST and PROD environments, as well as in DEV.\
In TEST and PROD, go to Profile → Settings and enable the diagnostic panel under Diagnostic Settings.
When enabled, the diagnostic panel can be opened and closed using the toggle icon located on the right-hand side of the header banner during app execution. The setting will be disabled when the session ends or when the user switches environment or organisation.
### Fixes in Web/Windows client
* Improve signature control smoothness.
* Update icons for diagnostic mode.
## 2025-12-04
### Connector Agent **v1.0.0.**&#x37;79 is released
With the release of **Connector Agent v1.0.0.779**, we've addressed several issues and introduced new features. To learn how to upgrade, follow the [upgrade guide here](/flow-connect/working-with-connect/connect-to-systems/connector-agents/manage-agent.md#upgrade-agent)
* #### SFTP connector released
  The first version of the SFTP connector has been released. SFTP connector allows flow apps to interact with a SFTP server. [Read more](/flow-connect/working-with-connect/connect-to-systems/connectors/sftp.md)
* **Database Connectors**
  * Introducing time zone handling to Improve consistency in date/time handling. It is specific to database connectors like IFS 10, SQL Server & Oracle [Read more](/flow-connect/working-with-connect/connect-to-systems/timezone-handling.md)
Please ensure that both the Connector Agents and Flow Designer are updated to their latest versions.
* Connector Agent V1.0.0.779
* Flow Designer V1.0.0.199
## 2025-12-02
#### SCIM Improvements and Fixes
* SCIM-managed users with the status Inactive can now be deleted in the Hub.
* Improved validation of provisioning configuration to prevent users from being created in an unusable state.
* SCIM-managed users who belong to multiple organizations are now only flagged as SCIM-managed in the source organization.
#### Connector Configurations
* Connector configurations can now be copied between environment tabs.
#### Application Packages
* Application packages can now be managed directly from the Access Group settings page, not only from the Application Package access screen.
## 2025-11-26
### New
Added the ability to run diagnostics mode for apps that use queue lanes, i.e., where transactions are uploaded asynchronously.
### Fixes
#### All clients
* Improvements to date- and time-based features
* General performance enhancements
#### Web and Windows clients
* Fixed a bug that prevented touchscreen devices on Windows from registering input in the signature control.
## 2025-11-20
### SCIM 2.0 Integration
Flow Connect now supports SCIM 2.0 (System for Cross-domain Identity Management) for automated user and group provisioning.
Our initial release includes full support for Microsoft Entra ID, allowing organizations to synchronize users and groups directly from Entra into Flow Connect.
[Learn more about setting up SCIM.](/flow-connect/reference/how-to-guides/synchronize-users-and-groups-with-scim-2.0.md)
### Migrate translated applications from Classic
The import function in Hub now supports migrating translated workflows from Flow Classic to the new Phrasebook in Flow Connect.
## 2025-11-19
### Fixes Portal
* Added a loading indicator to data sources for improved UI feedback.
* Corrected an error that occurred when changing organisation if no pages existed in the target organisation.
* Corrected an issue where portlet events stopped working after copying a portlet.
* Corrected Finnish translations for CRUD buttons.
* Improved styling for disabled custom buttons.
* Increased portlet title length limit to 1024 characters.
* Prevented the possibility of creating circular references using *onRefresh* events.
* Custom Content – Corrected an issue with portlet filtering when pagination was enabled.
* Map – Corrected an issue where markers were not updated when event filter results were empty.
* Map – Corrected an issue where panning became disabled after the first move when *home lock* was enabled.
* Map – Corrected an issue where panning was disabled after a drag-and-drop action.
* Table – Added missing disabled states to CRUD toolbar buttons.
* Table – Corrected an issue where color rules were not applied to frozen columns.
* Table – Corrected an issue where, when adding a row, all columns appeared editable.
* Table – Corrected an issue with column resizing.
## 2025-11-10
### Connector Agent Manager **v1.0.0.347** is released
With the release of **Agent Manager v1.0.0.347**, we've introduced a checkbox during the agent installation to store the machine name in Connect Cloud.&#x20;
<figure><img src="https://1716064794-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FIIgl6sNaTky0iALxYWHH%2Fuploads%2FIyaSZLpyCjGAjgTT4bq0%2Fimage.png?alt=media&amp;token=48742dc8-d238-4e42-b1f6-fa3ed6488ac0" alt="" width="463"><figcaption></figcaption></figure>
If this option is checked you can see the machine name in the Hub making it easier to find where a particular agent is installed.
<figure><img src="https://1716064794-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FIIgl6sNaTky0iALxYWHH%2Fuploads%2FuQaolGFItZz5ZN99DspI%2Fimage.png?alt=media&amp;token=953d87d8-1acd-4b98-bcb6-b915c074d6a8" alt="" width="563"><figcaption></figcaption></figure>
### Connector Agent **v1.0.0.735** is released
With the release of **Connector Agent v1.0.0.735**, we've added optimizations for REST, FileSystem and SFTP connectors when using modules. To learn how to upgrade, follow the [upgrade guide here](/flow-connect/working-with-connect/connect-to-systems/connector-agents/manage-agent.md#upgrade-agent)
## 2025-11-06
### **New**
It is now possible to set an expiration date for preloaded data. The expiration time is defined on the local resource, with options for either a soft stop or a hard stop.
Read more [here](/flow-connect/reference/reference/designer/steps/local-data-resource.md#expiration-date).
### **Fixes**
**Android**
* The local data resource badge in the home view now automatically updates its status.
* Fixed an issue that caused certain Zebra scanners to emit multiple keystrokes when using the physical keyboard.
* Fixed an issue where rotating the screen in the search view would clear the search text.
* Fixed an issue where the client would crash when exiting an application from a sub-workflow.
**iOS**
* The local data resource badge in the home view now automatically updates its status when a local data resource expires.
* Redesigned list and multi-list selection controls.
* Fixed an issue where pinned step icons would randomly move.
* Fixed a crash caused by performing quick actions while in a menu selection.
* General security improvements.
## 2025-10-22
### Connector Agent **v1.0.0.717** is released
With the release of **Connector Agent v1.0.0.717**, we've addressed several issues and introduced the possibility of[ configuring a pass through proxy for REST connector](/flow-connect/working-with-connect/connect-to-systems/connectors/rest.md#configure-passthrough-proxy). To learn how to upgrade, follow the [upgrade guide here](/flow-connect/working-with-connect/connect-to-systems/connector-agents/manage-agent.md#upgrade-agent).
