> For the complete documentation index, see [llms.txt](https://docs.novacura.com/flow-connect/llms.txt). Markdown versions of documentation pages are available by appending `.md` to page URLs; this page is available as [Markdown](https://docs.novacura.com/flow-connect/reference/how-to-guides/create-user-step-controls/text-input.md). Agents can also search and read this documentation through its [MCP server](https://docs.novacura.com/flow-connect/~gitbook/mcp).
# Text input
This guide will take you through how to set up a text input.
## Add a text input
   2. Add a Text input.&#x20;
   3. In the Target Variable, write color.
   4. Under Appearance, in Prompt, write "Write a color".
   5. In Default Text, write "Blue".
   6. Under Behaviour, check the boxes "Force Uppercase", "Enable Text Correction" and "Trim Input Automatically".&#x20;
   7. Click the **Play** button in the top right-hand corner to run the application in diagnostic mode.
   <figure><img src="https://1716064794-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FIIgl6sNaTky0iALxYWHH%2Fuploads%2FBo5mVznS6hIBw2zcIujW%2FText%20input.png?alt=media&amp;token=71e8b1f4-f558-4136-987e-9aec96409590" alt=""><figcaption><p>Notice that the default text shows as BLUE even though we wrote Blue, since we checked the "Force Uppercase" checkbox. </p></figcaption></figure>
2. Go back to the Designer.
   <figure><img src="https://1716064794-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FIIgl6sNaTky0iALxYWHH%2Fuploads%2FoHGixRKhz7mCgFwRtmor%2FWith%20border.png?alt=media&amp;token=fabf8a31-f25e-4599-9864-41bbd0010540" alt=""><figcaption><p>The image is now hidden since the condition is fulfilled.</p></figcaption></figure>
GET https://docs.novacura.com/flow-connect/reference/how-to-guides/create-user-step-controls/text-input.md?ask=<question>&goal=<user_goal>
