> For the complete documentation index, see [llms.txt](https://docs.novacura.com/flow-ifs-cloud-development-guidelines/llms.txt). Markdown versions of documentation pages are available by appending `.md` to page URLs; this page is available as [Markdown](https://docs.novacura.com/flow-ifs-cloud-development-guidelines/getting-started/setting-up-the-odata-connector/configure-connection-between-flow-server-and-ifs-cloud.md). Agents can also search and read this documentation through its [MCP server](https://docs.novacura.com/flow-ifs-cloud-development-guidelines/~gitbook/mcp).
# Configure connection between Flow Server and IFS Cloud
All flow servers and IFS Cloud instances that need to be connected are registered, registration of both systems can be done in any order.&#x20;
## Register Flow Server
Select ***Add Flow Server*** under ***Flow Server*** page.
<figure><img src="https://3323790987-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FJyIxKYxK0LMJ2T3XubCS%2Fuploads%2F3bGTC8dMcSYiirFZ32ka%2Fimage.png?alt=media&amp;token=66290f76-7a66-4daa-9642-bfaea5209d3a" alt=""><figcaption><p>Add new Flow Server</p></figcaption></figure>
1. Give Flow Servers URL, designated flow server user and password.&#x20;
2. Flow user can be machine user or other flow user with ***AdministerBasicData*** Access Level.
3. Select ***Create*** and Flow Server registration is done!
<figure><img src="https://3323790987-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FJyIxKYxK0LMJ2T3XubCS%2Fuploads%2F8SzXXQrvL3CIqPpB7M6W%2Fimage.png?alt=media&amp;token=41d4dc24-e538-482e-bb83-95b32583b1f2" alt=""><figcaption></figcaption></figure>
## Register IFS Cloud configuration
Select ***Add New*** under ***Configurations*** page.
<figure><img src="https://3323790987-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FJyIxKYxK0LMJ2T3XubCS%2Fuploads%2FW9n2RCVYwGkOYD5krelv%2Fimage.png?alt=media&amp;token=8d4c55d0-01ba-488d-9053-e3883d81a060" alt=""><figcaption><p>Add new IFS Could configuration</p></figcaption></figure>
### General -tab
* Name: name of the configuration
* Service URI: base path to IFS Cloud instance
* IFS Version: IFSCloud
* Break workflow on error is initially set to No. Read more from&#x20;
{% content-ref url="/pages/4cnXC7Qr69g7KQCt3XVh" %}
[Response status handling](https://docs.novacura.com/flow-ifs-cloud-development-guidelines/flow-development-with-odata/implementation/response-status-handling.md)
{% endcontent-ref %}
<figure><img src="https://3323790987-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FJyIxKYxK0LMJ2T3XubCS%2Fuploads%2FizojkDzDptOYS1N0UDvJ%2Fimage.png?alt=media&amp;token=5a9eeaaa-6b52-4b38-a5b7-cea1fa4c743b" alt=""><figcaption></figcaption></figure>
### Auth -tab
{% content-ref url="/pages/5kblTXgAtVDZrAh2hSyJ" %}
[Authentication models](https://docs.novacura.com/flow-ifs-cloud-development-guidelines/flow-development-with-odata/configuration/authentication-models.md)
### Miscellaneous -tab
WIP: not sure what these do.
<figure><img src="https://3323790987-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FJyIxKYxK0LMJ2T3XubCS%2Fuploads%2FyrG6bQAshKKsyderRb3B%2Fimage.png?alt=media&amp;token=dfa77e70-2e07-468d-a353-c3c6741258ef" alt=""><figcaption></figcaption></figure>
### Communication Log
Connector service can log all request that you can inspect from **Communication Log** page. Setup can be changed
<figure><img src="https://3323790987-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FJyIxKYxK0LMJ2T3XubCS%2Fuploads%2FmjWvVXL1UKZSv0Hoz3Tu%2Fimage.png?alt=media&amp;token=fb721b09-4acf-4955-aac2-8cea2df8640b" alt=""><figcaption></figcaption></figure>
In production configurations logging could be disabled to optimize Connector performance.
## What happens when you add new IFS Cloud configuration
1. After you save configuration and **Design time** authentication is correct, OData Connector service will automatically start loading all available projections from IFS. It may take few minutes to have the projection list ready. After initial upload all available projections can be browsed in\
   &#x20;
   <figure><img src="https://3323790987-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FJyIxKYxK0LMJ2T3XubCS%2Fuploads%2FO5vIGiP5HGdeVdyNxMPE%2Fimage.png?alt=media&amp;token=b79e14e6-6833-49c1-8e0e-cecf48263cf9" alt=""><figcaption></figcaption></figure>
2. After adding new configuration Re-register each Flow Server using new OData Configuration.
<figure><img src="https://3323790987-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FJyIxKYxK0LMJ2T3XubCS%2Fuploads%2Ftx89m80b1tbkMnMMzM2L%2Fimage.png?alt=media&amp;token=15c78b29-3ae7-4bc0-8e1e-4c429efdaa82" alt=""><figcaption></figcaption></figure>
OData Connector service will refresh projection list from IFS on regular basis (every hour?) to find new projections.&#x20;
## Deleting and modifying configurations
1. When you remove a configuration, it is not automatically deleted from flow server. You must Unregister one OData Connector from the flow server by executing Unregister. Notice that all OData connectors are removed.<br>
   <figure><img src="https://3323790987-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FJyIxKYxK0LMJ2T3XubCS%2Fuploads%2FDEtsueWed01HAL8HVdFV%2Fimage.png?alt=media&amp;token=15733fdd-56d8-4596-9b97-907b51862e6a" alt=""><figcaption></figcaption></figure>
2. Re-register the flow server in OData Connector and all connectors are restored to flow server.
3. If you modify configuration name, Re-rgister the Flow server.
GET https://docs.novacura.com/flow-ifs-cloud-development-guidelines/getting-started/setting-up-the-odata-connector/configure-connection-between-flow-server-and-ifs-cloud.md?ask=<question>&goal=<user_goal>