## 2025-10-07
### Connector Agent **v1.0.0.707** is released
With the release of **Connector Agent v1.0.0.707**, we've addressed several issues and introduced improvements to several Connectors. To learn how to upgrade, follow the [upgrade guide here](/flow-connect/working-with-connect/connect-to-systems/connector-agents/manage-agent.md#upgrade-agent)
* Microsoft SQL Server Connector
  * Introduced **Trust Server Certificate** property in the connector configuration that allows the connector to accept self-signed SQL server certificates without validating it against a certificate authority (CA).
* File System Connector
  * Renamed mergeTwoPDFs to mergePdfs for consistency and clarity.
**Potential breaking change** if the Apps currently uses the **`mergeTwoPDFs`** method in File System Connector ->  flowscript steps. Please update the flowscript code to use **`mergePdfs`** instead.
### Translations for Applications and Components
We’ve introduced translations in Flow Connect, making it easier than ever to build multilingual applications.
**Highlights:**
* Translate application packages, applications, and components into multiple languages.
* Manage translations centrally in a Phrasebook.
* Use variables and template strings to insert runtime values (e.g., “Hello {firstName}”).
* Full support for the ICU Message Format, enabling natural-sounding messages with pluralization and advanced language rules.
* Automatic fallback to default language if no translation exists.
* Quickly add new phrases from the Designer with the “Add text to Phrasebook” option.
[Learn more about translating applications.](/flow-connect/reference/how-to-guides/translate-applications.md)
## 2025-09-30
## Flow Connect Assistant
**What it is**\
Flow Connect Assistant helps you navigate Help documentation and learn how to use Flow Connect. You can start with a suggested question or write your own.
**What you can ask**
* Simple tasks, for example, “How do I create a token key for an automation”
* Multi step tasks, for example, “I want a solution where the purchaser enters an item and a price, then on submit the manager must approve before the purchase is authorized”
**What it will not answer**
* Questions about **Flow Classic**
* For deep FlowScript code questions, use[ **FlowScript Copilot**](/flow-connect/reference/reference/flowscript-copilot.md) for those
**Why this matters**\
You get faster answers inside Hub, without searching across pages.
**How to open** [**Flow Connect Assistant** ](/flow-connect/reference/reference/flow-connect-assistant.md)
## 2025-09-29
### Fixes - iOS
* Fixed an issue where an action button would appear in toast messages that required no input
* Fixed an issue where subworkflows would not fully quit
## 2025-09-26
### Connector Agent **v1.0.0.701** is released
With the release of **Connector Agent v1.0.0.701**, we've addressed several issues related to database connectors and send-email connector. To learn how to upgrade, follow the [upgrade guide here](/flow-connect/working-with-connect/connect-to-systems/connector-agents/manage-agent.md#upgrade-agent)
* Send-Email Connector
  * Resolved an issue where SSL was enforced when sending emails even when "Security Type" was set to "None" in connector configuration.
* Database Connectors(SQL Server & Oracle)
  * `datetimeoffset` values are now returned as proper date-time objects instead of string.
**Potential breaking change:** Applications that expect `datetimeoffset` values as strings may be affected. As a temporary workaround, use Flowscript to explicitly convert `datetimeoffset` values to strings
```javascript
return format(dateValue, "yyyy-MM-dd HH:mm:ss K");
### New in Portal
#### **Map portlet - Clustering**
You can now enable clustering for map layers. When multiple markers are close together, they will automatically be grouped into clusters, making maps easier to read and navigate.
#### **Map portlet - Image as a new type of static layer**
It is now possible to add images as static layers in the map portlet. Images can be positioned, resized, and locked in place, providing more flexibility for images such as floor plans and site maps.
#### Base chart
A new configurable option for column spacing has been added. You can now choose between *None*, *Narrow*, *Medium*, and *Wide* to adjust spacing between columns.
### Fixes
* The Portal locale changed to be based on the browser language. The portal language setting only affects actual translations
* Custom buttons improved support for custom button conditions
* Fixed an issue where the environment variable could not be resolved
* Custom content -  fixed an issue where the portlet was not correctly refreshed
## 2025-09-19
### New feature
We have added Spanish as a system language, and it is now officially supported in the clients.
### **Fixes**
**Android**
* Updated UI for a more modern look and feel
* Fixed an issue where the keyboard remained open when adding a row in grid or calendar controls
* Fixed an issue where the keyboard didn’t close when exiting the search view
* Fixed an issue where external authentication got stuck when rotating the screen
* Fixed an issue where subworkflows didn’t fully quit
* Fixed margins between pinned steps and user steps
* General performance improvements
**iOS**
* Improved UI for search view in landscape mode
* Fixed an issue where rotating into landscape on certain devices caused the screen to appear blank
* Fixed an issue where translations didn’t update in profile view
* Fixed translation issues in the search view
**Web**
* Fixed an issue where signature control backgrounds appeared black when uploaded to IFS
* Fixed an issue where images could appear outside user step boundaries
* Fixed an issue where the FlowScript version text was cut off in the settings dialogue
* Fixed translations for the client update notification
## 2025-09-12
### **New in Portal**
* General – You can now copy a portlet into a page that belongs to a different package. Data sources, unless they are global components, will be disconnected. The cut and copy UI has also been updated for easier use.
* Basic chart – Data label has been added as a configurable item. This means the chart value can now be displayed inside, above, or in other positions relative to the bar for faster visual access to data.
* Map portlet – Two new marker shapes have been added: circle and square.
### **Fixes**
* Fixed an issue in Custom Content where refresh was missing after interaction.
* Fixed missing message in meta (page name) translations when no languages were available.
* Fixed an issue in Map where the default icon could not be removed.
* Fixed an issue in Custom Content where row selection was not cleared.
* Fixed an issue in Map where markers were not visible after a base map change.
