> For the complete documentation index, see [llms.txt](https://docs.novacura.com/flow-connect/llms.txt). Markdown versions of documentation pages are available by appending `.md` to page URLs; this page is available as [Markdown](https://docs.novacura.com/flow-connect/reference/how-to-guides/create-user-step-controls/binary-option-input.md). Agents can also search and read this documentation through its [MCP server](https://docs.novacura.com/flow-connect/~gitbook/mcp).
# Binary option input
This guide will take you through how to set up a binary option input.
## Add a binary option box input
   2. Add a Binary option input.&#x20;
   3. In the Target Variable, write "under50".
   4. Under Appearance, in Option 1 Text, write "I am under 50 years old".
   5. In Option 2 Text, write "I am 50 years old or older".
   6. Under Behaviour, set the Option 1 Value to "yes".
   7. Set the Option 2 Value to "no".
   8. Set the Default Value to {"yes"}.
   9. Click the **Play** button in the top right-hand corner to run the application in diagnostic mode.
   <figure><img src="https://1716064794-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FIIgl6sNaTky0iALxYWHH%2Fuploads%2FLT5ava5Vy56QbL4gRbVc%2Fcheckbox.png?alt=media&amp;token=dbd9756c-0749-47c1-80c3-1aa3f938176b" alt=""><figcaption></figcaption></figure>
2. Go back to the Designer.
   <figure><img src="https://1716064794-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FIIgl6sNaTky0iALxYWHH%2Fuploads%2F30JbA6gLpdXaMHuSOvLR%2FWith%20border.png?alt=media&amp;token=589bec14-8458-499f-ac8b-73b3da8387ab" alt=""><figcaption><p>The options are now hidden since the condition is fulfilled.</p></figcaption></figure>
GET https://docs.novacura.com/flow-connect/reference/how-to-guides/create-user-step-controls/binary-option-input.md?ask=<question>&goal=<user_goal>
