> For the complete documentation index, see [llms.txt](https://docs.novacura.com/flow-connect/llms.txt). Markdown versions of documentation pages are available by appending `.md` to page URLs; this page is available as [Markdown](https://docs.novacura.com/flow-connect/this-is-flow-connect/technical-overview.md).
# Technical overview
Novacura Flow Connect has been built from the ground up as a cloud native product, based on a microservice architecture which provides scalability and redundancy.
Novacura Flow Connect was designed with security concerns at the forefront: runtime data is protected using per-organization encryption keys and system-wide authorization rules.
### System overview
The Novacura Flow Connect platform consists of the following parts:
* **Administration services**, where administrator users sign in to manage applications, users, groups and connectors.
* **Clients** for iOS, Android, Windows and Web, in which end users sign in and run the applications developed in Novacura Flow Connect. For client download links, refer to the [downloads page](https://docs.novacura.com/flow-connect/reference/flow-connect-downloads.md).
* **Runtime services**, which support the execution of applications in the clients. Physically and logically separated from the administration services, the Runtime services are designed for high availability under load.
* **Agents** which provide connectivity to external systems.
GET https://docs.novacura.com/flow-connect/this-is-flow-connect/technical-overview.md?ask=<question>&goal=<user_goal>