## 2025-08-28
### Connector Agent **v1.0.0.665** is released
With the release of **Connector Agent v1.0.0.665**, we've addressed several issues and introduced HTML to PDF capabilities in File System connector. To learn how to upgrade, follow the [upgrade guide here](/flow-connect/working-with-connect/connect-to-systems/connector-agents/manage-agent.md#upgrade-agent)
* **File system Connector**
  * New [operations](/flow-connect/working-with-connect/connect-to-systems/connectors/file-system.md#operations) added
    * [HTML to PDF](/flow-connect/reference/reference/flowscript/walkthrough/filesystem-module.md#converthtmltopdf)
    * [Merge PDF](/flow-connect/reference/reference/flowscript/walkthrough/filesystem-module.md#mergetwopdfs)
  * Please ensure that both the Connector Agents and Flow Designer are updated to their latest versions.
    * Connector Agent V 1.0.0.665
    * Flow Designer V1.0.0.180
## 2025-08-26
### New import functionality available as a beta release in the Hub
The ability to import workflows from Flow Classic—previously only available in Windows Designer—is now available in the Hub. The new import wizard adds functionality for migrating machine steps that use the IFS OData connector into IFS OData modules. It also supports importing individual Flow files (.flow).
We are especially interested in your feedback on using the new import wizard for **OData workflows**, so please share your experiences with us.
Migration of IFS OData connectors is only supported by the new import wizard in the Hub. The existing import functionality in Windows Designer will be removed in a future release.
#### IFS OData Code Generation
Several improvements and fixes have been made to the built-in IFS OData code generation capabilities. OData queries now support:
* Group By
* Aggregation (SUM)
* Aliases for columns/properties
**Bug fixes**
* Custom fields were missing in the returned results.
* Missing parentheses in the IN operator.
#### Import Classic OData workflows
The import wizard has been improved with multiple fixes and enhancements based on findings from early tests:
* Migration of iterators
* Migration of Group By and Aggregation
* Filters for navigation properties ($expand)
* Improved migration of functions and actions
The new import wizard and the updated version of IFS OData code generation rely on new features introduced in FlowScript. This means you must run Connector Agent version **1.0.0.614** or later.
### **New in Clients and Designer**
#### **Sync Work – Offline capability completed**
This release includes Queue Lanes in the Designer and extends Local Data with Sync Work in the clients. With this release, Flow Connect becomes fully offline-capable.
The My Data section in Flow Clients is now available whenever apps use either Local Data (preloaded resources) or Sync Work (configured in queue lanes in the Designer). Local Data ensures that the required information is available on the device, while Sync Work manages transactions created offline and synchronizes them once the device is online again.&#x20;
More information:
* [My Data](/flow-connect/reference/reference/clients/my-data.md)
* [Queue lane](/flow-connect/reference/reference/designer/queue-lane.md)
* [How to create an offline App](/flow-connect/reference/how-to-guides/offline-create-and-run-an-app.md)
## 2025-08-20
### New in Portal
#### New portlet: Map
We are pleased to announce the arrival of the Map portlet in the Connect portal. This portlet provides a geographical map with support for markers, static overlays, and interactive capabilities.\
Read more about the Map portlet [here](/flow-connect/reference/reference/portal/design-items/portlets/map.md).
#### Print custom content portlet
The Custom Content portlet can now be printed to PDF. A new advanced setting, Enable Print, has been added. If enabled, the end user will see a Print option in the context menu (the three dots in the portlet header).
#### Language switcher
A language switcher is now available under the user profile. The selected language will be cached in the browser.
### Fixes
* Improved table row selection colors.
* Fixed an issue where external links in the Custom Content portlet did not open the target page.
## 2025-08-18
### Fixes
**Android:**
* Enabled edge-to-edge display, allowing toolbars and the navigation bar to extend to the screen edges.
* Adjusted icon colors in the status bar for higher contrast with the background.
* Fixed an issue where the on-screen keyboard would remain open.
* Fixed a bug that prevented the language from changing in a paused application.
* General bug fixes.
**iOS:**
* Fixed a bug that prevented translations from applying correctly in the search, profile, and settings views.
* Added missing translations for existing languages.
**Web:**
* Added camera support for the Windows client.
* Fixed an issue where high-resolution images could extend beyond the boundaries of the image control.
* Fixed a missing icon for the camera control.
## 2025-08-14
### Connector Agent **v1.0.0.614** is released
With the release of **Connector Agent v1.0.0.614**, we've addressed several issues and introduced new features. To learn how to upgrade, follow the [upgrade guide here](/flow-connect/working-with-connect/connect-to-systems/connector-agents/manage-agent.md#upgrade-agent)
    * [Get Sub Directory Names](/flow-connect/reference/reference/flowscript/walkthrough/filesystem-module.md#getsubdirectorynames)
    * [Write Text](/flow-connect/reference/reference/flowscript/walkthrough/filesystem-module.md#writetext)
    * [Write Binary](/flow-connect/reference/reference/flowscript/walkthrough/filesystem-module.md#writebinary)
    * [Append Text](/flow-connect/reference/reference/flowscript/walkthrough/filesystem-module.md#appendtext)
    * [Add Folder to ZIP](/flow-connect/reference/reference/flowscript/walkthrough/filesystem-module.md#addfoldertozip)
    * [Extract from ZIP](/flow-connect/reference/reference/flowscript/walkthrough/filesystem-module.md#extractfromzip)
    * [Combine Paths](/flow-connect/reference/reference/flowscript/walkthrough/filesystem-module.md#combinepath)
    * Connector Agent V 1.0.0.614
    * Flow Designer V1.0.0.177
**Breaking Change:** The **Write** operation in the File System connector has been replaced with two distinct operations:
* [Write Text](/flow-connect/reference/reference/flowscript/walkthrough/filesystem-module.md#writetext) – for writing text content to files
* [Write Binary](/flow-connect/reference/reference/flowscript/walkthrough/filesystem-module.md#writebinary) – for writing binary content to files
This change affects **only apps using the Write operation in previous versions**. Update them to use either Write Text or Write Binary based on the data type.
* **IFS10 Connectors**
  * The user executing the Flow App is available in both the Initialization and Cleanup commands as **:username** bind variable.
* **Microsfot SQL Server Connector**
  * The user executing the Flow App is available in both the Initialization and Cleanup commands as **@username** bind variable.
## 2025-07-08
### Fixes
#### Clients
* Addressed issues with single list selection when no item is selected.
#### Web&#x20;
* Resolved a performance issue when opening list selections in full screen.
