> For the complete documentation index, see [llms.txt](https://docs.novacura.com/flow-connect/llms.txt). Markdown versions of documentation pages are available by appending `.md` to page URLs; this page is available as [Markdown](https://docs.novacura.com/flow-connect/reference/how-to-guides/create-user-step-controls/static-text.md). Agents can also search and read this documentation through its [MCP server](https://docs.novacura.com/flow-connect/~gitbook/mcp).
# Static text
This guide will take you through how to set up a static text.
## Add a Static Text
   2. Add a Static Text.
   3. In Text, write “This static text field was created on {now()} | with a pipeline break".
   4. Click the **Play** button in the top right-hand corner to run the application in diagnostic mode.
   <figure><img src="https://1716064794-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FIIgl6sNaTky0iALxYWHH%2Fuploads%2FZKA2IbitHXGnfGKinfpz%2FWith%20border.png?alt=media&amp;token=6249da67-e707-4654-8441-e0e8f0ccbf1b" alt=""><figcaption><p>You will see todays date and time.</p></figcaption></figure>
2. Go back to the Designer.
   1. In the Condition To Hide, write “{userId = “*your user id”*} *(the user Id you log on with)*
   <figure><img src="https://1716064794-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FIIgl6sNaTky0iALxYWHH%2Fuploads%2FoHGixRKhz7mCgFwRtmor%2FWith%20border.png?alt=media&amp;token=fabf8a31-f25e-4599-9864-41bbd0010540" alt=""><figcaption><p>The static text is now hidden since the condition is fulfilled.</p></figcaption></figure>
GET https://docs.novacura.com/flow-connect/reference/how-to-guides/create-user-step-controls/static-text.md?ask=<question>&goal=<user_goal>
