> For the complete documentation index, see [llms.txt](https://docs.novacura.com/flow-ifs-cloud-development-guidelines/llms.txt). Markdown versions of documentation pages are available by appending `.md` to page URLs; this page is available as [Markdown](https://docs.novacura.com/flow-ifs-cloud-development-guidelines/flow-development-with-odata/configuration/configuring-projections-in-ifs/quick-reports.md).
# Quick Reports
Quick reports allows you to create Quick Reports and publish them as new Projection which can used in Read-operation in flow.&#x20;
<figure><img src="https://3323790987-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FJyIxKYxK0LMJ2T3XubCS%2Fuploads%2FalWYGUdulz7LgK7GX68N%2Fimage.png?alt=media&amp;token=3030deee-72c2-4163-9567-21f6484f3335" alt=""><figcaption><p>Published QR</p></figcaption></figure>
Once published, IFS generated projection with QuickReport\<sequence number>.
Read detailed configuration instructions from IFS documentation, search for **quick reports.**
Few notes about building quick report
* do not use schema owner when referencing to database objects
* do not use ; in the end
* SQL-query is stored in oracle in CLOB column = no restrictions on size of the report&#x20;
&#x20;
&#x20;
GET https://docs.novacura.com/flow-ifs-cloud-development-guidelines/flow-development-with-odata/configuration/configuring-projections-in-ifs/quick-reports.md?ask=<question>&goal=<endgoal>