### Connector Agent **v1.0.0.572** is released
With the release of **Connector Agent v1.0.0.572**, we've addressed several issues and introduced new features. To learn how to upgrade, follow the [upgrade guide here](/flow-connect/working-with-connect/connect-to-systems/connector-agents/manage-agent.md#upgrade-agent)
  * New file system [operations](/flow-connect/working-with-connect/connect-to-systems/connectors/file-system.md#operations) added
    * [Write ](/flow-connect/reference/reference/flowscript/walkthrough/filesystem-module.md#write) - updated handling of optional parameters.
    * [Get Directories](/flow-connect/reference/reference/flowscript/walkthrough/filesystem-module.md#getdirectories)
    * [Get Files](/flow-connect/reference/reference/flowscript/walkthrough/filesystem-module.md#getfiles)
    * [Get File Names](/flow-connect/reference/reference/flowscript/walkthrough/filesystem-module.md#getfilenames)
    * [File exists](/flow-connect/reference/reference/flowscript/walkthrough/filesystem-module.md#fileexists)
    * [Copy File](/flow-connect/reference/reference/flowscript/walkthrough/filesystem-module.md#copyfile)
    * [Delete File](/flow-connect/reference/reference/flowscript/walkthrough/filesystem-module.md#deletefile)
    * [Move File](/flow-connect/reference/reference/flowscript/walkthrough/filesystem-module.md#movefile)
* **Oracle Database Connector**
  * The user executing the Flow App is available in both the Initialization and Cleanup commands as **:username** bind variable. This can be used to support scenarios where user impersonation is handled programmatically. [Read more](/flow-connect/working-with-connect/connect-to-systems/connectors/oracle.md#user-impersonation-in-ifs)
## 2025-07-03
### &#x20;Fixes
#### Android
* Corrected an issue when reloading local data
* Added support for auto-forward for image selection control
* Minor UX/UI adjustments
* Fixed Android 15 issue with on-screen navigation buttons
#### iOS
* When searching, you can now dismiss the keyboard by scrolling
* Fixed an issue where if you scrolled in the home view, it would cause a slight flickering
#### Web
* Multiline Text now expands up to 10 lines, then a scroll appears
* Sub workflows now support auto-reloading
* New visual design for settings/profile views
* Fixed an issue where the scroll bar would not appear after the image viewer is closed
## 2025-06-27
### Connector Agent **v1.0.0.540** is released
With the release of **Connector Agent v1.0.0.540**, we've addressed several issues and introduced new features. To learn how to upgrade, follow the [upgrade guide here](/flow-connect/working-with-connect/connect-to-systems/connector-agents/manage-agent.md#upgrade-agent)
* **IFS Cloud OData** - **Resolved** an issue that prevented handling of special fields such as `@odata.etag`, `@odata.context`, `@odata.id` etc..  in JSON responses.&#x20;
* **REST Connector**&#x20;
  * HTTP module now supports multipart content. [Read more](/flow-connect/reference/reference/flowscript/walkthrough/http-module.md#multipart-content)
  * Improved authentication performance by caching access tokens in the agent for both **Client Credentials** and **Password Credentials** authentication flows.
    * [Write ](/flow-connect/reference/reference/flowscript/walkthrough/filesystem-module.md#write)operation now supports binary data.
    * [Read Text](/flow-connect/reference/reference/flowscript/walkthrough/filesystem-module.md#readtext)
    * [Read Lines](/flow-connect/reference/reference/flowscript/walkthrough/filesystem-module.md#readlines)
    * [Read Binary](/flow-connect/reference/reference/flowscript/walkthrough/filesystem-module.md#readbinary)
  * Added support for UNC paths across all file system operations, enabling access to network shares and mapped drives.
* Connector Agent V 1.0.0.540
* Flow Designer V1.0.0.161
## 2025-06-23
### New in Portal
#### New type of event
A new event,  Share Data, has been added. This event sends data without triggering a refresh in the receiving portlet. Only Custom Content portlets can receive this event.
#### Interactions for Custom Content portlet
Interactions have been added to the Custom Content portlet. You can now configure click actions to run an app or component, or navigate to a Portal page. This makes it easy to add interactive behavior directly within your portlet.&#x20;
## 2025-06-03
## File system connector released
The first version of the File system connector has been released, and this version includes the following file system [operations](/flow-connect/working-with-connect/connect-to-systems/connectors/file-system.md#operations).
* Check if directory exists
* Create directory
* Write content to file
[Read more here...](/flow-connect/working-with-connect/connect-to-systems/connectors/file-system.md)
Please ensure that both the Connector Agents and Flow Designer are updated to their latest versions to use the File System Connector.
* Connector Agent V 1.0.0.502
* Flow Designer V1.0.0.158
## 2025-05-15
### Fixes
#### Android
* Added support for user-defined profiles for Honeywell scanners
* Fixed closing an inbox search not clearing the results
* Fixed an issue where the keyboard would hide the focused input field
#### iOS
* Added support for using defined profiles for Honeywell scanners
* Fixed the appearance of the "Recently run apps" header
* Fixed an issue where the pre-scrolled position in My data view was incorrect
* Fixed an issue where the bottom menu was being displayed in the organisation selection view
#### Web
* Fixed an issue where it was not possible to add a row with a different schema to a table
## 2025-05-07
## Automations Release
Automations have now been released in live, and the functionality this provides will greatly increase the usability of Flow Connect. &#x20;
As showcased in the recent [2025 Q1 Quarterly News](https://youtu.be/lYqmC34I1ds?t=246), the Automations feature is a direct replacement for machine workflows that you may be familiar with in the classic product.
Key Features:
* Enhanced scheduling functionality
* Fast and  Secure execution of webhooks
* Utilises asset components
* Integrate external systems directly with your ERP system
You can start using automations now by following the instructions in the [Automations documentation](/flow-connect/working-with-connect/create-and-design/automations.md).
## 2025-04-30
## New in Portal
#### My Apps portlet
The new My Apps portlet is now available in the Portal. It displays the apps a user has access to and can be configured to show either:
* All available apps, or
* Only those associated with the same package as the page where the portlet is placed.
From My Apps, users can quickly launch any of the listed apps.
For users familiar with Portal 1 in Flow Classic, My Apps replaces the Menu Portlet.
> Note: Inboxes are not yet included in the My Apps portlet.
#### **Smaller New Features**
* Custom Content - The code editor has been updated to use an expandable modal window.
