> For the complete documentation index, see [llms.txt](https://docs.novacura.com/flow-ifs-cloud-development-guidelines/llms.txt). Markdown versions of documentation pages are available by appending `.md` to page URLs; this page is available as [Markdown](https://docs.novacura.com/flow-ifs-cloud-development-guidelines/flow-development-with-odata/configuration/authentication-models/setup-openid-flow.md).
# Setup OpenID flow
## Setup OData connector configuration
Select OpenId as Runtime authentication.
<figure><img src="https://3323790987-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FJyIxKYxK0LMJ2T3XubCS%2Fuploads%2FRq4P9ncWzY0mjzfDY8VP%2Fimage.png?alt=media&amp;token=ecc00ebf-0c02-4805-8961-535d052c0599" alt=""><figcaption></figcaption></figure>
## Flow Server OpenId configuration
### Create IFS IAM Client
Create IAM Client with same setup as in example below.&#x20;
Name IAM client so that it can be identified as being used by Flow. Also adding postfix describing authentication type would be a good idea.
Example name: NC\_Flow\_OpenId or Novacura\_OpenId
<figure><img src="https://3323790987-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FJyIxKYxK0LMJ2T3XubCS%2Fuploads%2F2TbhDikInRTzir5WVL35%2Fimage.png?alt=media&amp;token=6c9dcad6-dffe-4549-8f3e-94fa44fe4377" alt=""><figcaption><p>Example IAM client for supporting OpenId</p></figcaption></figure>
Use same name for same type of IAM client in all customers IFS Cloud instances.
### Setup OpenId in Flow Server
Add **Authority URL** and **ClientId** based on IFS Cloud info.
All the rest configurations can set as in example below.
<figure><img src="https://3323790987-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FJyIxKYxK0LMJ2T3XubCS%2Fuploads%2FSrCkgQY0wc65Vq8awPcK%2Fimage.png?alt=media&amp;token=e145240b-9834-480d-a6c5-689aa13f1ef9" alt=""><figcaption><p>Example OpenId configuration in Flow Server</p></figcaption></figure>
#### AuthorityURL
Get **Issuer URL** value from IFS Cloud.
{% content-ref url="/pages/pehKlFbKxppGwLyn2F5y" %}
[Obtaining Authentication related URLs from IFS Cloud](https://docs.novacura.com/flow-ifs-cloud-development-guidelines/flow-development-with-odata/configuration/authentication-models/obtaining-authentication-related-urls-from-ifs-cloud.md)
{% endcontent-ref %}
#### ClientId
Add previously created IAM Client Id.
## IFS User and Flow Server User Setup
Flow User ID must be same as IFS Users Directory Id
<figure><img src="https://3323790987-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FJyIxKYxK0LMJ2T3XubCS%2Fuploads%2FQtl6hdBS5AHPhEoH4Cfa%2Fimage.png?alt=media&amp;token=9333de6e-d567-4a4b-be8b-88728a45738a" alt=""><figcaption><p>IFS User setup</p></figcaption></figure>
<figure><img src="https://3323790987-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FJyIxKYxK0LMJ2T3XubCS%2Fuploads%2F9C4DDh40cSqQQdf90KrQ%2Fimage.png?alt=media&amp;token=829378c1-806c-47f7-8af1-b65cc78f846b" alt=""><figcaption><p>Same user in flow server</p></figcaption></figure>
If users are synchronized to Flow Server from Azure AD, follow instructions
<https://help.novacuraflow.com/development/flow-studio/environment/active-directory-sync>
**OPEN ISSUE: If synchronization is set up, is there any effect in having "Use sync source for authentication" checked which is automatically set up during synchronization???**
![](https://3323790987-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FJyIxKYxK0LMJ2T3XubCS%2Fuploads%2FlM8cPO42AEzksdq7nEPt%2Fimage.png?alt=media\&token=fbce60d5-6168-493e-b25d-0640693c0449)
## WIP - Effect to Flow development
Flow apps using connector with Runtime authentication type OpenId authentication cannot be debugged in Studio.&#x20;
For flow developer this means that prior debugging connector in flow must be changes to connector using Runtime authentication type of Client Credentials or Password Credentials. Alternatively, if flow has a lot of fragments and changing the connectors in all fragments takes a lot of time you can have copy of the flow (+ fragments) using connector using Runtime authentication type of Client Credentials or Password Credentials.
Notice that possible to have connector using Password Credentials requies that IFS User has password defined in IFS and SSO login is disabled.
If flow uses projections that require authentication as actual user in IFS, then debugging can only be done by running tests in NC client.
GET https://docs.novacura.com/flow-ifs-cloud-development-guidelines/flow-development-with-odata/configuration/authentication-models/setup-openid-flow.md?ask=<question>&goal=<user_goal>
