> For the complete documentation index, see [llms.txt](https://docs.novacura.com/flow-connect/llms.txt). Markdown versions of documentation pages are available by appending `.md` to page URLs; this page is available as [Markdown](https://docs.novacura.com/flow-connect/working-with-connect/create-and-design/application-packages.md).
# Application packages
All applications are groped into application packages, similar to folders in the file system.  Packages contains applications, components, permissions and more.
## Create application package
1. Select **Apps** in Hub menu and select **Create Package**.
   <figure><img src="https://1716064794-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FIIgl6sNaTky0iALxYWHH%2Fuploads%2FN17NbxPOBtdQhq5HvMtH%2Fimage.png?alt=media&amp;token=b8c59734-aa4e-4488-9c8b-6b64614c678c" alt=""><figcaption></figcaption></figure>
2. Enter the name of the package.
3. Set the icon and color.
4. Select **Add developers** to add one or more groups. Members of the groups will have full access to the package and its content.&#x20;
5. **Save**.
   <div align="left"><figure><img src="https://1716064794-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FIIgl6sNaTky0iALxYWHH%2Fuploads%2FGe20rrAgfJWR3qZdutry%2Fimage.png?alt=media&amp;token=49f517f2-2f1b-49ae-b039-79f3443af168" alt="" width="263"><figcaption></figcaption></figure></div>
At least one access group needs to be assigned to the package.
## Edit application package
1. Hover over the app package card and the context menu will appear, click on **Edit**.
2. You can now change the title, icon, color and the assigned groups.&#x20;
## Delete application package
1. Hover over the app package card and the context menu will appear, click on **Delete**.
{% hint style="danger" %}
Deleting a package will also delete all of its content. This operation can not be undone.
## Application Library list view
The Application Library can be displayed as cards or as a sortable list. Use the view toggle in the top-right corner to switch between them.
In list view, your packages are shown in a table with the following columns:
* **Name** – sort packages alphabetically by selecting the column header.
* **Created** – who created the package and when.
* **Last Modified** – who last changed the package and when.
Search and the filter button are available in both views.
<div align="left" data-with-frame="true"><figure><img src="https://1716064794-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FIIgl6sNaTky0iALxYWHH%2Fuploads%2Fcv8KXZpE6fA23ahG1KS6%2FCleanShot%202026-06-15%20at%2014.29.34.png?alt=media&amp;token=b3c10741-8706-4f70-90d1-909c1439d9f5" alt="" width="563"><figcaption></figcaption></figure></div>
GET https://docs.novacura.com/flow-connect/working-with-connect/create-and-design/application-packages.md?ask=<question>&goal=<user_goal>