* Custom Content - Event data can now be used in the presentation section. Data sent from portlets emitting events is now available to the custom content portlet. Use curly braces `{}` for autocomplete. Event data is prefixed with `Events`, e.g., `{Events.FieldName}`.
* Link - Buttons and tiles now have a new UI to align visually with the new My Apps portlet.
* Copy Input for Interactions - The function has been extended to Interactions.
* Share Function - Portal pages are now included in the Share feature available in the Hub.
## 2025-04-23
## New in Clients and Designer
The My Data section is now available for users with access to applications that utilize preloaded data via the new step Local data resources. This marks the first step toward enabling offline capabilities in Flow Connect, aligning with the functionality previously available in Flow Classic.
Preloaded data—referred to as Local data—is stored locally on the device and can be accessed both online and offline.
The second part of this functionality—uploading transactions created while offline—is currently under development.
See [My data](/flow-connect/reference/reference/clients/my-data.md) in the Reference section.
<figure><img src="https://1716064794-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FIIgl6sNaTky0iALxYWHH%2Fuploads%2Fc0BWVnPsJYfakjDMFSQN%2Fimage.png?alt=media&amp;token=e0a19af3-8a80-4b36-8b31-b26519f6840a" alt=""><figcaption></figcaption></figure>
## New in Designer
**FlowScript Copilot**&#x20;
FlowScript Copilot is an **AI-powered assistant** (chatbot) designed to support users in creating FlowScript code. It offers a Copilot-like experience specifically tailored to FlowScript, enabling users to:
1. Contextually aware, **FlowScript Copilot** is capable of handling conversations by retaining context from previous questions and answers.
2. FlowScript Copilot can interpret the user intent and provide a solution to the problem.
3. Access **syntax explanations** and **code examples**.
4. Use **"copy-paste" functionality** for code snippets.
5. Receive **real-time responses** to FlowScript queries.
6. Get **FlowScript function suggestions** as potential solutions to problems.
7. Provide feedback for continuous improvement.
***For a full walkthrough on how to use FlowScript Copilot, see*** [***Flowscript Copilot***](/flow-connect/reference/reference/flowscript-copilot.md) ***in the Reference section.***
### Fixes
* Fixed the "No matching machine step command found" issue when debugging a component from Designer.
* Corrected the issue of multiple lines appearing in the "single line" input TEXT field when scanning a QR code (Android and iOS).
* Fixed the issue where more than one pill in subtasks was connected to the same variable.
* Improved performance for scripting and modules.
## 2025-03-26
## New in Portal
#### Custom content portlet
The Custom content portlet allows users to create a customizable portlet using HTML and CSS. It supports styled content, enabling tailored presentation to fit specific needs. This is a merge of the HTML table and HTML advance portlets from Flow Classic.
See [custom content](/flow-connect/reference/reference/portal/design-items/portlets/custom-content.md).
<figure><img src="https://1716064794-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FIIgl6sNaTky0iALxYWHH%2Fuploads%2FCyHZp1ZiyIWhqK33Rx75%2Fimage.png?alt=media&amp;token=8939d1ea-7b10-491a-9dbf-123df2867ea4" alt=""><figcaption></figcaption></figure>
#### Drag and drop Table to Kanban
There is a new event type added to Kanban: drag-and-drop events from a table. This will enable a user to drag a row from a table portlet and drop it into the Kanban either as a new card or as an update in an already existing card. See [drag and drop Kanban](/flow-connect/reference/reference/portal/design-items/portlets/kanban.md#additional-event-in-kanban).
#### Copy input definition
A copy option has been added to the portlet datasource configuration to copy portlet input data from events. It helps determine the correct syntax for the Start Ring Input table, which can be cumbersome to write manually.
### Fixes
* Set the side navigator to open in an expanded state by default.
* Fixed the issue where global components were not usable by portlets.
* Data Tree – Add the ability to unselect a row.
* Document Viewer – Fix toggle error in configuration.
* Kanban – The minimum and maximum card values should be allowed to be the same.
* Kanban – Hide task counters in collapsed columns.
## 2025-03-04
### New version of agent manager & agent available
* Agent Manager **v1.0.0.304** - With this version onwards Agent Manager installations will display a notification at startup when a new version is available. Also the users can upgrade to the latest Agent Manager version with a single click, simplifying the update process.&#x20;
  <figure><img src="https://1716064794-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FIIgl6sNaTky0iALxYWHH%2Fuploads%2FRVIuKePhfvkd2oYOoBKJ%2Fimage.png?alt=media&amp;token=e709c476-52a3-41d7-b465-a8932a18ef21" alt="" width="309"><figcaption><p>Agent Manager update notification</p></figcaption></figure>
* Connector Agent **v1.0.0.309** - Upgraded engine parser version & flow script version.
## 2025-02-11
Added client support for improved backward compatibility, see the release note: New version of agent manager & agent available dated 2025-02-07.
### Fixes
* Fixed a memory leak issue that occurred in paused applications containing data grids.
**iOS:**
* Fixed an issue where an application package name would flicker when entered from the search view.
## 2025-02-07
* Agent Manager **v1.0.0.254** - resolved the issue that prevented the connector agents from installing/upgrading successfully on the first attempt.
* Connector Agent **v1.0.0.284** - improved **backward compatibility** with older client versions while providing greater tolerance for variations in request formats, allowing seamless communication across different iterations.
It’s crucial to update the Agent Manager and Connector Agents to the latest versions (**v1.0.0.254** & **v1.0.0.284**). This ensures improved backward compatibility, making future upgrades smoother while minimizing the risk of breaking changes.
### New in Portal
#### Link portlet
This release includes the preview version of a new portlet: Link. The Link portlet replaces the Workflow portlet in Portal 2, but it comes with more functionality, including the ability to navigate between portal pages and access external URLs.
See [Link](/flow-connect/reference/reference/portal/design-items/portlets/link.md).
<div align="left"><figure><img src="https://1716064794-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FIIgl6sNaTky0iALxYWHH%2Fuploads%2F8Qu6IjXlTzOlsbpjHGAw%2Fimage.png?alt=media&amp;token=511262bf-9682-4259-b683-d4eec4b71f81" alt=""><figcaption></figcaption></figure></div>
#### Other
* Added support for Interactive Authentication.
### Fixes
* Fixed issue with the toggle in portlet configuration
* In Kanban corrected the issue so min and max card values are be allowed to be the same
## 2025-01-21
### Fixes
#### Web
* If no organization logo is present, it will now default to a temporary logo.
