> For the complete documentation index, see [llms.txt](https://docs.novacura.com/flow-ifs-cloud-development-guidelines/llms.txt). Markdown versions of documentation pages are available by appending `.md` to page URLs; this page is available as [Markdown](https://docs.novacura.com/flow-ifs-cloud-development-guidelines/flow-development-with-odata/configuration/projection-administration/administrating-updated-projections.md).
# Administrating updated projections
## OData connector and projection updates
Updated projections has to be manually refreshed in OData connector service.
Log into OData connector services, select the IFS Cloud enviorment from which projection needs updating.
<figure><img src="https://3323790987-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FJyIxKYxK0LMJ2T3XubCS%2Fuploads%2Fcw8AydBqe6sCLm72vY5r%2FUpd%20Projection.png?alt=media&amp;token=a548a9f5-8e8c-43e0-a40e-691786ce599d" alt=""><figcaption></figcaption></figure>
Select projection from list after which info about when the projection last been updated.
1. Select **Re-download**&#x20;
2. After reloading has finished select **Re-Compile**
<figure><img src="https://3323790987-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FJyIxKYxK0LMJ2T3XubCS%2Fuploads%2F75GLo31YfumGYIi7YW22%2Fimage.png?alt=media&amp;token=204c57fb-a3e6-4575-a933-6a3ab7d1d917" alt=""><figcaption></figcaption></figure>
In order to see the updated projection in Flow studio; refresh the projection list cache in the machine step where the updated projection is used. &#x20;
1. Open step, ***Refresh***&#x20;
2. Close the step with ***Cancel***
3. Reopen step&#x20;
<figure><img src="https://3323790987-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FJyIxKYxK0LMJ2T3XubCS%2Fuploads%2Fb9SsEoorTid8ZsG6yIAt%2FFrefresh%20cache.png?alt=media&amp;token=d35a9fc9-ea35-4d28-9e3a-2365e70c029c" alt=""><figcaption></figcaption></figure>
GET https://docs.novacura.com/flow-ifs-cloud-development-guidelines/flow-development-with-odata/configuration/projection-administration/administrating-updated-projections.md?ask=<question>&goal=<endgoal>
