> For the complete documentation index, see [llms.txt](https://docs.novacura.com/flow-connect/llms.txt). Markdown versions of documentation pages are available by appending `.md` to page URLs; this page is available as [Markdown](https://docs.novacura.com/flow-connect/working-with-connect/connect-to-systems/timezone-handling.md).
# Timezone Handling
### Database Connectors
Flow Connect represents every date/time internally as calendar date + clock time + UTC offset (i.e., an offset-aware timestamp). Many external databases however use offset-naïve types (datetime objects that lack any timezone information)
* **Oracle:** `DATE`, `TIMESTAMP`
* **SQL Server:** `datetime`, `datetime2`
* **IFS10:** `DATE`, `TIMESTAMP`
Because these formats lack time zone context, Flow Connect must:
* Assume a time zone when reading values from external sources.
* Optionally convert values into a target time zone when writing back to those systems.
#### Connector Configuration
To improve consistency in date/time handling, Flow Connect introduces new configuration options in database connectors.
<figure><img src="https://1716064794-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FIIgl6sNaTky0iALxYWHH%2Fuploads%2F216PvpqgZctFQxJzoLPB%2Fimage.png?alt=media&amp;token=87bc372d-3b24-4137-827b-479d54f14a8c" alt="" width="563"><figcaption></figcaption></figure>
#### **Time Zone**
* Purpose: Defines the target time zone for the connected database.
* Configuration: Select the appropriate time zone from the dropdown list.
  * Default: Connector Agent’s time zone
  * Custom: Choose the external database’s time zone if known
* Behavior When Reading Values
  For offset‑naïve types (e.g., Oracle `DATE`, SQL Server `datetime`, IFS10 `DATE`), Flow Connect interprets values in the configured time zone. Daylight Saving Time adjustments are applied automatically.
* Behavior When Writing Values
  Controlled by the **Date/Time Input Parameter Behavior** setting:
  * Pass through: default option where the values are sent exactly as provided, with no conversion.
  * Convert to configured time zone: All date/time input parameters are converted to the selected time zone before execution. Useful when your database stores date/time without offsets but you want them normalized to a specific zone (e.g., `Etc/UTC`).
#### Behavior Matrix
Use this matrix to predict read/write behavior based on the database column type and the chosen connector configuration.
{% tabs %}
{% tab title="IFS 10" %}
**Offset-aware** data types:
IFS 10 lacks support for offset-aware timestamp data types, due to limitations in the .NET Access Provider.
**Offset-naïve** data types:
* `DATE`&#x20;
* `TIMESTAMP`
<table><thead><tr><th width="109.6348876953125">Operation</th><th width="251.635009765625">Connector Configuration</th><th>Behaviour</th></tr></thead><tbody><tr><td>Read</td><td><div><figure><img src="https://1716064794-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FIIgl6sNaTky0iALxYWHH%2Fuploads%2FIOxgotyDoJeFDke7kCmd%2Fimage.png?alt=media&amp;token=cc2d23ce-c09e-44ae-899e-be3e7effba86" alt="" width="329"><figcaption></figcaption></figure></div></td><td>Interpreted in connector agents time zone (Daylight saving time aware) to produce an offset-aware value in Flow Connect.</td></tr><tr><td>Read</td><td><div><figure><img src="https://1716064794-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FIIgl6sNaTky0iALxYWHH%2Fuploads%2FmXOll7fWIQX6RBXieiXh%2Fimage.png?alt=media&amp;token=c433cbcf-93a8-4418-9c82-d57010c56b23" alt=""><figcaption></figcaption></figure></div></td><td>Interpreted in connector configured time zone (Daylight saving time aware) to produce an offset-aware value in Flow Connect.</td></tr><tr><td>Write</td><td><div><figure><img src="https://1716064794-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FIIgl6sNaTky0iALxYWHH%2Fuploads%2FMwRFN59TNVwwv2AoGb3P%2Fimage.png?alt=media&amp;token=3a24a9cc-c152-4d1e-b102-2ca1e699f9a9" alt=""><figcaption></figcaption></figure></div></td><td>Values are sent as given (including offset). No conversion</td></tr><tr><td>Write</td><td><div><figure><img src="https://1716064794-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FIIgl6sNaTky0iALxYWHH%2Fuploads%2F8mOrpFXImmebZEaR5OTb%2Fimage.png?alt=media&amp;token=2cc77f20-6339-4a13-9ef9-20c17ed91248" alt=""><figcaption></figcaption></figure></div></td><td>Flow Connect converts inputs to connector configured time zone (including offset). It can be the connector agent's time zone or any other time zone value set in the connector.</td></tr></tbody></table>
{% endtab %}
{% tab title="Oracle" %}
* `TIMESTAMP WITH TIME ZONE`&#x20;
* `TIMESTAMP WITH LOCAL TIME ZONE`
<table><thead><tr><th width="109.6348876953125">Operation</th><th width="251.635009765625">Connector Configuration</th><th>Behaviour</th></tr></thead><tbody><tr><td>Read</td><td><div><figure><img src="https://1716064794-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FIIgl6sNaTky0iALxYWHH%2Fuploads%2FIOxgotyDoJeFDke7kCmd%2Fimage.png?alt=media&amp;token=cc2d23ce-c09e-44ae-899e-be3e7effba86" alt="" width="329"><figcaption></figcaption></figure></div></td><td>Flow Connect uses the stored offset. Time zone settings in the connector is ignored</td></tr><tr><td>Read</td><td><div><figure><img src="https://1716064794-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FIIgl6sNaTky0iALxYWHH%2Fuploads%2FmXOll7fWIQX6RBXieiXh%2Fimage.png?alt=media&amp;token=c433cbcf-93a8-4418-9c82-d57010c56b23" alt=""><figcaption></figcaption></figure></div></td><td>Flow Connect uses the stored offset. Time zone settings in the connector is ignored</td></tr><tr><td>Write</td><td><div><figure><img src="https://1716064794-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FIIgl6sNaTky0iALxYWHH%2Fuploads%2FMwRFN59TNVwwv2AoGb3P%2Fimage.png?alt=media&amp;token=3a24a9cc-c152-4d1e-b102-2ca1e699f9a9" alt=""><figcaption></figcaption></figure></div></td><td>Values are sent as given (including offset). No conversion</td></tr><tr><td>Write</td><td><div><figure><img src="https://1716064794-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FIIgl6sNaTky0iALxYWHH%2Fuploads%2F8mOrpFXImmebZEaR5OTb%2Fimage.png?alt=media&amp;token=2cc77f20-6339-4a13-9ef9-20c17ed91248" alt=""><figcaption></figcaption></figure></div></td><td>Flow Connect converts inputs to connector configured time zone (including offset). It can be the connector agent's time zone or any other time zone value set in the connector.</td></tr></tbody></table>
* `DATE`&#x20;
* `TIMESTAMP`
* `TIMESTAMP WITHOUT TIME ZONE`&#x20;
{% endtab %}
{% tab title="SQL Server" %}
* `datetimeoffset`&#x20;
* `datetime`&#x20;
* `datetime2`&#x20;
{% endtab %}
{% endtabs %}
GET https://docs.novacura.com/flow-connect/working-with-connect/connect-to-systems/timezone-handling.md?ask=<question>&goal=<user_goal>