* Resolved an issue that caused user applications to enter an incorrect operation state.
## 2025-01-14
### Fixes
#### Android
* Fixed an issue with the Signature Control in the Web Client where it was not displaying properly.
* Fixed an issue where the width of applications was inconsistent.
* Fixed an issue where Inbox error messages did not always appear.
* Fixed an issue where searching for an organization did not display the correct organization logo.
#### iOS
* Added support for iOS 18.
* Added missing translations for date and time controls.
* Fixed an issue where lists under the calendar control did not render properly.
* Fixed an issue where interactive authentication displayed "failed to authenticate" instead of "login was cancelled."
## 2025-01-08
### Hub improvements
* Added the ability to map script steps executed on connector agents during the import of shared applications.
### Hub fixes
* Fixed an issue where connector mapping could inadvertently affect other objects, such as variables, during the import of shared applications.
* Fixed some instances where the UI did not correctly reflect the user’s permissions.
## 2024-12-17
### New agent version available v1.0.0.199
* REST Connector - added support for Interactive Authentication (Open ID & OAuth2 Authorization Code Flow)
### **Fixes:**
**Web:**
* Fixed an issue where numeric fields would not handle non-US regions
**Android:**
* Fixed an issue where scanner wouldn't scan values after changing the view
**iOS:**&#x20;
* Fixed an issue in calendar control which caused added rows to appear cut-off
* Added missing Finnish translations to calendar and time input controls
## 2024-12-03
* Added search applications and pages in deployment overview.
* Introduced collapsible sections for applications and portal pages in the deployment overview.
* Highlighted version cards in deployment overview. When a specific version is deployed, it will be highlighted for a short period.
* Enhanced compatibility for extra query parameters in REST connector configurations.
### Hub fixes
* Fixed an issue where the user list did not refresh to reflect new changes.
## 2024-11-21
* Added support for extra query parameters in REST connector advanced configurations.
* Reordered the application contextual menu for improved usability.
## 2024-11-05
### Fixed in Clients
* Fixed an issue where barcode scanning events did not read values.
* Fixed an issue where assertion step messages did not appear when triggered by scanning events.
* Fixed an issue where uploaded files might be removed when navigating through user steps.
* Fixed an issue where the "force uppercase" option did not apply to scanned values.
* Improved error messages for cases when the client version is older than the published applications.
#### iOS
* Fixed an issue where rows below the calendar control were not rendered properly.
#### Web
* Fixed an issue where special scanning characters did not function correctly during scanning.
* Fixed an issue where the script dialogue did not display correct default values in diagnostic mode.
* Fixed an issue preventing application startup with optional parameters.
## 2024-10-24
### **New in Clients**
* Android - added support for Bluetooth Zebra scanners.
* Made it possible to use the output of an interaction item as an input to the source of Image Selection and File Gallery.
* Make it possible to start an application with parameters in diagnostic mode.
* Add refresh button to home view in web and Windows client.
### **Fixes in Clients**
* Resolve the issue where files used in pinned steps were under some circumstances removed.
* Resolve the issue where text in coloured Grids would not display properly.
* Resolve the issue where pinned steps would not be displayed.
## 2024-10-22
### **New**
The preview version of the Kanban portlet has now been released.
## 2024-10-15
### New
The Portal client has been released as a public Beta.&#x20;
The portal client is run in the browser and is supported on Google Chrome and Microsoft Edge browsers.&#x20;
## 2024-10-07
### New
* All clients now support both dark and light themes. Switching between themes is done under Settings. By default, the theme selected on the device is used for mobile clients, and the browser's theme is used for the web client.
### Fixes
* Resolved issue where pinned steps would overlap diagnostic panel while running diagnostic mode.
## 2024-09-27
### New agent version available v1.0.0.144
#### **Potential Breaking Change**
* Changes in how database connectors (IFS 10, Oracle & SQL Server) handle Schema/AppOwner parameters. Previously it was possible in database connectors to use a flow variable as Schema/AppOwner value.&#x20;
  <figure><img src="https://1716064794-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FIIgl6sNaTky0iALxYWHH%2Fuploads%2FkDD3FVBdFaTi0Hvwulpn%2Fimage.png?alt=media&amp;token=2f5fdb3f-5915-4ba0-9bfa-c42a7da6ba40" alt=""><figcaption><p>Schema/AppOwner as a variable</p></figcaption></figure>
  <figure><img src="https://1716064794-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FIIgl6sNaTky0iALxYWHH%2Fuploads%2Fz6Dqqu5WJn0jaU7EyIAC%2Fimage.png?alt=media&amp;token=318b0225-817e-46cd-9c35-83fa48cd33df" alt=""><figcaption><p>Use the flow variable as Schema/AppOwner</p></figcaption></figure>
* Starting from agent version **v1.0.0.144** this is no longer possible. You have to define the Schema/AppOwner parameter values in Connector Configuration itself.
  <figure><img src="https://1716064794-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FIIgl6sNaTky0iALxYWHH%2Fuploads%2FqZ65zFSuOrTFjosIjJBs%2Fimage.png?alt=media&amp;token=9e8c18ca-d609-4c49-a1d2-dd08b0b5279d" alt=""><figcaption><p>Define the Shema/AppOwner value</p></figcaption></figure>
* If any of your apps/components use "flow variable as Schema/AppOwner" syntax in database machine steps, here are the steps you can follow **before** upgrading the agents to the latest version **v1.0.0.144**.
  * In the Connector configurations define the value for Schema/AppOwner field for DEV/TEST/PROD environments. You can define the Schema/AppOwner value for IFS 10, Oracle and Microsoft SQL Server database connectors.
  * Replace {} syntax for Schema/AppOwner in database machine steps with {AppOwner} or {Schema} as shown below.
    <table><thead><tr><th width="363" align="center">Before</th><th align="center">After</th></tr></thead><tbody><tr><td align="center"><img src="https://1716064794-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FIIgl6sNaTky0iALxYWHH%2Fuploads%2F7DOl4Gvj3vbFSr966pO6%2Fimage.png?alt=media&amp;token=060d94d4-3aff-4017-9037-9bb1c30f5130" alt="" data-size="original"></td><td align="center"><img src="https://1716064794-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FIIgl6sNaTky0iALxYWHH%2Fuploads%2FKrKB54PH6SUTREeOwmkK%2Fimage.png?alt=media&amp;token=18ac48be-ca01-4a2a-91dc-26b45d88032e" alt="" data-size="original"></td></tr></tbody></table>
  * Save the changes in the app/component and finally deploy the changed apps to TEST/PROD as necessary.
