> For the complete documentation index, see [llms.txt](https://docs.novacura.com/flow-connect/llms.txt). Markdown versions of documentation pages are available by appending `.md` to page URLs; this page is available as [Markdown](https://docs.novacura.com/flow-connect/reference/how-to-guides/create-user-step-controls/image-viewer.md). Agents can also search and read this documentation through its [MCP server](https://docs.novacura.com/flow-connect/~gitbook/mcp).
# Image viewer
This guide will take you through how to set up an image viewer.
## Add an image viewer
   2. Add an Image Viewer.
   3. In the URL, add the link "<https://is1-ssl.mzstatic.com/image/thumb/Purple112/v4/fc/e2/56/fce256cf-05e5-9efa-0df1-a28a24c820bb/AppIcon-0-1x_U007emarketing-0-0-0-7-0-0-85-220.png/512x512bb.jpg>"
   4. Click the **Play** button in the top right-hand corner to run the application in diagnostic mode.
   <figure><img src="https://1716064794-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FIIgl6sNaTky0iALxYWHH%2Fuploads%2F4RhGBvz9jZULXgewk3Zz%2FImage%20viewer.png?alt=media&amp;token=6fc52758-2d34-4e32-8124-613041f1dd52" alt=""><figcaption></figcaption></figure>
2. Go back to the Designer.
   <figure><img src="https://1716064794-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FIIgl6sNaTky0iALxYWHH%2Fuploads%2FoHGixRKhz7mCgFwRtmor%2FWith%20border.png?alt=media&amp;token=fabf8a31-f25e-4599-9864-41bbd0010540" alt=""><figcaption><p>The image is now hidden since the condition is fulfilled.</p></figcaption></figure>
GET https://docs.novacura.com/flow-connect/reference/how-to-guides/create-user-step-controls/image-viewer.md?ask=<question>&goal=<user_goal>
