# Page Not Found
The URL `reference/how-to-guides/dependent-controls-in-user-step/control-visibility-based-on-end-user-input.` does not exist. This page may have been moved, renamed, or deleted.
## Suggested Pages
You may be looking for one of the following:
- [Control visibility (condition to hide)](https://docs.novacura.com/flow-connect/reference/how-to-guides/dependent-controls-in-user-step/control-visibility-condition-to-hide.md)
- [Dependent controls in User step](https://docs.novacura.com/flow-connect/reference/how-to-guides/dependent-controls-in-user-step.md)
- [Variable source](https://docs.novacura.com/flow-connect/reference/how-to-guides/dependent-controls-in-user-step/variable-source.md)
- [Expression source](https://docs.novacura.com/flow-connect/reference/how-to-guides/dependent-controls-in-user-step/expression-source.md)
- [List selection input](https://docs.novacura.com/flow-connect/reference/how-to-guides/create-user-step-controls/list-selection-input.md)
## How to find the correct page
If the exact page cannot be found, you can still retrieve the information using the documentation query interface.
### Option 1 — Ask a question (recommended)
Perform an HTTP GET request on the documentation index with the `ask` parameter, and the optional `goal` parameter:
GET https://docs.novacura.com/flow-connect/reference/how-to-guides/dependent-controls-in-user-step/control-visibility-condition-to-hide.md?ask=<question>&goal=<end_goal>
### Option 2 — Browse the documentation index
Full index: https://docs.novacura.com/flow-connect/sitemap.md
Use this to discover valid page paths or navigate the documentation structure.
### Option 3 — Retrieve the full documentation corpus
Full export: https://docs.novacura.com/flow-connect/llms-full.txt
Use this to access all content at once and perform your own parsing or retrieval. It will be more expensive.
## Tips for requesting documentation
Prefer `.md` URLs for structured content, append `.md` to URLs (e.g., `/flow-connect/reference/how-to-guides/dependent-controls-in-user-step/control-visibility-condition-to-hide.md`).
You may also use `Accept: text/markdown` header for content negotiation.