### New in clients and designer
* Make it possible to use output of a interaction item as a input to source of List Selection, List Presentation, Menu Selection and Multi List Selection.&#x20;
* Make it possible to add images to rows in List Selection and Multi List Selection controls.&#x20;
* Make it possible to use binary files (jpeg, png and webp) as sources for images in List Selection, Multi List Selection, Image Selection and Image Viewer.
* Make it possible to use output for interaction item as a input to the condition to hide property for all controls.
* Make it possible to access scanner settings on Scanning devices
### Fixes in clients
#### All Clients
* Fix issue where user were unable to start a recent application under some conditions.
#### Web & Windows Client
* Fix blurbs alignment issues.&#x20;
* Fix issue where second binary option not being able to be clicked.
* Fix issue where spinner would be stuck when entering application complete step in diagnostic mode under some circumstances.
* Fix issue where trace logs from rest connectors was not parsed when a error occurred during execution.
#### Web & Windows & Android Client
* Fix issue where detail text was not displayed for selections in multi-list selection
#### Android Client
* Fixed issue where image annotation would crash the client when long pressing an image to edit
* Fixed issue where incorrect control would get focused when entering a user step
## 2024-09-11
### New
#### Hub
* Account type in the user list shows whether the user signed up with their email or Microsoft Entra ID account. If a user hasn’t signed in for some time (before this feature was added), the account type will be empty until the next time they sign in.
* “About” screen showing the dates and user information for asset creation, saving, and commits.
* "About" screen for application packages with creation and last modified details.
### Bug fixes
#### Hub
* Fixed an issue where asset cards remained continuously highlighted when navigating from search results.
## 2024-09-02
### New
* Added dependent controls feature to list and menu selection controls
### Bug fixes
#### Web:
* Fixed a bug which caused pill to count amount not updating when deleting a sub-task
* Fixed an issue in the diagnostic mode panel where the scroll didn’t behave as intended
* Fixed an issue where rest connector trace logs were not parsed correctly
* Fixed an issue where trace logs were not received on failure
## 2024-08-29
### New designer version 1.0.0.83
* Fixes an issue that prevented certain historical versions from being opened.
## 2024-08-23
### New agent version available v1.0.0.120
* Bug fix for Microsoft SQL Server Database connector to handle null value as parameter.
## 2024-08-21
### New feature
* Added support for modules in rest connector agents.
* Added support for DataLogic Scanner.
#### Web and Windows Client
* Added [Diagnostic mode](/flow-connect/reference/reference/diagnostic-mode.md#flowscript-evalutor)to diagnostic mode
* Improve look and feel of progress overlay when running application.
* Make it possible to trace HTTP call in rest connectors.
### Bug fixes
#### General
* Fix issue that occurred when last deployed app in package was removed.
* Fix issue where colouring of Grid was missing.
* Fix issue where tables from rest connector scripts would not work in Grid.
#### Web / Windows Client
* Fix issue in list control where header line were cut-off.
* Fix issue of translation not applying directly in home view
#### IOS
* Fix issue where clicking on column header in grid would scroll
* Fix issue where application package list would be stuck in the middle of the screen.
* Fix issue where reload in app package would not reload the apps.
#### Android
* Fix issue where user would be stuck in a loading state when searching apps in packages.
## 2024-08-20
### New agent version available v1.0.0.92
* Added Oracle connector, which supports version 12c and higher versions.&#x20;
* Enabled FlowScript module execution using the REST connector.&#x20;
* REST trace is enabled for the server side execution.
FlowScript modules on REST connector are dependent on Flow Designer changes. Make sure you [upgrade your agents](/flow-connect/working-with-connect/connect-to-systems/connector-agents/manage-agent.md#upgrade-agent) to v1.0.0.92 before upgrading to Designer v1.0.0.78 or later.
### New
* When an item in the Application Library is accessed from the Hub, a popup notification informs users that they need to install the Designer to open application items. The notification can be hidden by checking "Don't show again".
* Introducing a new, more compact design for the context menu in Hub, with menu items now consistently named and ordered for improved usability.
## 2024-06-24
## 2024-04-11 <a href="#id-2024-04-11" id="id-2024-04-11"></a>
#### New <a href="#new-6" id="new-6"></a>
#### **Agent Manager version - v1.0.0.184**
* Oracle database connector for Flow Connect - The Oracle Connector can be used to integrate with Oracle databases with version 12c and upwards.&#x20;
## 2024-06-24
### New feature
* A new, easy-to-configure [HTTP request](/flow-connect/reference/reference/designer/steps/http-requests.md) step is now available in Flow Designer.
* The import wizard can now import machine workflows from Flow Classic as components in Connect.
* Images editing when uploading images or taking photos. Available in Android, iOS and Web clients.
### Bug fixes
#### Web
* List selection group headers now wrap over two lines.
* In Production, the environment type will not show, only the organisation name will be displayed.
* Added functionality so that clicking the organization logo navigates to the home view.
* Search now ranks results based on their relevance to the query. When searching within an application package, items within that package will take precedence.
* Corrected issue so icons for sub-tasks now display in the header.
* Corrected issue so reauthentication will no longer get stuck in an endless loop.
#### iOS
* Fixed an issue where grids would not respect the break mode.
* Fixed an issue where pinned steps would disappear when rotating the iPad.
#### Android
* Fixed an issue where Bluetooth devices would not connect due to permission issues.
## 2024-06-19
### New
#### General
* Reset the password for local member accounts. The login screen for email accounts contains a ‘Forgot password’ link that initiates the reset password process.
## 2024-06-04
### New feature
#### Windows client&#x20;
* Added the ability to resize the Diagnostic panel to allow for a more optimized work area.
### Bug fixes
#### Android client
* Added a delete row dialogue when pressing back.
* When searching, applications will now display the application package title instead of the description.
* Fixed an issue where Zebra scanners would not work.
* Fixed an issue where the sign-out dialogue would not sign out.
* Fixed an issue where favorited application’s title would not display entire letters if cut off.
