> For the complete documentation index, see [llms.txt](https://docs.novacura.com/flow-connect/llms.txt). Markdown versions of documentation pages are available by appending `.md` to page URLs; this page is available as [Markdown](https://docs.novacura.com/flow-connect/reference/how-to-guides/create-user-step-controls/labelled-static-text.md). Agents can also search and read this documentation through its [MCP server](https://docs.novacura.com/flow-connect/~gitbook/mcp).
# Labelled static text
This guide will take you through how to set up a labelled static text.
## Add a Labelled Static Text
   2. Add a Labelled Static Text.
   3. In the Label, write "This is the label header".&#x20;
   4. In Text, write “I, {userId}, created this labelled static text".
   5. Check the “Use large font” checkbox
   6. Click the **Play** button in the top right-hand corner to run the application in diagnostic mode.
   <figure><img src="https://1716064794-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FIIgl6sNaTky0iALxYWHH%2Fuploads%2FN3dNI37RVzigtomlO7uJ%2FWith%20border.png?alt=media&amp;token=df71f6f5-a26f-4813-883e-8f4a81e6e43c" alt=""><figcaption><p>You will see your own userId.</p></figcaption></figure>
2. Go back to the Designer.
   1. In the Condition To Hide, write “{userId = “*your user id”*} *(the user Id you saw in the static text in the first part)*
   <figure><img src="https://1716064794-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FIIgl6sNaTky0iALxYWHH%2Fuploads%2FoHGixRKhz7mCgFwRtmor%2FWith%20border.png?alt=media&amp;token=fabf8a31-f25e-4599-9864-41bbd0010540" alt=""><figcaption><p>The labelled static text is now hidden since the condition is fulfilled.</p></figcaption></figure>
GET https://docs.novacura.com/flow-connect/reference/how-to-guides/create-user-step-controls/labelled-static-text.md?ask=<question>&goal=<user_goal>
