# Page Not Found
The URL `working-with-connect/connect-to-systems/managing-connector` does not exist. This page may have been moved, renamed, or deleted.
## Suggested Pages
You may be looking for one of the following:
- [Managing Connectors](https://docs.novacura.com/flow-connect/working-with-connect/connect-to-systems/managing-connectors.md)
- [Connectors](https://docs.novacura.com/flow-connect/working-with-connect/connect-to-systems/connectors.md)
- [Connect to systems](https://docs.novacura.com/flow-connect/working-with-connect/connect-to-systems.md)
- [Connector agents](https://docs.novacura.com/flow-connect/working-with-connect/connect-to-systems/connector-agents.md)
- [Binary File Handling](https://docs.novacura.com/flow-connect/working-with-connect/connect-to-systems/binary-file-handling.md)
## How to find the correct page
If the exact page cannot be found, you can still retrieve the information using the documentation query interface.
### Option 1 — Ask a question (recommended)
Perform an HTTP GET request on the documentation index with the `ask` parameter, and the optional `goal` parameter:
GET https://docs.novacura.com/flow-connect/working-with-connect/connect-to-systems/managing-connectors.md?ask=<question>&goal=<end_goal>
### Option 2 — Browse the documentation index
Full index: https://docs.novacura.com/flow-connect/sitemap.md
Use this to discover valid page paths or navigate the documentation structure.
### Option 3 — Retrieve the full documentation corpus
Full export: https://docs.novacura.com/flow-connect/llms-full.txt
Use this to access all content at once and perform your own parsing or retrieval. It will be more expensive.
## Tips for requesting documentation
Prefer `.md` URLs for structured content, append `.md` to URLs (e.g., `/flow-connect/working-with-connect/connect-to-systems/managing-connectors.md`).
You may also use `Accept: text/markdown` header for content negotiation.