* Fixed an issue where the delete button would not be displayed in sub-tasks.
* Fixed an issue where the inbox would not display a warning in certain cases.
#### iOS client
* Added pills in subtask inline header view.
* Corrected Search so empty application packages do not show in the search result.
* Added confirmation dialogue for signing out.
* Fixed issue where invalid input fields were cleared when rotating the device.
* Fixed an issue where accent icons would be blurry.
#### Web client
* Updateed the text in the new version of the client is available pop-up to say “Flow Connect” instead of “Application”.
* Fixed an issue where the Windows Client would not respect upper case.
* Fixed an issue where the calendar would shift by 1 day when reloading.
* Fixed an issue where sub-task icons were incorrectly coloured.
* Fixed an issue where the file gallery icon would overlap the text on certain screen sizes.
## 2024-05-27
### New
Added to the Diagnostic panel:
* the possibility to see UTF-8 characters below 127 as abbreviations or symbols in the variable section
* added sorting by time for log tracing
### Bug fixes
#### Client: Web/Windows client
* Fixed the total number of items displayed when searching in a list selection control.
* Fixed issue with list selection default selection still being highlighted when the user selects another value.
* Fixed issue with sub-task icons.
* Fixed checkboxes not being correctly colored and resized in the data grid control.
* Updated the UI for Application and Inbox cards
## 2024-05-23
### New
Added a Trace Tab in the Diagnostic Panel to enable developers to trace events during a diagnostic run. Users can now generate logs for the following events:
* Entering and Exiting Steps.
* HTTP Calls from the HTTP module in Flowscript.
## 2024-05-06
### New
Make it possible to pin variables over multiple application runs. A pinned variable will remain pinned until the user signs out, switches environments or unpin the variable.
### Bug fixes
Fix the issue where the diagnostic panel didn't refresh when entering or exiting sub-workflows.\
Fix the issue where selection did not persist on the scroll in the diagnostic panel.\
Fix the issue where switch environment was not highlighted properly.
## 2024-04-29
### New
#### Client: Windows client
Support has been added for the Signature control.
Input data entered when running a component in diagnostic mode is now stored in the session. This means that if the same component is run multiple times, the input data only needs to be entered once. If the input parameters are changed, click Reset to fetch the input parameters anew. Note that the input data is cleared upon resetting.
## 2024-04-25
### New
In diagnostic mode, it is now possible to pin variables, copy values, and export all. The search functionality has been improved to display all variables in the search results, and a collapse and expand button has been added for improved user-friendliness.
## 2024-04-24
### FlowScript Modules released
Enhance your development process with FlowScript modules, designed to facilitate the sharing of functions and types across all applications in a package or in your organization.
Read more about how to create and manage modules [here](/flow-connect/working-with-connect/create-and-design/modules/create-module.md) and new FlowScript features related to modules in the [reference](/flow-connect/reference/reference/flowscript/walkthrough/custom-modules.md).
## 2024-04-11
### New
#### Agent Manager version - v1.0.0.163
* The default value for no of days we keep the agent logs has been reduced to 7 days from 60 days. This is only applicable for new agent installations. If you like to change the default value for existing agents follow the steps described [here](/flow-connect/working-with-connect/connect-to-systems/connector-agents/manage-agent.md#configure-agent-logs).&#x20;
## 2024-04-09
### Bugs
**Client:  Web**
* Added toggling between home and settings/info views
**Client:  iOS**
* Fixed an issue where uploaded images to the file gallery caused images to become black
## 2024-04-02
### New
**Client: Android, iOS, Web, Windows**
* Added contextual menu to inboxes
## 2024-03-27
### Bug fixes
* Fixed issue with caching variables in grids&#x20;
## 2024-03-21
### New
#### Connector agent - v1.0.0.59
* Multiple bug fixes for IFS 10 Database connector
## 2024-03-19
### New
#### Hub
* New Hub home page.
* Web Client link in the hub menu.
* Delete Organization components.
### Bug fixes
* "Recently opened" section on home page also includes Organization components.
* Error message when trying to create a new connector configuration if there are no agents.
## 2024-03-14
### New
#### General
* New Sign In and Sign Up pages.
* Separate user journeys for signing in and signing up.
* Select account when user is logged in to more than one.
### Bug fixes
* Prevent invited users to sign in before signing up.
* Deep links in Hub.
## 2024-03-11
### New
#### Hub
* Re-invite users. Send invitation email again for users in status 'Pending'.
#### Windows Designer (version 0.0.6.209):
* Welcome page if opened without apps or components.
* Navigator is back!
* Option for downloading Diagnostic client if it's not installed.
#### FlowScript
* New FlowScript functions in [Seq module](/flow-connect/reference/reference/flowscript/walkthrough/seq-module.md). Added `takeWhile`, `skipWhile`, `orderBy`, `groupBy`, `orderByDescending` and `indexed`. Read more in FlowScript documentation.
### **Bug fixes**
* Support for transparent backgrounds for Organization logos.
* Performance improvements for showing component dependencies in Hub.
* Huge FlowScript performance improvement for auto complete.\ <br>
## 2024-02-13
### **New**
#### **Hub**
* Connector configuration dependent fields - For Authentication Type in the REST connector configuration, the UI will now dynamically show the inputs depending on the selected type.
* Local auto save in Windows Designer. If the Designer quits unexpectedly you will be prompted to restore unsaved changes if there are no conflicts.
* FlowScript Playground improvements - Save result as a variable and copy result type.
### **Bug fixes**
* Test and Prod environments not visible in variables page for users without end user permissions.
* Error in Windows Designer when opening an app from version history.
* Direct links to a page in Hub do not work.<br>
## 2024-01-30&#x20;
### New&#x20;
* Multi tenant login supported. Customers using Microsoft Entra ID (Azure Active Directory) will be able to sign in and sign up using the single Microsoft Account button.&#x20;
### Bug fixes&#x20;
* Errors in Connector Configuration screen will be shown in Hub<br>
## 2024-01-16&#x20;
### New&#x20;
#### Hub
* Tagging System for Organization and App Package Components&#x20;
* Filter Components by Tags and Text&#x20;
* Show Connector Agents for Agent Group
* New Application Cards UI
<br>
GET https://docs.novacura.com/flow-connect/this-is-flow-connect/whats-new/change-log.md?ask=<question>&goal=<user_goal>
