Managing Connectors
Add connector
Select Connectors in Hub menu and select Add Connector.
Select your connector from the list. i.e. NiceLabel connector
Enter the name and optionally a description.
Provide the configuration values for the respective environments.
Refer to the Configuration Values section within each connector for details.
Click Save.
Edit connector
Hover over the connector card and the context menu will appear, select Edit.
You can now change or the configuration values for different environments.
Delete connector
Hover over the connector card and the context menu will appear, select Delete.
Confirm and the connector will be deleted.
